Question about Ovens
Actually on Sunday when I used it again, when I shut if of the control panel gave off some sparks and we have not used it since - repair man coming today.
  • John van Veen Jan 22, 2013
    Because of the extremely poor english I suspect this is a scam
  • Charlie Lapinski Jan 22, 2013
    it is not. what is your language you speak any way
    Sergeant:
    Champion:
  • 249 Answers
What did it started then I might can help you right now before the repair man comes out to your place it might be fixed already before he gets there
Posted on Jan 22, 2013
My Kenmore Electric Range model 790.9661 seems to have a control board problem. Before replacing the $200 part, just wanted to make sure it was the problem. The clock works, but the oven temperature side...
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
Jun 11, 2011 | Kenmore Ovens
Only some of the keys on the keypad of my oven work. I have replaced the control board (computer board), but they keys still don't work. What specific part do I need to replace?
Hello, Thank You for using FixYa. I will be helping you today.You didnt have to change the computer you need to replace the control panel. The control panel is the whole front piece which has the touch membrane on it. This is common on these units.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag MEW6530DDS Stainless Steel Electric...
Hello and thanks in advance for any help!\r\n I have an Electrolux Wall oven model# E30EW75ESS that has seemingy lost its mind, or temp control at least. When I spoke with Elux they told me that the front...
Call Electrolux service and not a private service man. These appliances are sophisticated and many require proper factory training to service. Most likely there is some type of latch or a retaining key-screw that is not clearly visible to release the glass cover. Actually the cover is most likely ceramic and if so is expensive to replace if it gets broken. These can be delicate to handle.
Apr 02, 2017 | Electrolux 30" Built-In Single Electric...
The oven will not heat. I used it on sunday and notice it took a long time to bake. When I went to use it monday night it would not heat at all. Can you tell me how old the range is? We moved in in...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 09, 2010 | Ovens
Oven won't turn off
I SOUNDS LIKE THE SELECTOR SWITCH INSIDE HAS STUCK ONE OF THE TABS TOGETHER. THEY ARE A SMALL ROW OF BRASS FINGERS THAT CONNECT WHEN THE KNOB IS TURNED..
Mar 08, 2010 | Ovens
Kenmore stove oven does not shut off
Wow, this post is going to be extremely late. Actually, I was able to get a new control unit for my Kenmore gas range from Sears Parts Dirext for $156.06. That includes shipping and tax. The burners work without it. We just cannot use the oven until the new board comes in. It's very easy to replace. Remove the panel screws on the back (just the top) and you have access to unplug the unit and remove the 4 screws holding the assembly in.
Jun 05, 2009 | Kenmore Ovens
Maytag wall oven Model # MEW6530DDS control panel failing
HI, unfortunately, it is not just dirt, this is a faulty touch pad that is combined with the control board. most touch pads are separate parts that are clipped in front of the circuit board but, in this case, the touch pad and control board are one piece. You will need to replace the entire control board in this case. the touch pad is faulty.
Jun 03, 2009 | Maytag 30" Built-In Single Electric Wall...
Kenmore Oven will not shut off
ok, due to the age of this unit, the repair will be costly. the issue here is a damaged control board. the control will run a little over 200 dollars and that without the labor charge. standard labor charges will vary form 50 to 75 dollars an hour and , there is a 2 hour standard start charge automatically leaved once the repair man arrives. this will bring your repair bill to the 300 dollar mark. you may be able to find a cheap repairman but, the price will be hovering in the 230 to 290 range a t best.
It would be more cost affective to purchase a new unit with a new warranty as well.
May 26, 2009 | Kenmore Ovens
I have a Kenmore Elite slide in electric range and the oven will not preheat to temperature (even after 40 min.) The repair man says I need a new control panel that will cost me almost 500 bucks...Any...
Hi. the electronic oven control board actually costs 198.00 but, the labor charges will inflate the cost because of the need to disassemble and add new wire harnesses. On most models, this relay is separate from the actual control board and it is usually linked via, wires. I would check around to see if you could get a second and maybe a third opinion. In my experience, you should just be able to replace the temp sensor or relay and that should fix the issue. Normally, if the control board is experiencing any issues, you will see a error code of some sort. I would defiantly get a second or third opinion before allowing the service tech to do the repair. that repair cost seems to be highly inflated in my view.
Please rate and god bless:)
Apr 03, 2009 | Ovens
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
