Question about Sport & Outdoor - Others
Jiffy model 30 ice auger carbutrator linkage
I have a Model 30 ice auger, and I need a picture of the govenor and carbutrator linkage.
saailer
  • 1868 Answers
SOURCE: I lost the gas cap from my Jiffy model 30 ice
Hello! Go to the following link to acquire a vented gas cap for your ice auger.
www.outdoordistributors.com/Tecumseh/tfuel.html
Guru..........saailer
Posted on Dec 27, 2009
snowghost1
  • 784 Answers
SOURCE: What should the gas oil
hello,
I work out at a remote fishing lodge in Alaska and the Jiffy auger we have here says 24:1 on the unit but I know for a fact ( cu'z I do the mixing ) that we run it using a 40:1 mix Ratio and it works great.
I have heard stories from other fishermen that they are running ' Amsoil* ' in there Jiffy augers at a mix ratio of 80:1 and they say that it cut down on the smoking of motor.
fish on,stay warm and have fun,
c...
Posted on Jan 02, 2011
SOURCE: I need the carb needle settings for my jiffy model
start at 1 to 1.4 turns to the left both from needles turned in .should start, from there,then fine tune P.S don't forget to turn in your idle screw some up
Posted on Jan 20, 2011
snowghost1
  • 784 Answers
SOURCE: the pull cord on my
if you just need the cord -- most hardware stores do carry replacement cord ( sold by the foot ),, if you look in the chainsaw department you should be able to find the size that you need. as soon as you have the cord you can re spool the winding unit and this will restore the pull start function.
you can also buy the cord at your local lawn and garden shops,snowmobile shops or chainsaw shops.
if you have any further questions about this problem -- please feel free to ask,
c...
Posted on Jan 26, 2011
snowghost1
  • 784 Answers
SOURCE: I was just trying to
the fuel mix ratio that Jiffy says is 24:1 --- but I have always ran 40:1 and had no problems.
c...
Posted on Feb 06, 2011
Jiffy ice auger won't start if cold model 30 start good room tempature
Piece of junk if it needs to be warm.....being an ice auger and all.....take it back if you can.
Jan 10, 2017 | Refrigerators
Why does my ice auger want to keep spinning and wont stop when you pull the cord it turns the auger
Pulling the cord will only start the engine. Your problem is with the centrifugal clutch. Check the clutch for broken springs. GOOD LUCK FRIEND.
Mar 02, 2015 | Jiffy Model 30 10" Ice Auger
What year is a model 76 jiffy ice auger
The model 76 ice auger was made over a number of years and is probably still be in production. If it has a Jiffy engine, it was made before 2011 ("2500 series"). If it has a Tecumseh engine, it's 2011 or newer. Your best bet for getting the age is to find the serial number on the auger or the engine and contacting the manufacturer. Info source: http://www.jiffyonice.com/EComStore/pages/operatingmanuals.aspx
Feb 11, 2015 | Refrigerators
Need parts for jiffy lite ice drill model 90 serial # 901465
Jiffy Ice Auger is made by Feldman Engineering & Mfg. Co. Inc., 520 Forest Avenue, Sheboygan Falls, WI 53085-2513 (920) 467-6167 800-344-0712 www.jiffyonice.com
Jan 29, 2011 | Sport & Outdoor - Others
I need the carb needle settings for my jiffy model 30 ice auger.
Jan 08, 2011 | Sport & Outdoor - Others
What should the gas oil miz ratio be for an older model 30 jiffy ice auger... fustarted fisherman
hello,
c...
Jan 02, 2011 | Sport & Outdoor - Others
I have a older model # 30 jiffy ice auger and i can not seem to keep it running consistanly. I was wandering what the carburator adjustments are. The low idle screw and the high idle screw where do I start...
Hello Randy. I can talk you through making adjustments to your Jiffy ice auger engine.
1. Read through the whole list before you start adjusting.
2. Close both jets GENTLY
3. Open the Low speed 1/4 turn
4. Open high speed jet 1 1/4 turn
5. Start engine.
6. Adjust low speed until idling smoothly.
7. Open her up wide open.
8. Adjust High speed until engine transitions smoothly from idle to high speed without bogging.
9. Shut engine off. Let it cool.
10. Once engine is cold. Fire it up and let it idle for 30 secs. Open it up wide open again. Adjust if necassary.
NOTE 1: The trick with the Jiffy's is to tune them during cold (ice fishing) weather.
NOTE 2: Low speed screw,the one on the left.
NOTE 3: High speed on the right.
Good luck ice fishing! Regards, Joe
Dec 31, 2009 | Sport & Outdoor - Others
I lost the gas cap from my Jiffy model 30 ice auger. The cap must be a vented cap. John It's an older model 30, from the 1980's
Dec 27, 2009 | Sport & Outdoor - Others
The ice wheel not turning
If your model is the JSD2789GES let me know as I have the service manual 118 pages...Sea Breeze
Jun 21, 2009 | Jenn-Air JSD2789GES Side by Side...
Ardis Ice Auger
I pick up a power head from the junk yard this past weekend. The unit was made by Feldmann Mfg. and engineering. I believe this is the same company that manufactures Jiffy ice augers. I paid $3 for it. It looks like it is from the 50's or 60's. It was complete except for the auger. The motor was froze from sitting, but after disasembling, cleaning, cutting new gasket, freeing the rings and numerous other problems I got it running. I found augers in the Northern hydraulics catalog in sizes from 3" to 12". They are for earth and the 8" was $139.99. You would need to contact them for the shaft size to see if it will fit in the power head you have.
Mar 30, 2009 | Tanaka TIA-350s Post Hole Digger -...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
