Question about Goodman GMS90703BXA Heater
Goodman Furnace i have a new goodman gas furnace and i get the wind chill effect, how do i adjust this?
  • elliselect Jan 31, 2009
    wind chill effect is when the blower goes on the air feels cool rather than warm. I was wondering how to set the blower to kick in alittle later. Thanks
  • Don Berry May 11, 2010
    What is a "wind chill effect"? I would like to help if I can.
    Novelist:
    Champion:
  • 230 Answers
Elliselect,Thanks for the information about wind chill effect! Look on the circuit board for a set of dip switches(Usually a small red block containing white switches about 3/8 of an inch long) or a jumper. (The jumper looks like the one you commonly find on the back of a hard drive). Either one is usually clearly marked on the board in numbers representing seconds of time. You can set the blower OFF delay for any one of these options. For more complete instructions please read your user manual. If you do not have a manual you might be able to find one on the goodman.mfg.com website. Best of luck!
Posted on Feb 03, 2009
  • 137 Answers
Could be that the fan on you new furnace is more powerful than your old one and is forcefully blowing the cold duct air out causing a temporary chill or it could be that you need to adjust the fan delay.
I'm not familar with this unit so I wouldn't have aclue on how to do this or even if you can.
Posted on Jan 29, 2009
My goodman GMVC95 furnace circuit board is flashing On 6 I replaced the flame sensor but it's still flashing. Does it have to be manually reset?
Alright, have you checked the low voltage fuse on the circuit board in the blower compartment? Make sure you check the roll out switches as well. If all of these issue appear to be fine then you may have a bad circuit board. There has been a bad batch of circuit boards going around many of the popular furnace brands this winter. Trane Gas Furnaces and Goodman Gas Furnaces have been effected. We sell both brands and have had to replace many circuit boards on new furnaces. Trane Gas Furnaces Installed Goodman Gas Furnace Installation Gaithersburg
Feb 03, 2018 | Goodman Heating & Cooling
Need wiring schematics for goodman manufacture model # A60-20REV/C gas furnace
Here is a diagram containing the Wiring Schematics for Goodman Gas Furnace
Jun 27, 2008 | Goodman Heating & Cooling
Goodman dependable 92 light for 6 sec out reignights after 45 sec it does it about 4 times then nothing i turn the pwr on and of thought might be the thermocoupler or flm sensors storm knocked out air
be carefull
only found these
DF]Service Instructions - HVACPartsShop
www.hvacpartsshop.com/manuals/gmph050-3.pdf
Goodman Dependable 92 Furnace Manual - PDF documents
www.do-cu-cu.com/Goodman-Dependable-92-Furnace-Manual.pdf Goodman dependable 92 furnace manual shop for goodman gas furnace repair parts for model gmpn1004 at sears partsdirect. find parts, manuals & diagrams ...
Oct 10, 2016 | Goodman Heating & Cooling
My gas pack won't light
First, the thermostat white wire is the wire that initiates the furnace to start. When you select heat on your thermostat the tech should get a 24-28 volts between the white wire and common on the thermostat wire in the furnace. If you do not get the required voltage, there is a break in the wire from the furnace to the thermostat that needs to be tracked down and eliminated.
Feb 27, 2014 | Goodman Manufacturing Goodman...
New goodman 80% gas furnace leaking condesation down exhaust vent
it could be condensation. or poor seal at roof. probably the seal at roof. also check the larger copper line is it sealed good? if any spot is not this will cause leaking when in cooling mode. maybe dripping from line onto vent.
Jan 28, 2014 | Goodman Manufacturing Goodman 60,000 btu...
Furnace will not light,on Goodman Furnace model#GME80704BX
Is the gas turned on or does it come on but goes off quickly?
Oct 06, 2012 | Cozy Enclosed Front Console Heater 70,000...
Goodman furnace model # GMNT100-4B On vacation neighbor checked house house filled with gas. He shut off main and furnace. Came home turned on gas to everything except furnace. All good. Furnace will not...
from my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
May 14, 2010 | Goodman GMS90703BXA Heater
Goodman furnace model # GMNT100-4B On vacation, neighbor checked house, house filled with gas. He shut off main and furnace. came home turned on gas to everything except furnace. All good. Furnace will...
Solid red typically means bad controller. Try unplugging the furnace, wait about 30 secs, then plug it back in. The possibility that the controller was sending voltage to the valve even when there was no flame is a bad sign. If the controller starts the furnace, watch it very closely and see what it does. If the solid light comes back on, it's time for a new board.
Mar 24, 2010 | Goodman GMS90703BXA Heater
Goodman gas furnace power vent motor and housing replacement
You need to type GOODMAN GAS APPLIANCES into you browser to find you local servicecenter. I must tell you that Goodman only sells to authorized service companies in my experience. So you become EgKraft Company.
Nov 07, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
402 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
