The fone wont charge the orange light comes on for a few seconds then turns off and not charging
Hello Dear Friend:"::"
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
SOURCE: phone will not turn on
i think a similar thing happend to me i have sidekick lx and the whole little light show thing will show up and make noises and then the screen will work for like 2 min and the dim back and go back and so i called t mobile and they said it was the battery to go to a t mobile retailer and ask about the php bundle but not all of them have switched over so none of them had the battery for my lx or the tester so they sent me a new battery in the mail and it still didnt work then finally they send me a new lx and it works but know it wont make any noise when i get a text and stuff its anoying me. =)
SOURCE: sidekcik Lx will not charge.
alright..my sidekick does he same thing but i fund a temp fix....the guy at the store says its the charging port..idk.....first plug it in....let it charge 4 ten min....then try to put in on...it will say the low battery sign...dont worry...then t8 sumting pointy and push it in the little reset hole behind the screen as you swivel it...as soon as you see the little box with the circles in it you press and hold the space button... hopeully it will start by showing the four butttons....if it does start and cuts off at the tmoblie sign jus let it charge longer and do it agian....hopefully it will work on yours it worked on mine....gud luk
SOURCE: rokr e8 won't charge
when the phone discharges completly, it can olny be charged via the charger that plugs into a wall outlet.
SOURCE: my htc touch pro wont turn on after being charged all night
Had the same problem. You need new battery! (borrow from friend, if anyone has HTC to test if phone is OK with different battery).
Testimonial: "holy crsp it worked thanx:)"
SOURCE: my nokia E63 wont start up. the screen just lights
Take the battery, sim card and microSD card out for an hour or so then place the components back in the phone. If this doesn't work, go to www.nokia.com and download the firmware for your phone via instructions on the Nokia web site.
