Question about Dynex Enhanced-G Wireless Broadband Router
I have a Dynex Wireless Enhanced G Router; 2.4 Ghz-802.11g. It has, apparently, stopped working, as I can connect my laptop directly to the modem and connect to Internet. Is there any way to 'fi
I'm hoping this router has not 'died', but if it has, what type/power should I look for ?
2 Suggested Answers
Sgt Fluffy
  • 157 Answers
SOURCE: Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Posted on Jun 09, 2009
I can not find the web site to log on and change my password for my Dynex router i am afraid that other users can log on and use it help
hi. I think I can help you with this.
First, make sure internet is directly connected to the router with a lan cable from the cable modem.
Next, connect your laptop to the router's lan ports with a lan cable, instead of attempting to connect to it wireless-ly.
Next, open a browser, and go to this address: 192.168.2.1
Next, if you didn't assign a username and password, when it asks for them, leave them blank, and press enter
If you have already given it a username and password, use them to log into the router.
Then, go into security setting and select a security level...i.e. wep, wpa, and so on, and give it whatever you want to have for those, but make sure you write them down, as you will need them to log into the internet, as well as logging into the router page.
After you do everything you need on settings, click the save button if there is one.
If not, then click log-out
Next, disconnect the wire from the router to your laptop, and unplug both modem and router.
Next, plug in modem first, and wait 45 seconds for it to initialize, and then power up the router.
Within about 30 seconds or so, it should initialize, and be ready for you to use it.
Thenlog on to that internet connection, and enter the username and password that you gave the connection, and you should be good to go.
Jan 25, 2011 | Dynex Enhanced-G Wireless Broadband Router
My computer is not connecting to my Dynex wireless router. I've called my locate cable subscriber and they told me that it's a router problem. I've disconnected the router several times and it shows that...
First off, verify that you can connect to your cable modem directly. After that, hook up your Dynex wireless router and reboot your cable modem. After this, directly connect your computer to the Dynex router (using a cable). If you cannot get an Internet connection, then there is some issue with your Dynex router configuration. It's possible that there might be an IP address conflict with the cable modem. It would be best to contact support for configuring the Dynex.
If you can connect to the Internet with your computer connected directly to the Dynex router, then there must be some router configuration problem affecting your ability to connect wirelessly. You'll have to check the configuration--might be a good idea to completely reset the router and start over. If that doesn't help, you should contact Dynex customer support, as each router has its own configuration specifics. Good luck.
Nov 07, 2010 | Computers & Internet
Stopped working with internet modem supplied by AT&T and the AT&T service tech. said to contact DYNEX to soulve the problem of connectivity
Do you have another router to try? What exact problem are you getting? Can you still access the router itself?
Thank you,
Lee
Jun 30, 2010 | Dynex Enhanced-G Wireless Broadband Router
Router stopped working
check the power adopter and and also check your router's power led is glowing or not, if both are ok then need to check your internet service provider about internet connection.
Mar 04, 2010 | Dynex Enhanced-G Wireless Broadband Router
We had to replace our modem & our wireless router isn't working
You have got a new modem. You will need to change the settings of the router according to the new modem.
First make sure that your computer is able to go online when connected directly to the modem. If that works then connect the computer to the router and the modem to the router.
open the set up page of the router and set up the router.
Click here for more info
Nov 28, 2009 | Dynex Wireless-G Broadband Router
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
The modem light is flashing when all others are solid
whenever ur noderm light flashes then it means that there limited or no connectivity at all so plz try configuring or try checking the moderms ip and see if that solves the problem
Apr 07, 2009 | Dynex Enhanced-G Wireless Broadband Router
Dynex Wireless G Router
check the configuration of the router then re-configur the router it
Feb 26, 2009 | Dynex Wireless-G Broadband Router
Wireless signal keeps dropping/dissapearing
Check my tip
Using Router and Wlan adapter from different brand (Dynex + Belkin) is sometime calling for trouble: you must configure both to be sure to be on same standard (or change Both).
I'm using Netgear + Belkin and tune is not easy
On router config check radio power, reduce the used standard (B/G A/N) to the only one used by Belkin adapter (N).
Be sure you removed Windows zero wireless configuration (= use windows to manage my connection= OFF)
edit your belking wireless networking utility to automatic reconnect:
try downgrading to G standard from router side
Check your network connection plugging your laptop to router via lan cable.and check network params (DHCP DNS etc.).
Then check wlan connection near router, if you experience wlan drops only when far from router, find any possible interferences source (Microwave, cordless, remote) remove it or be ware you cannot have wlan when your wave is working.
Dec 13, 2008 | Dynex Enhanced-G Wireless Broadband Router
Need help with best connection type for college student in dorm
The enhaced version just give more range of signal over the normal dynex, regarding the internet provider it depends because sometimes you'll need a password and user to connect to the wireless signal. The dynex is used to connect from a cable signal (RJ-45)internet and then it will transfer the connection to wireless so it can be use from any laptop with wireless connection. So for example you DSL internet connection is a cable (RJ-45) then you connect that cable to the dynex router, then the router will automatically transmit the signal to wireless so any nearby pc can connect to it. If the laptop doesn't have wireless, then you'll have to buy a card to be able to connect to wireless signal or you could by also a (RJ-45 straight-through cable Cat 5e) to connect from one of the ports from the DYNEX to the laptop. Hope it helps.
Aug 19, 2008 | Microsoft Xbox 360 Console
Dynex Enhanced-G Wireless Broadband Router Logo
74 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
