Question about Apple iPod Audio Players & Recorders
My ipod model a 1285 keeps turning itself off why
When listening to my music, although the battery is charged, it keeps turning off ,what is wrong with it.
  • melanie fellingham Jan 24, 2013
    the solutions was very helpful and now my ipod is working again.
  • Brian Sullivan
    Brian Sullivan Jan 24, 2013
    well done hope it all worked out
  • Apple Master
  • 27,725 Answers
IPod keeps turning off Plug your iPod in overnight to make sure it has charge. If after a full night of charging it has a low battery, there is probably something wrong with your charger cable. Replace the charger cable, especially if yours is old or has ever gotten significantly dirty. Reset your iPod. This basic reset does not remove any content from your iPod. Apple suggests this soft reset as the first fix for any software problems or if the screen freezes. Eject your iPod from your computer first. For an iPod with a click wheel, toggle the hold switch on and off several times, then hold down "Menu" and the center button at the same time until the Apple logo shows up on the screen. For touchscreen iPods, hold down the "Sleep" button at the top right until the Apple logo shows on the screen. Perform a factory restore on your iPod if the previous steps do not fix the problem. Plug it into your computer and open iTunes. Click on your iPod, then click "Restore." This wipes all content from your iPod and re-installs the operating system.
b> iPod Keeps Cutting Off b> Your iPod may cut off during a song or video, or during an application. Different causes lead to different types of cutting off just the sound may disappear, or you may suddenly experience cutting to a different screen. For example, if your iPod cuts off during a song, you may have merely hit the "Pause" button. With a blank white screen, you're encountering a software problem. Whatever the reason, follow some simple troubleshooting steps before contacting Apple's customer service.
Headphones Check that your headphones are connected correctly if the sound cuts out suddenly. If the 3.5-mm headphone jack comes out even a little bit, it can make the sound cut out in one or both headphones. Check for debris in the headphone jack itself, which can prevent a solid contact between the headphones and the iPod. b> Other Sound Issues b> Make sure the volume is up high enough. Also, especially if the iPod is in your pocket, make sure you haven't bumped the pause or sleep button. To ensure that audio plays constantly, engage the lock on your iPod. The music will always stop when you pull out the headphones, and once the headphones are back in, you have to push "Play" again. Cutting to White Screen b> A sudden white screen may appear when a generic software malfunction occurs, one in which t you don't get an error message. You must reset the iPod by turning it off, then on again. If this happens several times and you are using the same application each time, that app may be faulty. Try re-installing or re downloading the app. b> Cutting to Black Screen b> An iPod that cuts out to a black screen and won't turn back on is usually out of power. Usually you'll see a low battery warning, but if you're not looking at your iPod when the warning flashes, you might miss it. Once you connect your iPod to a functional power outlet, you can turn it on immediately, but it's best to wait a few minutes when the battery is very low. This gives the iPod a chance to regain power so it can function normally when you plug it in. Hope it helps.
Posted on Jan 22, 2013
komguy
  • 2306 Answers
SOURCE: My Ipod froze
You can usually reset a frozen iPod by holding down the menu and center buttons for about 10 seconds. Hope this helps!
Posted on Jun 23, 2009
  • 846 Answers
SOURCE: My ipod 4th generation keep freezing
Try the button combination : menu button and center button together for 5 sec. That will hard reset your iPod (make sure it's not on hold when you do that.) If that doesn't work, Take it to the Apple store first. Only if you're not under warranty, you should try a firmware restore using iTunes. If that doesn't help it's a hardware issue with your logic board. The logic board can be replaced by a tech savy user and the part is available on common auction websites. There are ipod nano 4G Repair guides that show you how to do the replacement step by step.
Posted on Aug 19, 2009
  • 42 Answers
SOURCE: No Battery power remains connect ipod to power
Sounds like your battery circuit is not working properly. Since you have opened it before, open it again and check to see that the little plug where you put the battery tab in is pushed down to make a good connection. Sometimes the plug connector is in the up position and needs to be gently put back down to have good contact.
You could have also messed up the battery connector when you disconnected the first battery to change it. Sometimes that happens if too much force is used. I use a pair of tweazers to just gently pull the battery tab out of its plug. I also use the tweazers to gently push it back in without moving the connector up and down.
You could also have a bad battery. Have you tried putting the old battery back in to see if that works.
Hope that helps.
Posted on Dec 19, 2008
sweetshaan88
  • 11 Answers
SOURCE: ipod keeps turning off!!!
Did you try Restoring the iPod.
if not try restoring, if that doesnt fix get a replacement(if iPod is under warranty).
