Question about Sony DSR-1800 DV/Mini DV VCR
How to remove ERROR 39-000 for VDCAM - Sony DSR-1800 DV/Mini DV VCR
  • 917 Answers
This error: Detected an abnormality of tape top/end sensor LED.
could be dirty and needs cleaning, or could be something else.
Posted on Mar 17, 2016
2000 PORSCHE BOXSTER S PASSENGER SIDE WINDOW MOTOR STAYS ON AND KILLS THE BATTERY> I also felt the outside of the car above the wheel and it was really hot. car has 39,000 only
sticky drinks can get into the switches and glue up the contacts. Spray a plastic friendly contact cleaner on the switch, let it dry and try again.
Jul 03, 2018 | Porsche Cars & Trucks
What would the answer be to the problem 39,000 rounded to the nearest thousand
To round a number, we first have to find the column in question. In this question, we need the thousands column, which has a 9 in it. Next, we go to the column immediately to the right. If the number is 4 or less, we don't add one to the thousands column and set all the numbers to the right to zero. If the number is 5 or more, we add one to the thousands column and set all the numbers to the right to zero.
In this case, the number in the column immediately to the right is a 0, so we don't have to add 1 to the thousands column, and rounded to the nearest thousand, we get 39,000.
Good luck,
Paul
Apr 18, 2015 | Office Equipment & Supplies
1986 Ford Ranger w/39,000 actual miles stalls when going around corners, changing lanes but normally restarts immediately. Otherwise runs great, but wouldn't restart yesterday after sitting for a
at that year, it could have moisture in the line or fuel filter. back then fuel filters where small and see thru usually in the engine compartment.
Jul 22, 2012 | Ford Cars & Trucks
The cooling fan on my 2001 Mustang runs constantly. Even when the engine is cold. The temperature gauge reads normal. The engine has 39,000 miles. What is the problem?
low engine coolant ,coolant temp. switch for the fans,fan relay shorted closed.and possibly a computer.check for codes,coolant level in radiator when cold,remove relay for fan and see if the fan stops. check to see if the ac is on or if the heater ac switch is in defrost position. ac will be on and coolant fan is commanded on also.i hope this will help.
Oct 27, 2009 | 1995 Ford Taurus
Dies at idle in gear
idle air control valve Check idle air control valve on throttle body. Mine had similer problems. A quick fix to get you going should be just unplug and remove spray w/ cleaner to get carbon off spring and cone shaft, reinstall. remember, this is just temporary. If cleaning helped, buy a new one soon. JMO
May 24, 2009 | 1988 Buick LeSabre
Sony DSR-1800 DV/Mini DV VCR Logo
222 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
