Question about Swann Communications DVR4 ADVANTAGE Video Recorder
RECORD FAULT NO HDD TO WRIT - Swann Communications DVR4 ADVANTAGE Video Recorder
When the dvd/hdd is on it not show any picture on the tv
Do it show its Logo on screen. If it shows the logo, and does not show picture, the fault is with its pick-up lens system. If it do not show the Logo too, the fault is with its main power regulator board [SMPS]. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 26, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Fault A2
Are you SURE it's a fault code, and not the selected AV input? (A1, A2 or A3?
Press the Input Select button on the remote to cycle between AV inputs and Freeview channels
Jun 22, 2014 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Swan dvr wont record
It sounds like a problem that might be an easy fix. Since the system CCA board doesn't see the HDD. Can you view any previously recorded images? How are the connections to the drive? Bad IDE ribbon cable (yes do do fault), power to the HDD and how about the drive? Some of my DVRs require the manufacturer drive, not a simple off the shelf (i.e. Lanex or Verint).
Try that and reply back. :)
May 22, 2013 | Home Security
Record fault no hdd to write
Hello I bought 1 terabyte 2nd hand unit but I cannot use it in our dvr recorder it says that record fault no hdd to write what does it mean . thanks
Mar 08, 2012 | Signet Home Security
Can not acess menu to HDD recordings?
I am not familiar with your model of recorder, but on all that I am, this has been due to a HDD fault. You might need to try and reformat the Disk, or replace the Disk.
Jul 17, 2010 | Toshiba DVR3 DVD Recorder/VCR
Fault code ER 7071 on Toshiba HDD drive model
TENGO UN TOSHIBA DVD RECORDER Y EN LA PANTALLA TIENE UN ERROR ER7071, COMO PUEDO ARREGLARLO?
Oct 04, 2009 | Toshiba RD-XS32 DVD Recorder
Sony dvd recorder as hdd error
try replacing the red sata cable which runs from the HDD under the DVD drive to the main board on the right-hand side. these are a common problem on these models, there cheap and unreliable. you can purchase a better quality cable from a computer store for little money. HDD ERROR is'nt necessery an HDD fault as i found out with my rdr-hx525. if however the HDD is faulty and you buy a replacement, once installed you will need to pair the new HDD with the unit by entering the service mode by unplugging the AC then while holding down open/close and play together then re-insert the AC lead while still holding open/close and play and wait until you see an "S" in the display then let go and the service mode will appear on the tv screen. go to no.9 HDD mode, press enter then go to no.3 Write ID then it will say "execute write ID?" yes and press enter and then it will say "writing HDD serial ID.... OK" once this is done, exit the service mode by keeping your finger on the power button for approx 10secs. your DVD recorder should now recognise the new HDD. if you don't follow this process, you will still have an HDD error message as your DVD recorder will have your old HDD installed and won't recognise your new one. given the amount of time since you posted this fault, you may still have the unit in question in which case i hope this solution is helpful, or for anyone else with the same problem.
Nov 11, 2008 | Sony Televison & Video
Hdd set to master
my dvr4-alert does not record no hdd
Jul 23, 2008 | Computers & Internet
Swann Communications DVR4 ADVANTAGE Video Recorder Logo
67 people viewed this question
Top Swann Communications Televison & Video Experts
Electro Med Services...
Jack Frost
Lawrence Oravetz
Are you a Swann Communications Televison and Video Expert? Answer questions, earn points and help others