Even i did the same
Posted on Nov 04, 2009
SOURCE: my ipod won't charge. keeps saying
I had the same problem. Went to the Apple store and the technician said that the IPOD battery ran down to low (battery level showed red) and the USB port on the computer was not strong enough to recharge it. He used a rechargeable adapter that pluged directly into the wall (adapter cost about $30) and recharged it enough for me to take it home and recharge it on my computer.He said to never let the battery level drop below 5% unless you are going to recharge it using the adapter that pluged into the wall. I bought an IPOD rechargeable travel kit from Target for $20 and used it to recharge my IPOD. My IPOD works fine now. The Technician also said at some point the battery will need to be replaced (in a year or two depends). Will cost about $59 to replace it (don't quote me on the timeframe or price of replacement, this may have been just for my IPOD but thought this would be useful info for someone.
Posted on Dec 03, 2009
Tip
Connecting an iPod Without a Car Stereo
<p>Newer cars often come with adapters to connect an iPod to a car radio, but you can still listen to your favorite lists, if you do not have a car stereo at all. Portable electronics can be used to connect the iPod to speakers, and play it on your car. <br /> <p><br /> <p>1. Purchase an adapter FM radio transmitter for your iPod. It will stream music from your iPod to a low-frequency power, which can be captured by a radio in your car. For best results, use a transmitter with a power adapter 12 volts, you can power adapter car "cigarette lighter" power outlet instead of batteries. <br /> <p><br /> <p>2. Place a "boom box" radio in your car stereo. For purposes of the iPod, the older model, if you have done. All you need is a working radio and decent speakers. Again, it is best if you turn the car to avoid the use of batteries. <br /> <p><br /> <p>3. Set your transmitter to a radio frequency is not used in the stereo field, and tune the same frequency. Adjust the volume on the stereo halfway. <br /> <p><br /> <p>4. Place your iPod within reach of the driver or passenger. When the iPod is playing, the sound will be transmitted to the radio. You can adjust the volume on the iPod itself to control the music changing. When the iPod is off, the radios go silent, although you will hear a static noise. Turn on the radio to get rid of noise, and to save battery when not running the car's power. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How can I use my iPod while charging?
<p>If your iPod and it gets low on battery, you can continue to enjoy your music while charging your iPod. To charge your iPod, you can choose from one of two ways: Use a computer to add power to your iPod, or use an electrical outlet to charge the device. Either method will allow you to use your iPod while charging. If your iPod is so low that it does not turn, you may need something to load before you can use while charging. <br /> <p><br /> <p>Charging the iPod using a computer <br /> <p>1. Connect the USB cable to your computer and connect the other end into the iPod port. <br /> <p><br /> <p>2. Make sure your computer is on and not sleeping. <br /> <p><br /> <p>3. Open iTunes and choose the iPod that you connect to the source list to access the settings to get the iPod. <br /> <p><br /> <p>4. Open the menu "Options" and "Manually manage music" checked. If you change the settings to manually manage music, iTunes lets you listen to your iPod while it is connected to the computer and load. <br /> <p><br /> <p>5. Click "Apply" manually manage music, then use the iPod as you want on your computer while charging. <br /> <p><br /> <p>6. Eject the iPod once it is loaded by pressing the 'Eject' button in iTunes. Remove the USB cable from your computer and iPod. <br /> <p><br /> <p>Charging With USB Adapter <br /> <p>1. Connect the USB adapter for the iPod and an electrical outlet. <br /> <p><br /> <p>2. Continue to use your iPod as you want while charging through the USB adapter. <br /> <p><br /> <p>3. Unplug the USB adapter and plug the iPod and the iPod is charged. <br />
My ipod turns itself on, even in the lokced
My ipod turns on in the locked position also.
Dec 31, 2009 | Apple iPod MA446LL/A MP3 Player
My green Apple Nano Chromatic iPod's batter life & other problems
turn the backlight down or maybe let it charge even when the battery says its fully charged!
Dec 15, 2009 | Apple iPod nano MP3 Player
Ipod nanao 2 gb problem
Have you tried plugging it into your computer and restoring the programming? Also, you can try pressing the menu and the center button at the same time for 10 seconds. It should go black (turn off) and then turn back on with the Apple logo. If this doesn't fix your problem, you got something wrong with the hardware, not software.
Jan 19, 2009 | Apple iPod nano MP3 Player
My ipod will not light up... but it is charged. and i have tried to reset it. what else could be wrong?
When an Ipod wont power On the first thing to check here is the battery because if the Ipod is charge and still wont power ON it only means the battery is bad already and needs a replacement and if your Ipod is still under warranty the battery replacement is cover by the warranty so just take it to a Apple center and let them replace the battery....
Hope that helps.........
Oct 06, 2008 | Apple iPod nano
Won't turn on
tammy,
It sounds like you either need a new battery pack, or the iPod itself has to be replaced/upgraded.
Please let me know if this helps. Take care!
Feb 28, 2008 | Apple iPod nano
Ipod not turning on/not recharging
I think your ipod is dead. This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging.
I hope this helps. Please rate my solution.
Jan 12, 2008 | Apple iPod MA446LL/A MP3 Player
112 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
