Can you tell me why hot water goes cold - Heating & Cooling
Could probably need more information on the problem....
Posted on Jan 22, 2013
Not letting water in
I would change your setting to COLD WATER and see if the water goes in.
Then I would change the setting and Select HOT. If the Cold water goes in and the HOT does it, then you have an Issue at your Connector with a Blockage inside the Screen from years of use (Normally on the HOT Side)
I would also see if the Water Line has a Blockage (Hose may be K-inked. If it does not, then you may have an issue with your Selector Switch (Newer Machines have more and more issue with the Electronics but you did not tell me what Year/Make/Model your Washing Machine is...
Mar 21, 2015 | Washing Machines
Ls80t hot water goes hot cold hot cold heating is ok
http://waterheatertimer.org/How-to-fix-water-heater.html
What kind of water heater do you have? Boiler, indirect?
What brand and model?
Or is this a HVAC unit?
Gene
Aug 17, 2014 | Water Heaters
Rinnai infinity standing in the shower and it suddenly goes cold for a few seconds no other water been run in the house or it goes cold and goes to a trickle then comes on again. Could the heat ex changer...
We are a bit confused by the device that you are using to heat the Hot water with- Is it an instantaneous HW heater?--
They are pressure sensitive-- Could it be, that your water pressure drops momentarily, (which causes the instantaneous heater to shut down its flame-- and you get a pulse of Cold water.)
If your hot water is a tank-- It is possible that something is cycling your hot water away-- like rinse pulses on the Washing machine)-- or your dishwasher?
Tell us more about the Rinnal Air Conditioners and what they have to do with Hot water and your SHower?
Tell us more-
Mack B
Jan 23, 2011 | Rinnai Heating & Cooling
My Bristan Meridian Show start ok with hot water then after a few minutes the water runs cold. Even if you try and increase the temp it still remains cold. You can switch of the shower and start again...
It sounds like 1 of 2 things to me. I will start wit hot water heater. The first test for the water heater is to have someone run the hot water while you hold the hot and cold pipes and see if the water is coming out of the water heater cold when the shower goes cold. Of the water heater is cold coming out then the problem is in the heater. ether a lower element is bad or the dip tube is broken at the top of the tank. if the hot water heater continues to put out hot water when the shower goes cold then it has to be the mixing valve for the hot and cold mix at the shower and that valve will have to be repaired or replaced. hope this gives you a good start. let me know if I can help further.
Dec 24, 2010 | Home
Electric shower hot and cold
it sounds like the flow is too low and causing the heat chamber to overheat ( or the heat sensor is faulty and thinks it is too hot) is the water too hot before it goes cold?
Mar 18, 2010 | Home
When washing machine goes to rinse cycle, water barely comes in
I am going to guess you run a warm wash, and cold rinse. This sounds like the screen on the cold water inlet is clogged. Shut the water off and remove the hose at the back of the machine. Look in the water inlet and see if the screen is clogged. If so, carefully scrape it as clean as you can. Use a straw and blow into it to help clear it out. Replace the hose and try it. It does not need to be perfectly clean, but at least half way opened will suffice.
Jan 01, 2010 | Kenmore Washing Machines
Hot water comes out cold side for few seconds and gets cold, no hot from hot side, only cold
Make sure that the water pipes for the cold water coming in and the hot water going out are connected to the correct positions on the water heater. If the connections get reversed, the water that is supposed to be hot will be drawn from the bottom of the tank and will not be as hot as it should be. The cold water input goes to the bottom of the tank. The hot water out comes from the top of the tank.
Oct 09, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
TB3 Brewer is brewing weak tea - how do I adjust?
Hello. Yes, however, you would need to adjust the brewing cycle time to make up for the lost bypass water in order to get the same container level. In other words, the cold water part of the brew cycle is separate from the hot water part of the cycle, if you put in less cold water, and want to keep you container filling to its current level, you would need to increase the hot part of the brew cycle to make up for it, other wise it will brew less into your normal container. If you go to:
http://www.bunnomatic.com/
find your unit by model/type, you should be able to get a owners/installation manual, this will tell how to do it, or call the manufacture.
Hope that helps, and thank you.
Dec 22, 2008 | Bunn TB3Q, 29" Trunk, 3 Gallon Tea Brewer
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
