Question about HP Compaq nx8220 Notebook
How do i load windows xp on hp nx8220 it goes to microsoft then back to start windows normally then repeats is there a solution thankx
Does not load windows
    Problem Solver:
  • 7 Answers
The reason why is because ,hp computers use a different set of video drivers than does win/microsoft, when upgrading to xp you must install xp 1st release no svc pacs, then must have the hp video drivers oem for the model you are installing xp to , they can be downloaded on hp driver download, or the intel driver download site, unless you have a different chip set, the oem drivers must also be puton either a floppy disk or cd , that is made bootable from restart, make shure either the A drive or the C drive is set to boot before the hard drive so it will pick up the bootable disk you made with the downloaded drivers , then reboot the computer with the xp disk , at the disk partion screen select leave old files intact with the new install !
Posted on Jan 28, 2013
tat4u
  • 520 Answers
SOURCE: Windows Xp wont boot up
systems do this if the os hasnt been registered within the time limit or you could have missing sys files either way you'll have to re-install windows either repair existing os or fresh install..I suggest fresh install....you could try booting to safe mode then restart using option start with last known config that worked..you could even try startup from usb to get to dos prompt(virtual dos)
and type in win and enter or type first "chkdsk"which if successful will check and repair any errors;but if they all fail and quite possibly they will you'll need to reinstall anyway.
Posted on Jan 23, 2009
timthorne911
  • 464 Answers
SOURCE: HP Pavillion dv5000 laptop will not load windows.
I had this problem, because I have had my HP Pavillion Dv 9000 laptop replaced 3 times. There is a recall on those laptops. The mother board is no good. HP fixes the problem at no cost to you even if it is out of warranty. There is also a freeware and software BIOS update that was just released. And if your screen ever cracks there is a recall on that as well with the left display hindge. My solution: Call HP at 800-474-6836 they are available 24/7 365. Make sure you have your notebook Model number and serial number ready.
Posted on Mar 18, 2009
hmerchant110
  • 7191 Answers
SOURCE: REPAIRING WIN XP FOR A HP 530
If repairing the XP installation is not solving your problem, you can try a clean install by formating your drive and re-installing XP.
Posted on Jun 29, 2009
  • 81 Answers
SOURCE: hp compaq nx8220 (insert smart card into reader)
you need to push and hold control, alt, and delete to initialize the start up.
at this time it will ask you for your username and password.
Posted on May 31, 2010
  • 324 Answers
SOURCE: windows xp will not load
run scan disk from bios, sounds like you have alot of disk errors
Posted on Jul 04, 2010
Still not loading
Reinstall windows. Before that use Hiren CD and check memory and hdd.
Jan 22, 2013 | HP Compaq nx8220 Notebook
Hp nx8220 starts but will not load windows xp
Hi there, if you have the recovery disc try that first. However, I had to deal with a similar problem on a FUJITSU LIFEBOOK, and after trying many possible solutions it turned out to be - hard disk failure, sorry. Hope this is not the case for you.
Compaq NX8220 laptop reseting
Well it might be a factory default problem with the board, some times when systems are not fixed properly, it come up with such issue. I will advice you take it to service centre near you so as not to void the warranty.
Feb 29, 2012 | HP Compaq nx8220 Notebook
My HP dv6119us just started rebooting itself. Sometimes 10 or more times. The screen remains black. Once in a while Windows XP will start and everything is fine. But, most of the time when I turn it on it...
Hi
Please can you try the following
1) Switch on Laptop
2) Immediatley press the F8 key continuoulsy until a advanced start up menu is presented
3) Choose safe mode
4) Once in safe mode click Start>Run and type in msconfig
5) click the start up tab and remove all the ticks and then click ok and let the Laptop restart and see if this goes into windows
Regards
Shauqat
Sep 29, 2010 | HP Compaq nx8220 Notebook
Xp will not load up Goes thru the preliminaries but stops and asks if you want to start up normal, safe mode, etc None of these things work
Have you tried to use the Windows XP cd-rom and do a repair install? Or you can try the windows XP cd and use the recovery prompt, and type in fixmbr, after selecting 1 for your WIndows installation. Look at this site for information on how to use it.
http://support.microsoft.com/kb/314058
May 03, 2010 | Microsoft Windows XP Professional With...
Wont get past Microsoft Windows XP loading screen on Acer Aspire1
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 17, 2010 | Acer Aspire One AOA150-1126 Notebook
I get the Blus screen when trying to install a fresh copy of XP on my nx8220
If you are installing a fresh copy, you should boot from cd, and not start it from windows. It is less error prone.
Oct 27, 2008 | HP Compaq nx8220 Notebook
HP Compaq nx8220 Notebook Logo
65 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
