Question about Enermax Liberty ELT400AWT 400W Power Supply
SCK crashed...VALUE? The SCK (green component) is crashed and i can't see no more the value. thanks
  • Bernard Jan 26, 2013
    i've tried to put some photos but i don't see...SCK is a NTC (thermister) There is only one ntc near the biggest cap. If one day you clean your enermax 400, you can see it and note the rating for me.(something like 052, 053 etc.) thanks Bernard
My 45inch lcd screen was struck by lightning and i found that the SCK 2R58 was cracked on the power supply. Can i use the value of 2R56?
If it appears identical what do you have to lose? Might just do the trick! If you have a tester you might want to use it since those ceramic caps are amazingly resilient. Might have a piece off of it and its value might not have changed.
Apr 03, 2017 | Televison & Video
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
Resetting waste in absorber code for IP4900
You ink absorber is full
1. Download canon service mode tools v3400 from the net.
2. Set the printer in Service Mode: - power OFF the printer bu Power button. Dont disconnect power cable
- connect the printer by USB cable to the PC.
- press and hold Resume button (red triangle in the red circle) and press Power button
- hold both buttons until power on indicator will light then release resume button (dont release Power button) and press Resume button 5 times
- release all buttons - the printer will blink few times with green light and will then light green constantly. You have put the printer in Service Mode now and you can now run the Service Tool. (If the printer is still blinking by green - you have some other errors in printer and you have to fix them first, because the Service Tool will not work if the printer is not put in service mode - green light is constant)
3. Run the Servicetools V3400.exe program.
4. Select the connected USB port number from USB PORT
5. In the Ink Absorber Counter section of the Service Tool, select MAIN from the Absorber pull-down menu.
6. From the Counter Value(%) pull-down menu, select the value (in 10% increments) which is the closest to the actual counter value confirmed before replacement of the logic board, and click SET.
Print EEPROM information to confirm that the value is properly set to the EEPROM.
Jan 18, 2013 | Canon PIXMA Office Equipment & Supplies
Mobitronic mps50A components
Hello Brenden,
Did you find the value for r13 on the Mobitronics MPS-50A power supply?
I am looking for that value also.
I
cannot locate where R13 is on the board so if you give me some direction I may be able to help.
I do not have a diagram just a power supply that I am trying to repair also.
Cheers
Stewart
Sydney
Australia
Nov 13, 2011 | Washing Machines
What is computer programing?
> what is computer pro gaming?
> what is computer programming?
The latter is the writing of instructions that a computer can follow, to solve a problem,
e.g.,
set the variable 'X' to the value '3';
set the variable 'Y' to the value '7';
calculate the value of X divided by Y, and store into 'Z';
display the value of 'Z', to 7 decimal-places;
stop running this program.
Jun 15, 2011 | Computers & Internet
Iam trying to find the value of a capacitor which is damaged on the GPU board for the following product. Nvidia 9800GT 1GB graphics card. The component is situated at the top right hand side of the GPU...
1) Whatever company that made that Nvidia 9800GT graphics card, isn't going to produce a schematic for the general public.
(EVGA, VisionTek, Galaxy, Sparkle, BFG, etc.)
They paid big bucks to Nvidia for the GPU, the schematics, and all licensing fees.
2) If you indicate that you believe most of the capacitors, (Radial Aluminum Electrolytic Capacitors), are of the same values, capacitance, and voltage, then remove another one of them, and test the capacitance.
Multimeter set to OHM's. An economical unit can be purchased for around $5 to $12.
Most auto parts stores carry them, as well as a multitude of other stores.
3) The Radial Aluminum Electrolytic Capacitors you are looking at, have the values printed on them. They are just in the capacitor manufacturer's code.
http://www.hardwaresecrets.com/article/595
Page 2 of the article starts with the identification of the markings.
Page 3 dealing with capacitors manufactured in Japan.
Page 4 deals with capacitors manufactured in China, and Taiwan.
Regards,
joecoolvette
May 30, 2011 | Computers & Internet
I got an amp from my buddy who was going to throw it out cause he broke the 0.2 to 6 volt dial. He discarded the old broken part out of fustration. Anyone know the part number for said missing piece? ...
so we know a few things...
1. you guys are inside the amp removing board soldered components.
could be a good thing since what you can do to sleuth a solution is this...
a. know that the 'knob' is actually a variable-resistor that ranges resistance from a start value to a max value.
b. you can ascertain the range by opening a similar amp and testing the resistance range as you rotate the knob.
c. pick the mid value resistance and buy a cheap resistor of that value, then just solder the resistor in place of the two knob-control bread board connectors.
voila.
May 07, 2011 | Crunch Maxxsonics P1500.1 Car Amp
Llomy id is blocked help me to unlock
Checking virtual IP servers...
[VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED]
[VIP Raw] Connecting to Virtual IP server 98.136.48.32... [FAILED]
 ***  'COMPONENT_TYPE_WININET' value: '12029' ***
[VIP Raw] Resolving host name vcs2.msg.yahoo.com... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.186.241... [FAILED]
[VIP Raw] Resolving host name 98.136.48.100... [PASSED]
[VIP Raw] Connecting to Virtual IP server 98.136.48.100... [FAILED]
[VIP Raw] Resolving host name 98.136.48.110... [PASSED]
[VIP Raw] Connecting to Virtual IP server 98.136.48.110... [FAILED]
[VIP Raw] Resolving host name 67.195.187.228... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.187.228... [FAILED]
[VIP Raw] Resolving host name 67.195.187.229... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.187.229... [FAILED]
[VIP Raw] FAILED
 ***  'COMPONENT_TYPE_YCP' YCPError: 'YMSG.ColoSelectionFailed' ***
Checking HTTP virtual IP servers...
[VIP Http] Resolving host name httpvcs1.msg.yahoo.com... [PASSED]
[VIP Http] Connecting to HTTP Virtual IP server 98.136.48.229... [FAILED]
[VIP Http] Resolving host name httpvcs2.msg.yahoo.com... [PASSED]
[VIP Http] Connecting to HTTP Virtual IP server 98.139.61.47... [FAILED]
[VIP Http] Resolving host name 216.155.194.137... [PASSED]
[VIP Http] Connecting to HTTP Virtual IP server 216.155.194.137... [FAILED]
[VIP Http] Resolving host name 98.136.112.142... [PASSED]
[VIP Http] Connecting to HTTP Virtual IP server 98.136.112.142... [FAILED]
[VIP Http] FAILED
Apr 19, 2011 | Yahoo Messenger
I have an Acer Aspire 5100. Right now I have error code 0X490 &0X2. How do I fix this problem after my laptop crashed. I can not find my startup disc.
this is a graphic card driver issue
memory hex errors, memory double word logic failure at [ hex value], read [hex value],expecting [hex value]..
hexadecimal, may be a bad memory address,
memory line parity error at [hex value]
without more information i cannot help you
rod
Jan 19, 2009 | Acer Aspire 5500 5570-2609 Laptop
Components value
This Component is red-red-black = 22ohms. Its of the same value as the R515A.
Jul 12, 2007 | Koss KS3102 System
Enermax Liberty ELT400AWT 400W Power Supply Logo
47 people viewed this question
Top Enermax Computers & Internet Experts
David Payne
David Payne
Are you an Enermax Computer and Internet Expert? Answer questions, earn points and help others
