Question about Ruud Central System Air Conditioner
Wiring a retrofit soft start blower into a Ruud 5T/100k gas pack
I need help wiring a new soft-start motor/blower into my gas pack. I have two black wires from the old belt-drive motor but the wiring schematic shows three, a black, orange and red. I hooked these two wires into the Low and Medium terminals on the new motor and got some bad smoke. I'm using the wiring drawing no. 90-23596-01 Rev. 4.
  • jrussell910 Jan 28, 2009
    I found Mr Mark's answer to be 100% correct. My confusion was trying to wire for a multispeed motor according to the wiring diagram when in fact, my system is a single speed. Thanks again.
    President:
  • 1,214 Answers
Chances are, you've smoked the motor. You basically put 120 volts across the speed windings of the motor when you did this.
What you need to do is, with the new motor, you will have neutral, and speed 1, speed 2, speed 3, etc. Hook one of the original black wires to neutral (it would be best to trace which of the two black wires is connected to neutral, and connect this one.).
Black on the new motor is probably High speed, red is probably low, orange is medium speed. Hook the remaining black wire to one of these, and no more than one of these, or you will smoke the motor again.
Attach a wire cap and/or electrical tape to the remaining wires to insulate them from contacting anything else.
Posted on Jan 27, 2009
  • Mark Egan Jan 28, 2009
    Thanks JR!
    I guess 30+ years in the business, plus having taught Jr College classes in HVAC have come in to use.
WIRING DIAGRAM FOR RUUD URGG-07E37JKR
Just go to the following web address. Hope this helps!
https://www.google.com/search?q=Ruud+model+URGG-07E37JKR+wiring+diagram&rlz=1C1SKPL_enUS
Jan 17, 2015 | Ruud Central System Air Conditioner
Replacing motor on my ruud furance
you should have a wiring diagram on the top of the motor to tell you what each wire does. compare both motors and see where the wiring goes.
Nov 08, 2014 | Heating & Cooling
Need to wire furnace blower
Gas valve should only have a couple of wires...24 Volt & common. the blower will use one speed on a gas furnace & a common. If you have AC or a fan switch on your thermostat, then the high speed will also be connected on the blower.
Dec 16, 2013 | Ruud Rheem Furnace Blower Motor...
I have a RUUD gas pack unit.....when you turn on the heat, the blower does not blow any air out of the vents while on "auto". If you put it on "on" it blows cold air out of the vents. What is wrong?
Sounds like the thermostat is hooked up wrong. If the ac doesnt work right its in the thermostat programming or the wiring. Hope this helps good luck
Jan 13, 2013 | Ruud UAMB Air Conditioner
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
Ruud achiever 10 inside blower motor burning
Check fan cage to make sure it turns freely. Check voltage to IFM make sure it is correct for the application. Make sure the motor turns the fan cage in the correct direction. IFM will have high and low speed make sure when you change from fan on to auto that the motor changes speed. If you have an amp draw meter check to see when running the motor pulls the amp load it is rated for. Recheck all wiring.
Feb 29, 2012 | Ruud Matching Split Air Conditioner
Fan on outside heat pump wouldn't spin put in new cap and started working when got off work it wasn't spinning again
I have a ruud gas pack, the blower fan wont come on. If we go out there we can spin it and she will run, but when the time shut off, so does the fan.. and it wont restart
Jan 28, 2010 | Ruud UBHC Air Conditioner
I have a tempstar gas pack,when I cut the heat on the heat fires up, but the blower doesn't come on. I changed out the contactor and the capacitor,and had the blower moter checked and it is fine. I've been...
Does your fan work in auto. If not you may have a wiring problem. Be glad to talk to you and help. Call me at 251-540-2730 and I will give you a hand. Rus
Nov 28, 2009 | Ruud Central System Air Conditioner
RUUD model URGG-10E31JKR GASS PACK purge fan and main blower
if the purge fan wont start on its own see if there is a capactor attached. if not replace it. more than likely you cannot lube the bearings in your blower motor. the new fans are not serviceable.
Oct 29, 2008 | Ruud Heating & Cooling
Ruud Central System Air Conditioner Logo
256 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
