Im trying to upgrade from my western digital 350gb hard drive to western digital 1.0tb i get a message saying no drivers
    Genius:
  • 1,250 Answers
On which os you have tried?
Posted on Jan 22, 2013
Crystal K
  • 3 Answers
SOURCE: jumper switch settings
I have the same thing and here is your solution.
http://www.babooforum.com.br/idealbb/files/152532-Maxtor2.jpg
Worked perfect for me afterwards. :)
Posted on Apr 19, 2009
SOURCE: Notebook does not recognize My Book / Western Digital hard drive
I have solved a similar problem to this. My laptop would not allow me to get to my WD Passport. The driver was fine and no errors were reported - it recognised the drive when I ran the hardware removal utility - I just couldn't see it from any of my windows applications and therefore couldn't get to any data.
The problem was that the passport was being designated as E:\ but my laptop already has a network drive mapped to E:\. When I am in the office the computer connects the network drive to E:/ and so my passport automatically picks the next available letter - F:\. Away from the office, the network drive is still buit shows as "disconnected network drive" and somehow the laptop gets confused into designating both the the passport and the disconnected network drive to the same letter. so the passport is not visible in My Computer.
To fix it I went to My Computer, right clicked on the disconnected network drive and select Disconnect from the options there. And hey presto the passport appeared!
You can see which letter your USB HDD is assigned in the device manager in XP. Right click on the device and go to the Volumes tab - click on Populate and the drive letter should be shown there. If that doesn't match what you see under that letter in My Computer it looks like you have a similar problem & so disconnecting whatever is there in My computer might help.
Posted on Jun 07, 2009
SOURCE: Western Digital External Hard Drive Won't Boot Up
Take it our of the external encasing and plug it in directly to your motherboard. This has worked for me in the past. I just had my second wd external harddrive crash so now I will do the same process all over again.
Posted on Nov 18, 2009
  • 163 Answers
SOURCE: My western digital Passport 320Gb usb drive is not detected
U need to update windows XP , USB drivers will be installed
Posted on Dec 29, 2009
Mattkintosh
SOURCE: Western Digital Hard Drive will no longer mount
HI. So I had this problem twice with the same hard drive. I didn't have the money to replace the hard drive the first time, but this time I did, so my ultimate solution to offer is to purchase a different HD and migrate the data from the current one.
How did I get the drive to turn back on so I could get the data migrated to the new HD? Persistence! I kept disconnecting and reconnecting the drive, making sure to shut the drive down by pressing the blue button on the front until the drive powered down. I disconnected, waited for some time (between ten and 20 minutes) Then I reconnected the FireWire cable first, and the power cable second, waited for it to mount - and eventually...
IT DID!!
Wow am I happy. I'm going to run a series of diagnostics on this one but I'm probably going to retire it. Too bad because 500 gigs is a lot of space to loose, but this being the second occurrence makes parting all the easier. I mean, my entire iTunes library is on this thing!
So, just keep trying - plug the drive into the computer, then connect the power cable and wait for it to come on.
I'm running Mac OS 10.6.4 and an older machine 10.4.11, both of which were able to read this drive before, the 10.6.4 had the problem initially, then both machines had issues. Ultimately the 10.6 machine was successful with a FireWire 400 connection.
I hope this helps!!
Posted on Oct 19, 2010
He llo my 1tb does not regater on my coputer only the wd smart were .before itdid now ican not bring up any of my files and it had over 350gb of info on the damm thing and now it says the premitur is...
From your description it appears that your drive is failing. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed by an experienced tech remotely over the Internet from a boot cd that you download and the best part is they just ask for donations: http://FreeDataRecovery.us
Aug 21, 2011 | Western Digital My Book Essential 1TB...
I bought a new WD Elements 350gb external hard drive and it came with a Memeo software CD. It says to insert CD before starting backup. I do not appear to be able to use this external hard drive as a plug...
This software is not linked with the drive (with this particular drive you only get a trial version anyway). Just remove the software from your PC.
Start > Control Panel > Add or Remove Programs > Remove Memeo/ WD Anywhere Backup.
Once you have done that, you can delete everything on it (assuming you never manually put something on it apart from the backup). If so, back it up onto your PC, another drive or CD.
Jan 25, 2010 | Western Digital Elements powered by WD 320...
Message says disk unreadable when i plug it in my mac
Change the cable and try again.
If the drive is seen in Windows, try the disk utilities to test the drive.
Nov 29, 2009 | Western Digital My Book Essential Edition...
My Western digital divice is mulfunctined as displayed on screen
do you use windows 98? because win 98 cannot support wd 160.
2) the mother board bios may not support this drive, or the interphase of the ext usb drive is faulty. lastly try to remove the raw drive from the casing and use it directly with the pc . i feel it will start working well
Sep 18, 2009 | Western Digital Passport WDXML800UE...
WD External Hard Drive malfunctioned & is not recognized
you can **** in western digital factory with this ugly hard drive
Dec 24, 2008 | Western Digital My Book (WDG1U2500)...
Western Digital Essential My Book
not digitally signed driver... but says continue anyways or block. most people opt for continue anyways.
Oct 10, 2008 | Western Digital My Book Essential Edition...
Western Digital 500gig external drive
it sounds like hard drive data may be corrupted. This could be due to a number of things. A power failure, hardware failure etc.. If the drive will not even let you access it you'll probably have to just format it im afraid.
- John
Jun 23, 2008 | Western Digital 500GB My Book World...
Installation
The hard drive will automatically install you do not need to install a driver. I'm guessing this is a hard drive in addition to the hard drive that vista is running on? If so you probably need to format the hard drive to gain access to it. Click the windows button, and in the search field type compmgmt.msc and hit enter. Click continue when the UAC pops up. Now inside the Computer Management Console find and click on Storage and then Disk Management. On the bottom portion look for your new hard drive. Most likely it will have a black colored stripe and say UNALLOCATED. This will explain how to do the rest Yes that article is for XP but the one in Vista is pretty much the same.
May 16, 2008 | Western Digital Caviar SE16 (WD5000KS)...
Computers & Internet Logo
David Payne
David Payne
