Question about Troy Garden
Does the transmission on a pony lawnmower need oil
Makes a lot of noise when driveing on the road-- I must go about a mile to my grandsons house to cut
    Sergeant:
  • 322 Answers
It will contain some form of lubricant whether it is oil or grease. It will depend on the transmission manufacturer to know which one. If it is oil it may be a special type
Posted on Jan 23, 2013
Turbo 400 transmission is making a loud metal to metal noise when shifting from drive to reverse or park to reverse.
could be internal piston housing failure for the bands
pull the pan and see what metal is in the pan
there is an aluminium housing that breaks away from the transmission body proper and is replaceable
Jun 12, 2017 | Cars & Trucks
I have a 02' chevy cavilar. This morning ,i left the house and didnt get about a mile down the road and the oil light flickered on and off a few times . So i checked the oil and it was full.
if it didn`t make any ticking noise and you say oil level is full then probably the oil pressure switch is the problem and needs replacing. however it wouldn`t hurt to have the oil pressure checked.
Aug 14, 2014 | Cars & Trucks
I have a 2002 ford escape and we just has to replace the transmission because it was stalling and before we had replaced it it had been making weird noises while driving. So after we changed the...
Look at the CV joints on the axels. See if the rubber boots are torn letting road dirt in to mix with the grease. If it'd too bad the joint will wear prematurely. If there are a lot of miles on the car then the joints may be just worn out.
Jun 05, 2014 | Cars & Trucks
2003 Electra Glide Classic. Very whiney in 4th gear. After several miles it was also in 5th gear. Now whining in almost all gears after 1000 miles. Seems to be getting worse. Lube on check stick seems...
Drain the oil and refill with 18 ounces of fresh oil mixed with 6 ounces of Lucas gear lube and see if that helps. If a transmission is whining, not a lot you can do except rebuild it. Are you sure it's the transmission and not the final drive belt. If the final drive belt is loose, it will rise up and rub on the bottom of the inner primary when you let off on the gas and make a whining noise.
Steve
Aug 09, 2011 | Harley Davidson FLHTC Electra Glide...
I have a GMC 2003 Envoy, each time i drive it sounds like im speeding but im going really slow , i need to change the oil could this affect that and what do i do about the sound
Difficult to know what sounds like speeding: engine, road noise, what ?
If the oil change were to help, you have bad, bad engine problems. I suspect you may have a wheel bearing that may have failed. This makes a lot of road noise, alters with vehicle speed and NOT engine speed (drop to idle, noise the same).
There is a possibility of transmission slipping. this lets your engine speed up, but not actually move the car.
There is a third common issue and that is FAN. When your fan clutch fails, is locks up a normally free spinning (somewhat) fan, as if the vehicle needed max cooling... This noise follows engine speed, the vehicle seems to go just fine, but huge noise.... This sometimes is called Jeep fan noise, as many of those used to have direct drive fans.... If this is your case, the fan clutch gets replaced, not huge $, but more than it should be.
Nov 27, 2010 | 2003 GMC Envoy
What mileage or duration should I change the transmission oil of my 1999 Honda accord (HONDA ACCORD 1999)
My Accord V6 '99 has over 215,000. You can use synthetic transmission oil if its zr1 compatible. I change mine every 60,000 or so. Its 3 qts for the v6. The nissan maximas are the ones that have transmissions that generally dont last past 120,000 miles. Why do you still see many 98 and 99 accords still on the road Carlos?
If yours went at 70,000 than you need to buy a haynes manual and keep up with the maintenance on your car. By the way. Honda Accords are notorious for running fine after 200,000 miles. The parts are easy access and if you use a cheap obd2 scanner you can zero in on any problem with the car.
Jul 30, 2010 | 1999 Honda Accord
My 2006 jeep wrangler was making a noise like a belt squeeling drove about 5 miles noise stopped engine light appeared and oil pressure went to 0 (Jeep only has 38,000 miles)I imediatly turned engine off i...
have truck scanned for code can be anything oil pump timing chain etc also check warranty before doing any work most drive trains 5yrs- 100,000 miles
Oct 07, 2009 | 2006 Jeep Wrangler
Ticking noise, grinding noise when turning, front wheel looks off
For the occasionally turning sound:
Sounds to me like you may want to check your CV boots for cracks. If water and other debris has got up into the boot then it could have damaged your cv joint which is a swivel joint to allow turning on front wheel cars. The boot is right at the point where your axle meets the wheel assembly.
The second problem with the transmission: with that kind of miles on the car, you may want to change the transmission fluid and filter and then add a container of TransX, used for older transmissions. Then see what happens. The TransX additive helps with seals and such... or you could just add the TransX to your transmission while its warm , drive it about 100 miles and hopefully see the effects.
Feb 15, 2009 | 1998 Toyota Camry
Garden Logo
57 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
