Question about Gaggia 74845 Platinum vision coffee maker Coffee Maker
Gaggia Platinum Vision no power
Hi, please if anyone can help this will be much appreciated. History 2nd hand machine, made 15 or so cups of coffee (321 total). Left in standby mode overnight. Screen on, clock on front frozen, touchscreen unresponsive. Turned off. Problem Machine will not power up. No LCD screen backlight, no mechanical noises. Tried new power cable fuse and unplugging for 1 hour. Possibilities from reading up: Dead Mainboard Dead PSU/Power switch Microswitches blocked Requires Reset. I am interested in finding out if there are indeed any Reset switches hiding inside. I have heard that on other Gaggia models the boiler can misbehave and requires 2 reset switches to be pressed before the unit will power up. I downloaded the service manual and can seem to find any on the platinum range though. Any ideas? Would rather DIY than send in for service if there is any option. Cheers Chris
  • Gaggia Expert
  • 109 Answers
You are correct it could be any of the possibilities you have mention.
It is worth checking the two thermal cutouts on top of the boiler.
These can be accessed by removing the top cover only.
If you press the center of the resets and you hear a click you have found the fault
Posted on Jan 26, 2013
Testimonial: "You're spot on! It was the two thermal cut outs which satisfyingly popped back when i pushed them in. I haven't left on again, preferring to turn off after use once a day. So problems every since. Thanks Chris"
2 Suggested Answers
SOURCE: Looking for an english manual for Gaggia Platinum
Hi
I have the original manual (a bit marked) but a better solution is to download the manual for the Swing Model from http://nettopdf.info/download.html?dl=aHR0cDovL3d3dy5jaGV6YmV0dGF5LmNvbS9pbWFnZXMvZ2FnZ2lhL2dhZ2dpYSUyMHBsYXRpbnVtJTIwc3dpbmcucGRm&t=pdf&name=Gaggia%20Platinum%20Swing%20Operation
The only difference is the manual, instead of electrical mechanism that moves the cup(s) up and down.
Cheers
Liz
Posted on Oct 22, 2010
Coffee coming one side only of spout
There are two ways to overcome this uneven drip of coffee into the cup.
1- Make sure the machine is placed on a level counter top. The coffee drips as a gravity flow. Machine placed on a tilted surface will allow coffee flow more on the tilted side.
2- It appears the coffee faucet outlet has not been cleaned/flushed with any coffee cleaners or descaling solution. Clean the coffee outlet as following:
* Prepare two or four cups of Baking soda solution.Fill the Baking soda in water tank and make few espresso, using the preground cycle.
** Then use two to 4 cups of descaling solution and repeat the process making several espresso.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 14, 2014 | Gaggia 74845 Platinum vision coffee maker...
Gaggia platinum vision
Seems that the valve stuck in wrong position. Try to start cleaning mode.
May 20, 2014 | Coffee Makers & Espresso Machines
What does wrench on screen of gaggia platinum vision indicate
I found a failing power supply board can cause the 'wrench' error code even in standby. The board is available for about $65 online and works in many Saeco models as well.
Jul 18, 2012 | Gaggia 74845 Platinum vision coffee maker...
Gaggia Platinum vision says dispensing failed
I suggest the spanner is telling you there is a fault, so you will need to get it serviced or repaired. It is doubtful that you can do anything.
May 06, 2012 | Gaggia 74845 Platinum vision coffee maker...
Looking for an english manual for Gaggia Platinum Swing Up coffee machine.
Hi
Cheers
Liz
Oct 07, 2010 | Gaggia 90901 Platinum Swing Up Automatic...
NEW GAGGIA PLATINUM VISION GRINDER NOT WORKING ANY WAY TO FIX THIS?
If it's new send it to a service centre.
These grinders are failing and can also damage the power supply board.
Dec 29, 2009 | Gaggia Platinum Vogue 90800 Espresso...
Gaggia platinum vision grinder not working
The grinder is faulty,take the unit to a service agent for repair
Dec 29, 2009 | Gaggia Platinum Swing 2-Cup Coffee Maker
Gaggia 74845 Platinum vision coffee maker Coffee Maker Logo
368 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
