Question about Samsung TXJ2754 27" TV
1/2 screen blank
Frequently I get 1/2 screen with no picture, and its only the bottom half of the screen that goes blank, not the top half. The Samsung is a Flat Panel, only 2 years old.
    President:
  • 3,130 Answers
Sounds like a bad connection on or in the vertical output circuit, or the drive circuit. Could also be the vertical output IC or the surrounding componets going bad. Good Luck
Posted on Jul 22, 2007
SOURCE:
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
One half of the t.v screen goes blank
Sounds like a back-light fault. Check its back-light inverter. To get more details, http://electronicshelponline.blogspot.com/Pull up older posts.
Nov 30, 2013 | Panasonic TH-42PX75U 42 in. Plasma HDTV
Only see half the screen - other half blank
Anytime you have a distortion in the image on the screen, this can NOT be reolved with a reset. You have a bad LCD module. Take a look at the pictures on this page and see if one is like the problem you are having.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
May 03, 2010 | Garmin nuvi 350 GPS Receiver
We have a widescreen plasma (Panasonic TY ST05-K). The picture all of the sudden shrunk to about 3/4 of the screen. Fortunately, the picture is not cut-off, so you can see the whole picture. The...
Hi there! If picture is smaller top to bottom with blank section on top and bottom then check your aspect ratio settings. If blank at the bottom only the Bottom Y-Drive board may be faulty. If blank at the top The Top Y-Drive may be faulty. If blank on the Left (TOP TO Bottom) then the Right X-Drive Board and on the Right, the Left X-Drive Board. May also be bad connections on the cables or flexible ribbon cables. Best Wishes and Good Luck, JUS004
Aug 23, 2009 | Televison & Video
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Black on bottom of screen
do me a fovor, i need your firmware version? to do this, press Input 619. in the center of the bottom of the screen, is three digits 5?.? please provide me with these numbers. you may just need firmware updates.
Sep 28, 2008 | Dell W5001C 50 in. Plasma HDTV
Bottom half of screen goes blank
Take it to a repair facility, don't be a cheaps ***.
Jul 27, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Problem in my HITACHI CMT2153 TV
hi, the problem is in the vertical ossilation if only u can trace the bad component.. let me know
Jan 10, 2008 | Televison & Video
Half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Samsung TXJ2754 27" TV Logo
202 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
