Question about Electro-Voice Dc-one Loudspeaker Controller
Why Electrovoice DC ONE no sound
Why output 1-2-3-4-5-6 no sound need connect to pc or something to do this
Check level settings
Posted on Mar 31, 2013
I have an Astec DS 1500-3-001 power supply that I want to use a a stand alone PS. What pins do I need to connect to get +12v DC output with 120 VAC Input.
Mike
I take it that this is a standard power supply out of a PC (switch mode)
These are a common connection point on any brand PC
Use a DC Voltmeter to find the Ground, +5 Volt & +12 volt wires to power your 3.5 inch Hard Drive. The 2.5" Hard Drives (laptop) has only Ground (Black) & +5 Volt.
Oct 30, 2014 | Computers & Internet
I mistakenly connected energy source at the AC inverter output .Inverter is 5KVA cyberpower inverter.After correcting the connection, It cannot switch from DC to AC( fault signal is displayed on its...
John,
It's shorted out, either replace the part or buy a new one.
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Sep 24, 2013 | Cybernet Systems CyberPower DC to AC...
Put wrong power supply into unit
You probably blew it. It sounds like the power supply put out more voltage then needed. Also they come in AC/DC, putting AC into a DC input usually blows things, dC into an AC normally does not hurt it assuming the voltages are in range in all cases.
Jan 12, 2013 | American Audio VMS2 VMS702 Table Top MIDI...
Micromax x225 is showing low signal
Ever looked at the power specifications of a mobile charger?? well if not, then have a peek... u will read that the output voltage is 5V DC........ the computer USB also has a voltage output of 5V DC........... any USB based electronic device needs this power to get started.... The laptop coolers u get basically work on this power from the USB... U'll notice that the USB ports have 4 terminals.... the extreme outer side are the POWER terminals +ve and -ve..... the middle 2 are the BUS lines IN and OUT.... a BUS is something electric conductive that allows the flow of 0's and 1's or rather high and low voltages to pass(Basic IT theory).... so this 5V DC can be used for doing anything; charging the mobile phone battery to lighting up entire rooms with LED's, making laptop coolers, etc......... Every mobile phone which has the USB connectivity option gets charged when plugged in... so sometimes even if u dont have the Mobile charger dont panic, find a computer and plug in the USB... not only micromax x225 mobile but, there are almost 80% mobiles which charge by connecting it to pc. Only nokia phones don't get charged. it is a good feature don't worry
Feb 24, 2012 | Nokia Cell Phones
The radio is on, no sound comes on, all wires checked
Check if your speaker cables are connected very well.
Use a battery remove your speaker cables test them with the battery for signal.
Check and reconnect everything you connected to your bose radio.you will here a sound . take care.
Jan 19, 2010 | ElectroVoice...
I have an Electrovoice MA-1212 That when I hook it up and power on all I get is a constant low frequency Hum. Checked the wiring and speakers on another amp and eliminated them? Any suggestions?
WIth the speakers disconnected, measure the terminals using a DC voltmeter. I suspect that there is DC voltage there where there should be 0V. If that is the case, the output transistors are shorted and need to be replaced.
Dan
Jul 31, 2009 | ElectroVoice...
I cannot find the specs or user manual on the JVC archived items list. A few sites want to charge $10.00 for the user guide info, but I think that is too much to charge.
Defiantely not 200 watts
KS-A82
  • 2 Channel Amplifier
  • Bridgeable 2 channel amplifier
  • Output power: 25W x 2, 20 - 40,000 hz at .08 THD
  • 2 ohm stable
  • Adjustable gain (.1 - 2v)
  • MOS-FET DC-DC converter
  • Multi phase connection
  • 1 Pair of line input terminals
  • Remote relay turn on system
  • MSRP: $159.95
http://www.admtechusa.com/JVC.html#KS-A82
May 22, 2009 | Car Audio & Video
Amilo Pro v2065 shuts down when battery is plugged
you need do check:
1) no charging means adapter input problem, first check your adapter DC output voltage is ok
2) check DC jack socket on the motherboard:
--- DC socket any pin disconnected, you need use iron and flux to fix it
--- DC socket damage(broken),you have to change it
3) if DC socket connection normall, the DC/DC circiute near around DC socket some component damage, you need find a technacian to repair.
hope help you to deal it well
May 14, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
TV has low sound output through right speaker of stereo receiver
try the balence. if no joy. try the cable if you have a meter also see if the cable and see if the cable has been reversed???????
Mar 27, 2009 | Samsung HL-S5087W DLP TV
How will i know if the horn has blown on my ev zx 5 speaker?(there is no top end at all) thanks.
first,try switching to a different output(if this is the left speaker,switch it to the right)if it does the same thing,then we need to pull the back off the speaker.to make sure the crossover is not bad your gonna want to unplug the horn & put a signal to it from your source(do this at a low volume with the bass turned down & trble turned up)if you have sound then there is a problem with the crossover(this is the pc board in the enclosure that connects to the speakers)if not your horn is gone.hope this helps,thanx for using fix.please rate all replys
Nov 17, 2008 | ElectroVoice Audio Players & Recorders
Electro-Voice Dc-one Loudspeaker Controller Logo
Top Electro-Voice Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Electro-Voice Audio Player and Recorder Expert? Answer questions, earn points and help others
