Question about Proform 980 CS Treadmill
Pro-form 980, regardless what button I hit the speed goes to 12
When I turn on my pro-form 980 if I press any button the speed goes to 12 and it won't slow down, the stop button doesn't work, I have to pull the red button off.
    Top Expert:
  • Proform Master
  • 12,223 Answers
1) test the speed sensor, for open or faulty, see the adjustment. Clean if and tight the connector very well
2) tight the ribbon cable for keypads , and clean it
3) replace batteries,and clean the contacts baterries very well
4) adjust the Reed swtich, test for open or faulty, clean it and tigh the connector very well see the diagram
5) Run the software calibration for troubleshooting, diagnose, and fix it.
God bless youpro-form 980, regardless what button I hit the spe - 1_22_2013_5_14_38_pm.gif1_22_2013_5_14_58_pm.gif
Posted on Jan 22, 2013
SOURCE: pro form 520 treadmill
I know this thread is a little old, but did you get your treadmill working? I have a 550e that does the same thing. The company has sent me 2 controller boards, but still doesn't work.
Posted on Jan 27, 2010
maxtreadmill
  • 832 Answers
SOURCE: My Pro Form 580 XP slows down suddenly while on,
If you have not ever lubricated the running deck then I suggest doing so . What happens is that the lack of lubrication will tend to make the belt drag thus slowing down the belt making the motor control board to try to compensate the drag.
Posted on Apr 21, 2010
maxtreadmill
  • 832 Answers
SOURCE: the proform 980 turns on but just goes to incline
It is trying to its starting point I would suggest is to unplug the unit open the motor shroud unit. The shroud it has a mini manual this should have a calibration instructions that can be done and also upper electronics self test to see if the processor is functioning properly. It should give a better idea which to head. You can call Icon Fitness@ 1-800999-3756
Posted on May 06, 2010
maxtreadmill
  • 832 Answers
SOURCE: My Pro-form 980 CS will not start. I plug the key
Press the Stop and the Speed Up keys down while inserting the safety key. This should get you into calibration mode. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. If you cannot get into calibration or if the EPROM test fails then the upper console will have to be replaced.
If you get pass to this point then proceed with the calibrating the incline and speed.
Press either incline key and the incline will calibrate automatically.
Be careful the treadmill will run at full speed in the next mode DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
Posted on Jun 12, 2010
  • 84 Answers
SOURCE: my pro form 525 slows
check all wire connections on the controller board ,it could also be fried
Posted on Mar 08, 2011
In tvs speed 40 printer all led light are blinking
follow these steps
1) Press ST1+READY button together
2)Turn on the tvs speed 40plus passbook printer
3) The 4 LED will blink 4 times. Release the button ST1+READY immediately after 4 blinks
4)PRESS ST1 - ST1+READY+EJECT starts blinking
5)again PRESS ST1 - ST1+EJECT+ST2 starts blinking
6)again PRESS ST1 - ST1+EJECT starts blinking
7)again PRESS ST1 - ST1+EJECT starts blinking
8)again PRESS ST1 - READY+EJECT starts blinking
9) printer is READY wait and PUT PAPER.
10) The paper goes in and comes out 3 times. will take about 2 minutes.
11) Paper ejects automatically after printing.
12) turn off the printer and turn it on.
Jan 24, 2014 | Office Equipment & Supplies
How to recalibate a pro-form 595LE treatmill.
follow this steps and fix it. God bless you
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Dec 09, 2013 | Proform 595LE Treadmill Walking Belt
Ifit light flashes. Everything works properly except light flashes, which is distracting and irritating.
o 1 Check the connection cablebetween the Pro-Form device and the home stereo, computer, television or VCR ifthe iFit program is not working. Ensure that both the Pro-Form device and thestereo device are both turned on in order to function properly.o 2 Connect the Pro-Form deviceto the computer prior to logging onto the website iFit.com if the iFit programsare not downloading or operating on the computer. The fitness device mustremain plugged into the computer at all times in order to use the iFit programsduring the workout.o 3 Insert the console key andpress the "Program Select" button repeatedly if the iFit program isnot working properly. Ensure that the fitness device is connected to thedesired output device, such as the computer, television, VCR or MP3 player. TheiFit indicator should be lit on the console display.o 4 Press the "Start"button on the console if the time display is flashing on the Pro-Form device console.The iFit program will not function while the time display is flashing.o 5 Listen for a chirping soundif the incline or speed changes suddenly on the fitness device. The chirpingsound indicates that a speed or incline change is about to take place, even ifthe iFit program has not announced the change.
Nov 09, 2011 | Exercise & Fitness
I need to reset my Officejet Pro K8600, can anybody help?
Follow the below mentioned steps to do a reset :
-Press the Power button to turn off the product.
(The product might not turn off after pressing the Power button. Continue to the next step regardless)
-Disconnect the power cord from the rear of the product.
-Unplug the power cord from the electrical outlet.
(Wait 30 seconds.)
-Replug the power cord into the electrical outlet.
-Reconnect the power cord to the rear of the product.
-Press the Power button to turn on the product.
Sep 22, 2011 | HP OfficeJet Pro K8600 Printer
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
EPSON Stylus Color 900, 980
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Feb 27, 2011 | Epson Stylus Photo 785EPX InkJet Printer
Jun 12, 2010 | Proform 980 CS Treadmill
The proform 980 turns on but just goes to incline
Apr 30, 2010 | Proform 980 CS Treadmill
My Pro-form XP 185 U bicycle has a timing problem. It stops every 5 seconds, and you have to press the start button again. How do i fix this?
My pro form cardiocrosstrainer 800 has a timing, speed, and calarie
diplay problem. It does not work. How do i fix the problem with on the console display.
Jan 27, 2010 | Proform Cycling
Ifit treadmill will not incline but everything else works, how do I fix the incline
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
Proform 980 CS Treadmill Logo
129 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
