Question about Adcom GFA-5503 3-Channel Amplifier
Power button on adcom gfa5503 is stuck in the on position
Power button will not release
    Genius:
  • 1,175 Answers
Hi...
Contact ADCOM through their website. They seems pretty helpful.
The part is probably an off-the-shelf type that snaps into the front panel.
Posted on Jan 28, 2009
I want to bridge 2 adcom GFA 555 amps to my sony DA7ES any suggestions
Obviously you are going to use the Front pre-out's on the Sony to drive the Adcoms. its pretty straightforward, just do not use a speaker that is less than 8 ohms. and make sure that you always have the power switch off on the adcoms, let them sit off for 5 minutes, THEN hit the bridge switch on the back of the adcom's and follow their instructions for bridging. it's pretty easy and tough to go wrong. Good luck...Rob
Apr 18, 2015 | Adcom GFA555 Amplifier
Should I repair my adcom GTP-506?
It sounds as though a remote control button is stuck or perhaps one of the remote control sensors within the unit itself. I would imagine this piece of equipment to be well worth repairing and likely the most cost effective avenue as well.
Jul 28, 2014 | Adcom Audio Players & Recorders
How to release the stuck steam button stuck in the up position in a morphy richard
On this model i believe you have to slide the button back to release perminent steam function. I am not sure what screws are on this iron as to what they are called.
regards, I hope this was useful.
May 13, 2014 | Irons
Preamp stuck in standby mode
a flaslight bulb and batteries and couple of wires can be used to make a continuity tester.and also pls check the small pushbutton(power button)try the remote if theres any
Feb 04, 2014 | Adcom GFP-710 2-Channel Amplifier
How do you connect wiring to bridge an adcom gfa 5300?
The manual does not specify a bridging option.
http://www.audioreview.com/cat/amplification/amplifiers/adcom/gfa-5300/prd_116265_1583crx.aspx
"Weaknesses:
Not bridgable."
Generally an amp that IS bridgeable uses the positive speaker terminals and some switching method to tell the unit to run as bridged. This is NOT a recommendation to try it on the 5300.
Aug 02, 2011 | Adcom GFA-5300 2-Channel Amplifier
I have an Adcom GFA 555 type II that won't shut off when the power switch is turned off...I'm assuming a relay problem?
please replace power switch to solve amplifier problem as power switch internal contacts seems stuck and does not disengage to turn power Off.
Thanks.
Mar 19, 2011 | Adcom GFA555 Amplifier
Adcom GFA-7400 power amp; 1 dead channel (thermal protect LED on)
Hi...
I've contacted ADCOM before and they sent a pdf of the electricals
http://www.adcom.com/default.aspx
also try:
www.stereomanuals.com
Mar 30, 2010 | Adcom GFA-7400 5-Channel Amplifier
Power button stuck in 'Off' position
My CHI button is stuck on off, how do i fix it ?
Aug 01, 2009 | Wahl Health & Beauty
Adcom 7500, Adcom 5400(bi-amp), Marantz AV-9000, Dakiom HA103
Try just the power amp on ..nothing connected
no Dakiom thingy either. It's a matter of elimination. Start at the output device and work back. Keep the Dakiom out of the loop.
If there's hum with just the Adcom..then it's the ADCOM
Mar 25, 2009 | Adcom GFA-7500 5-Channel Amplifier
No remote found
If pushing the power button does nothing, the unit is probably in "protect mode". This means there is an internal problem and will require professional service.
Sep 08, 2007 | Adcom GTP-760 Amplifier
Adcom GFA-5503 3-Channel Amplifier Logo
174 people viewed this question
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Edward Carrington...
Level 1 Expert
Jay Plesset
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
