Washing machines growls when washing then stops on an uneven load
  • Washing Mach... Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 22, 2013
Dryer is growling when spinning heavy loads.
The bearings may be gone, but I don't know how old your machine is or the brand. If it is over 8 years old, consider replacing it. Maybe get an estimate from a repairman who knows your brand.
Jun 09, 2015 | Dryers
My Maytag Bravos washing machine acted as if unevenly loaded while spinning and then stopped. What do I do now?
check the counter weight balances and is u have an inertial spin balance switch it may be bad
Feb 17, 2015 | Maytag Bravos Top Load Washer
Why does my machines spin cycle works slow
probably because its overloaded or the load is uneven.try rotating drum half way through loading to even the load,it will reduce speed if its not even loaded to stop it destroying its self
Apr 16, 2014 | Simpson Washing Machines
Whirlpool cabrio washing machine doesn't spin
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
Apr 05, 2014 | Whirlpool WTW6400SW Cabrio Washer
My HOTPOINT ULTIMA WASHING MACHINE wt960 is very noisy on the spin cycles...is there a need for oiling or what else can I do..?
It could have an imbalnce in the drum because the load is uneven, or your machine could be uneven on the floor,, try checking for the level of your machine
Apr 17, 2011 | Hotpoint Ultima WF860 Front Load Washer
Water pumping in very slowly and uneven flow
The washer filling so slowly can get very irritating and frustrating..most of the time the fix is very simple. The hoses have a screen in them to catch any dirt that may come in the water and this screen plugs up.
Simply unhook the hoses at the washer and clean the screens.
This tip will explain this in more detail for you..
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
May 05, 2010 | Fisher and Paykel WL37T26D Top Load Washer
When i have an uneven load how can i make the
you should have a pause or stop button, if dial push button in, rearrange the clothes to be more balanced in the washer, then push the pause button again, or if dial push it in......hope this helps.....
Jan 07, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Uneven load
For my washer it means the drain hose is bent/ clogges or the drain filter is clogges
Dec 02, 2008 | LG WM2042 Front Load Washer
NEC Washing Machine when it comes to spin cycle stops and just beeps with the 'OE' light flashing.
Well, what does that mean? Old Engine? Octopus Entering? Oily Electricity? Darn. No clue from that light, is there?
My guess is that it thinks there is an uneven load. Assuming that you've straightened your load, I'd say it must be a bad uneven load sensor. And unfortunately I don't know where that is located. So I guess I'm not much help. Sorry.
Jul 16, 2008 | Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
