Device manager shows a code 39 for the driver. How do I reinstall the driver. No disk available.
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps you
if you dont have a disk with the driver you will need to download one
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
or if its the drivers
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question or exclamation mark ? ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
http://www.opendrivers.com/companydriver/2165/optiarc-free-driver-download.html
you will need to select your operating system
hope this helps you
Click on
Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
for this device
drives if you see a yellow question or exclamation mark?! or a red x
or
hope this helps
Click on
Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
for this device
drives if you see a yellow question or exclamation mark?! or a red x right
or
hope this helps
