Question about Dryers
Kenmore 970-C93812-10 squeaky drum bearing - Dryers
4 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: Kenmore Dryer Model 970-C82062-10
The bearing or spindle the drum rotates on is probably bad or worn out. You can get to the back and turn it by hand and feel it when you turn it. You can tell if it is metal rubbing. If so, you can replace it.
Posted on Jan 25, 2009
SOURCE: banging noise when the drum is spinning
I had the same problem -- the banging started suddenly but got worse and worse. I took the top off, looked inside, spun the drum around several times, and lo and behold a wooden bead fell out! Who know how it got there, but no banging now that it is gone!
Posted on Aug 07, 2010
  • 314 Answers
SOURCE: Dryer drum or rollers or bearings are squeaking on my Kenmore 970-C69042-00 clothes dryer. How do I best trouble-shoot and repair it?
Instructions
    • 1 Turn off the gas to a gas dryer or unplug an electric one. Move the dryer from its position at least 3 feet from the wall. This will give you room to work. Pulling the dryer out into an even more open space may make this easier.
    • 2 Push the putty knife in between the top and main body of the dryer on the front of the dryer. Slide the putty knife near the corner closest to you. Push the knife and pull up to release the pins that hold the top onto the body.
    • 3 Lift the top off the body using a screwdriver as a lever.
    • 4 Label the wires that are connected to the front of the dryer. Make note of which wire goes where. Unclip the wires from the clip that holds them, remove the wires and place them to the side. You will be reattaching these wires later. Be sure to mark them so that you can place them back in order later.
    • 5 Remove the screws that hold the fount of the dryer onto the rest of it. There should be four on most models.
    • 6 Pull the front towards you until the drum inside comes loose from its bearing. Slide the front panel up to reveal the pulleys at the bottom of the machine.
    • 7 Grab the idler pulley. It is the one in front of the motor. Move it to the right to disengage the belt. Remove the belt. Do not remove the belt that goes to the drum.
    • 8 Put on your gloves and slide the drum out of the dryer. Be sure to use hand protection as the edges may be sharp.
    • 9 Inspect the two rollers. If they appear damaged, or you find metal dust under them, your rollers need replacing.
    • 10 Remove the plastic clip on the right hand side if the right roller needs replacing. Remove the metal friction plate, metal brace and plastic clip on the left hand side if the left roller needs replacing.
    • 11 Put on the new rollers and reattach the parts you removed.
    • 12 Slide the drum back in and grab the idler pulley. Pull the pulley to the left until the belt is tight.
    • 13 Slide and screw the front into place and reattach the top.
Posted on Jan 15, 2013
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Kenmore model 970-C85072-00
There's normally a plastic triangle piece you have to remove to slide the bearing off. Otherwise you've got 2 1/2 inch bolts holding the bearing on the back depending on how old it is. You gave a model number for a washer.
Nov 26, 2013 | Dryers
Dryer drum started vibrating tremendously. I verified the belt and it looks in good condition. Suspect it might be the bearing or rollers if any. How do I remove back panel to inspect? (Kenmore Laundry...
You can't take the back panel off because that is what holds the bearing and holds the drum. I can tell you the bearing is the most likely cause. http://www.repairclinic.com/ sells the bearing kit and I would go ahead and replace the belt while you have it apart. I've done it by myself a few times, but it is best to have someone help at least while putting it back together. Holding the drum in place while putting the screws in the back of the drum (on the bearing) is the hardest part of the whole job. I believe I also got the directions from Repairclinic.com also.
Oct 23, 2013 | Kenmore Dryers
How do I fix my Kenmore front load washer ?
your drum bearings have gotten water in them due to a bad lip seal on the back side of the inner drum,if you can buy the bearings and lipseal you can tear it down and replace these rusty noisy bearings,and leaking seal
Aug 26, 2012 | Washing Machines
My kenmore washing machine (front loader, model #970-C42062-00) is not spinning the clothes dry. sometime water is left in the drum other times not. the drum is making a squeaky noise as well. what...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 22, 2011 | Washing Machines
My dryer makes a squeaky sound during adrying
the front guides around the drum or the bearing at the back may be failing partially or bearings in the motor may have started to noise,there is also the chance that the belt idle pulleys have started to wear,more than lightly it is the belt idle pulleys that have dried up or the bushings have started to wear
Jun 30, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
Mar 07, 2009 | Kenmore Dryers
Jan 25, 2009 | Kenmore Dryers
Kenmore dryer making excessive noise
Likely the main drum bearing in the back. I have seen these go bad, and loud squeaky noise tells you. You can get a new main bearing and replace. It is in the center of the back of the drum, accessee through back panel of dryer usually.
Mar 06, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
64 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
