The display is showing an fuser error 50.2
SOURCE: Fuser Error 50.1 Fuser is hot. What is a fuser?
MAKE SURE THE PRINTER IS OFF AND INPLUGED BEFORE YOU START! The fuser is located in the back of the printer. You should see two blue pads where your index finger and thumb (on both hands) should pinch together then pull the fuser out. Re-seat the fuser back into its original position and wait 20 minutes before turnging Unit back on. If you do not wait 20 mins then the 50 error will appear again even if the problem is fix. Once you wait 20 minutes and it still gives you a 50 error you must replace the fuser. I have a great place to purchase fuser so let me know if you nee contact info!
SOURCE: i have hp colour laserjet cm6040f mfp, that
Probably the 'fuser power supply unit' is bad. RM1-3218-000CN
