Question about Hagen Exo Terra Snake Cave Size: Medium 9.5" H x 6.5" W x 5.8" D
Is it safe to use an exo terra snake cave in an aquarium as a fish hide?
Are these aquarium safe?
Hi. I purchased a pirate ship for my aquarium and it's been in it for almost a month. I quickly noticed that the white paint began chipping almost immediately.
Doesn't sound like it was made to be put in an aquarium. Because there can be toxic chemicals that will kill fish, it is a good rule to only put things that are labeled as being Aquarium Safe into a fish tank.
I would have removed it as soon as I saw the paint coming off. There's plenty of aquarium decorations out there, look for those if you want something other than a natural look in your aquarium.
May 18, 2017 | Fish
How to move With Fish Aquarium?
First Empty your whole aquarium, than fill it with some papers said to be old papers so that it will be safe from damage.
Move A fish Task
Mar 14, 2013 | Computers & Internet
Is it safe to use an exotic terra snake cave in an aquarium as a fish hide?
I think using a cave marketed for reptiles would be fine. Three things to consider:
  1. Was the cave previously used in a reptile habitat? When I use rocks from outside I usually boil them to kill any bacteria or microbes that may be harmful to the fish. If the cave is not plastic or wood, I would recommend doing the same.
  2. Is the cave painted? Some people are concerned about paint harming their fish. I assume most paint would be fine, but make sure it won't flake off in the water.
  3. Living Plants? I hate to state the obvious, but the plant will die and the fish may or may not have difficulty if they eat the plant.
All in all, I wouldn't worry too much about the cave. Just make sure it's clean and let your fish enjoy it!
Jan 20, 2013 | Fish
What safety issues should I look for in aquarium heaters?
There are some safety precautions that you should take to make sure the heater is safe for use:
  • Since most heaters are made of glass, you should look for cracks. If there are visible cracks, throw the heater away because if water enters the heater it can cause electric shocks to the fish and even to the owner.
  • Make sure that the fish doesn't use the heater has a hiding space because it can get severely burned from the heater. Basically, just create safe hiding places with decorations for you fish so it doesn't have to hide behind the heater.
  • Never take a warm heater out of the water. Make sure you take it out after it has been unplugged for at least 30 minutes.
Sep 05, 2012 | 1topstore Fish
Do fish automatically sleep when the lights are off?
Like any other creature in the world fish need their sleep. When you turn the lights off the fish will start looking for a shelter for them and get some sleep. You can see that if you suddenly point a flashlight toward them the will start swimming in a dazed matter and look for a new hole to hide in.
Aug 02, 2012 | Fish
Can I make my own aquarium decorations?
Making your own aquarium decor is a great DIY project. You can make ornaments for your aquarium outof virtually any substance. I like tomake mine out of Fimo clay or Styrofoam sheets. As long as you cover them with aquarium sealant, they will be safe foryour fish to swim around. You can buysealant at any local pet shop.
May 14, 2012 | Fish
My glass aquarium cracked. How can I fix it?
There are a few steps to take to fix a cracked tank:
  1. 1. b>Move the fish to a backup tank with cleanwater
  2. 2. Wipe the crack with white vinegarto clean the glass and let it dry completely. This will allow the silicone tostick.
  3. 3. Line the crack withaqua-marine safe silicone gel
  4. 4. Let the gel dry completely(usually overnight) before returning the fish to the water
May 13, 2012 | Fish
How long should I leave the lights on in my aquarium?
Theamount of time you should leave your aquarium light on depends on a number of factors. If you don't have plant life, I would saythat about ten hours a day is a safe average. However, not all fish take to light well so it depends on the type offish you have.
May 13, 2012 | Fish
Our aquarium had a leak...so we had to strip all of the old silicon out and replace it with new. However I was unaware that some silicone can be harmful to fish. the ingriedients that were the the silicon...
The silicone most be 100% silicone appropriate for aquarium use. If the sealant tube did not say this on the tube it is not safe for use in aquariums. They sell this type at pet stores that sell fish. Also make sure you use acetone to clean surface before applying sealant.
Sep 29, 2009 | Safe International Aquascape - Black Fish...
Hagen Exo Terra Snake Cave Size: Medium 9.5" H x 6.5" W x 5.8" D Logo
230 people viewed this question
Top Hagen Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a Hagen Pets - Other Expert? Answer questions, earn points and help others
