Question about iiyama Computers & Internet
Buzzing sound on light backgrounds on monitor
Why does my lcd screen show lines and buzz on startup?
Try it on a different computer. If it works, your motherboard may have problems. If it doesn't work, try another data cable.
May 05, 2014 | V7 Computers & Internet
Color Tv
Buzzing nois of this kind can come from a short or from disturbance.
Aug 11, 2008 | Sylvania 6413TC 13" TV
On my Dell E193fpc monitor, the background lighting goes off after a few seconds. The actual Screen-image is still there (can be seen in bright sunlight). How can I get the backlighting to work proper
This sounds as though there might be a problem with the inverter (this is a component that supplies a high voltage for a tube(s) that illuminate the screen.
As there are high voltages on inverters, this is really a job for a repair shop.
Dec 11, 2013 | Dell E193FPC 19" TFT LCD Flat Panel...
Background buzz through speaker dock
Hi
You have posted this in the "Mac Laptops" category?
Well it is very difficult to say where the buzz comes from. It sounds like a hum from your mains. It might be a transformer close to your amplifier or it might be plugging in to two different circuits from your fuse box - ie using a plug from a neighbouring room. Also fluorescent lights can give a buzz that affects sound systems.
Hope this helps
Oct 28, 2013 | Audio Players & Recorders
When the monitor is turned on the screen goes on but there is a buzzing noise coming from the power supply board, then after 3 seconds the monitor goes black but the green power light is still on and the...
Sounds like the common Bad Capacitor story! If your monitor is not under warranty and you have any soldering skills this is only a 10 dollar fix. There are dozens of tutorials on youtube that will walk you through this. Search "Monitor capacitor replacement".
Aug 05, 2011 | HP L1740 17" LCD Monitor
My acer monitor displays the acer background, makes a noise like a buzzing sound and goes black, and then after all my settings and background picture and information are complete and up, the monitar...
It sounds like a backlight or inverter problem. You can verify this by using a bright light to shine on the screen surface. If you can see the picture (but it will be very dark) that means that the backlight which illuminates the screen from behind. You would have to replace the inverter to test it, but there is good news: These are pretty difficult to find parts for, and not an easy repair for an amateur; acer products usually have a 3 year warranty on the backlight/inverter system, so I would start there.
May 25, 2011 | Acer V193W 19 inch LCD Monitor
Samsung P237HD tv/monitor,unit buzzing when on.
I would take it back unless you have time to investigate the problem before the return policy expires.
If the sound is coming from the speakers then it is interference and would likely happen with another TV.
The interference type can be electromagnetic or radio frequency, both of which can be defeated.
Start with plugging it into a different outlet. If that doesn't work, then unplug anything from it one device at a time to see which thing is the culprit. If it is one of the devices, move any audio cords away from power cords and/or position the device further from the television.
Household appliances and fluorescent lighting also can cause signal interference in electronics that is audible.
A device known to help with such interference are power line conditioners from such brands as Tripp lite, and ferrite clamps. You can place ferrite clamps on the power cords of your devices and their analog audio connectors.
Jan 10, 2010 | Samsung P2370HD 23 in. TV
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
Rca buzz me off
Do you picture and sound normally in the background?
Nov 04, 2007 | RCA F32450 32" TV
Computers & Internet Logo
Top iiyama Computers & Internet Experts
William Miller
William Miller
Ed Mac
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
