Question about HP Deskjet 1050A All-In-One Printer
Deskjet 1050 won't print in color anymore
Hi my HP deskjet 1050 won't print in colour. I have made sure greyscale is off and black ink only is off, but still won't print my color pictures. I have never had this problem before. I just started the other day??? Help please?
wayneard
  • 1901 Answers
SOURCE: hp deskjet 3845 won't print in color
When you click on "Print" and the window comes up, click on "Preferences".
Click on the "Color" tab. There should be an option to print in color or grayscale. Select "Color".
Posted on Oct 18, 2008
SOURCE: HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Posted on Oct 22, 2008
  • 21 Answers
SOURCE: HP Deskjet 54280 won't print
Try cleaning the print heads. You can find more troubleshooting info in the manual:
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Posted on Jul 06, 2009
  • 263 Answers
SOURCE: HP deskjet 3420 won't print in black.
It's probably because the colour cartridge has run out, it needs a colour cartridge aswell to print black.
Posted on Aug 04, 2009
SOURCE: HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
Posted on May 06, 2010
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
How to make the HP Deskjet 3054 Print in only black
Select 'Print' from your software package and then 'Preferences'. Select the 'Color' tab, click on the 'Print in Greyscale' box and select the 'Black Cartridge' box..
Jul 13, 2011 | HP Officejet 5610 All-In-One InkJet...
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
Cannot get to print in color. everything is black
Print out a test print to see what comes out. If the printer is printing the colour blocks then the printer should be OK. If not then check the colour inks to make sure they are OK. Then run a full cleaning cycle and reprint the test sheet. Keep doing this until the inks are printing OK then run an alignment test and adjust as necessary. Next check the settings of the print driver to make sure that you have not defaulted to Black & White or Greyscale printing only. Also check the printer to make sure that the setup is OK and no defaults to Black & White / Greyscale printing have been set. If all this is OK then the most likely culprits will be the interface lead to the PC / Mac. Check that this is inserted and secured correctly at each end and is not damaged. If this is OK then uninstall the printer driver and download and install the latest printer driver from HP support at the following link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=61236&lc=en&cc=uk&dlc=en&lang=en&cc=uk
Simply choose your operating system to proceed.
Once installed reboot the PC / Mac and all should be OK.
Oct 06, 2009 | HP DeskJet 932c InkJet Printer
Printer is only printing grayscale, need color, hp deskjet 6340
This is either because: 1. You only have black ink remaining and your tri-colour cartridge is empty or 2. In the printer driver settings you have selected either: Print Grey scale or Use black only.
I beleive your problem might be the last option.
To fix it :
1. Go to the printer driver (in vista go to: Start, Control panel, Printers, right click on your printer and select "printing preferences"). Now you are inside the printer driver. 2. go to the "color" tab. 3. Tehre you'll see if you have selected wither "Print in grey scale" and/or "Black only". 4. To ensure you get color again, de-select the"Print in grey scale" option.
Cheers, Ed
Oct 04, 2009 | HP Deskjet 6940 InkJet Printer
No Colour - everything in greyscale
just go to printing preference set to color and not to grayscale
Apr 20, 2008 | HP Deskjet 2360 InkJet Printer
Print black & white?
Your printer will keep using the color cartridges to keep the printing head working even if you don't print in color. If you need to print only in greyscale, buy a cheap HP printer (Printer only, not a PSC) and remove the color cartridge.
Apr 14, 2008 | Brother DCP 115C All-In-One InkJet Printer
Colour???
HP Deskjet 450 and HP Color Inkjet cp1160 and cp1700 Series Printers - How to Print with Black Ink Only Follow the instructions below to print with black ink only.
NOTE: HP Deskjet printers use all the primary colors, Cyan, Magenta, and Yellow, to create shades of gray when Print in Grayscale is selected in the printer driver and the Black only option is not available or not selected.
  1. Click Start , Settings , and then Printers . In Microsoft® Windows XP, click Start and then Printers and Faxes .
  2. Right-click the printer icon and in Windows 95/98/Me, select Properties . In Windows NT 4.0, select Document Defaults . In Windows 2000/XP, select Printing Preferences .
  3. Select the Color tab.
  4. Select Print in Grayscale .
  5. Select Black only .
    NOTE: If the Black only option is not available, download the latest printer driver from the HP Web site. Click here to go to the HP Support and Drivers page.
  6. Click OK to save the changes and close the window.
  7. Print the desired document or graphic.
Oct 25, 2007 | HP DeskJet 450Ci InkJet Printer
HP Deskjet 1050A All-In-One Printer Logo
185 people viewed this question
Seeker5211
Seeker5211
