Question about Buffalo Technology MiniStation Computers & Internet
My Buffalo HD-PCU2 USB Flashes and tries to start up but then reboots. Works on other computers just not my own. Have restarted, unplugged, tried multiple USB Ports and unplugging from the wall, Device manager cannot detect and seems to get caught in a loop... Any suggestions? (drivers up to date.)
  • Brianna Jan 22, 2013
    New Computer, Windows 7 I have also gone through Windows Task Manager and checked to see if there was anything frozen or tying up resources, or has anything to do with the USB Ports.
    Genius:
  • Buffalo Tech... Master
  • 1,250 Answers
Check some other hard drive on the usb port of your pc, if it also not work then there must be the problem on the usb port of your system
Posted on Jan 22, 2013
3 Suggested Answers
  • 9 Answers
SOURCE: Iomega 250 GB external stopped working
This is really not a solution, but you should all try to connect your iomega to a imac, and use the Disk Utility (in Utilities folder), if you have any luck the hard drive will be recognized and you will be able to format it
Posted on Feb 14, 2009
JulesPCaut
  • 702 Answers
SOURCE: external hdd not detected in my computer but is in device manager
You probably still need to partition it, before you can even format it.
Try the disk manager in Windows.
In the start menu, right-click "My Computer" and in the popup menu, select "Manage".
One computer management comes up, select disk management and there you should see the disk. You can then create a partition and format it.
Jules
Posted on Mar 16, 2009
Buffalo HD PCU2
check weather it get connected with other system and other operating system. Also check your data cable
Jul 15, 2014 | Buffalo Technology MiniStation Computers &...
My Buffalo 1TB mini station HD PCU2 started having some problems after connecting to my new laptop which is having windows8 os. At 1st i couldn't open some folders. It said to format. Did it thrice...
The windows 8 will not recognise the driver for this unit and this is a common problem with win8. Try to get Microsoft download for the correct driver for you machine
Aug 03, 2013 | Computers & Internet
Buffalo HD-LBU2 not reconised by computer
Try a drive dock on the Removed Hard drive. The usual problem is the enclosure.
Apr 12, 2013 | Buffalo Technology DriveStation HD-HC500U2...
My 500 GIGABYTE BUFFALO HD-PCU2 USB DEVICE hangs or stops when i try to copy,move or delete a file from PC onto it
it sound like your buffalo usb has become unstable either because of bad or connection faulty lead , drivers need to be updated , or firmware needds to be updated and possible malware or a virus
http://www.buffalotech.com/support-and-downloads/downloads
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
hope this helps
Sep 21, 2012 | Computers & Internet
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
EXTERNAL HD DOES NOT RECOGNISE ON COMPUTER
w7 if your computer is running windows 7 you might need to do this
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Aug 02, 2012 | Buffalo Technology MiniStation Computers &...
I cannot eject my buffalo ministation HD-PCU2 and when I remove it safely, a message prompts and says "device is currently in use. Close any programs or windows that might be using the device."...
Hi Welcome to FixYa!
I am having the same scenario too sometimes.. What i usually do if the drive is not in use, I turn off the computer first then unplug my external hdd. in that case, the computer is completely off as well as the drive. But if you feel like its a hassle of turning down the machine for you to remove the drive, you could try the following steps:
There is a setting for the USB drives which tells the OS how to optimize their usage. Either it is optimized for Quick Removal or for Performance. To check it, do the following:
-Right click on the USB drive icon in My Computer. -Select the Hardware tab. -Select your USB drive and click on Properties. -Now click on Policies tab.
Optimize for Quick removal This setting disables write caching on the disk so that you can disconnect this drive without using theSafely Remove Hardware icon.
Optimize for Performance This setting enables the write caching on the disk so as to improve disk performance. To disconnect this drive, you should use the Safely Remove Hardware icon so as not to hurt your USB drive.
Hope this would help!
Sep 06, 2011 | Buffalo Technology 320GB MINISTATION TURBO...
Buffalo HD-HC160U2 stops open Computer is start menu
The orange light indicates the drive is getting power. So, that leaves a faulty circuit in the chassis of the drive enclosure or a failed circuit in the drive itself.
Take your drive to your local PC shop and have the technicians test it in a new enclosure. If it works buy the new enclosure and be on your way.
If not, get back to me with your location(Country, State and City), I will be happy to refer you to a professional near you with the right equipment to help you recover your files.
Hope this helps FixYa,
Chris
Oct 25, 2009 | Buffalo Technology DriveStation HD-HC160U2...
Apparently i need to reboot my BUFFALO & MINISTATION LITE HD-PE500U2/WH 500 GB, how do i do this?
Apparently -- if you don't know how to reboot -- you should perhaps ask some computer wizard among your friends for advice.
You don't reboot a hard drive (or any other device), you reboot THE COMPUTER. Which means you shut it down and restart it. During the startup process (which is synonymous to "booting") the computer checks all its internal interfaces and external sockets, takes an inventory of all devices and checks if they work properly.
Sep 23, 2009 | Buffalo Technology Computers & Internet
Cannot startup XP if connected to the 1T Buffalo HD
set first device as your harddisk is bios.
When you power up the computer press F2 or "del" key to enter in bios.then go to boot option then set first boot as hdd.
Jul 13, 2009 | Buffalo Technology 1TB DriveStation...
Computers & Internet Logo
146 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
