Question about ASUS Computers & Internet
What kind of memory card used in asus KBN-VM - ASUS Computers & Internet
  • ASUS Master
  • 3,606 Answers
Hello enter the right mainboard number here:
http://www.asus.com/support
To find info about the mainboard.
Good luck
Posted on Jan 22, 2013
ren3n
  • 8 Answers
SOURCE: VGA CARD for ASUS P5RD1-VM
hi,
Try to visit this site.
http://www.sparkle.com.tw/product.asp?id=70
http://ati.amd.com/products/Radeonhd3800/specs.html
http://usa.asus.com/products.aspx?l1=2&l2=8
Just chose PCI EX depends on your budget.
regards!
Posted on Feb 17, 2009
  • 111 Answers
SOURCE: PCI video card on my P5PE ASUS motherboard
Your motherboard is equipped with an AGP slot, you would want to use this to add a video card, but first you must go into the BIOS and disable the on board video graphics chip so you can utilize an external video card. This will make your pc faster because of the independent processes and memory the card will have on its own, not needing the pc's memory to run, thus taking away from system resources. Take a look at these:
http://www.buy.com/prod/visiontek-radeon-hd-3650-agp-512mb-ddr2-128-bit-directx-10-1-video-card/q/loc/101/211110588.html
http://www.ewiz.com/detail.php?p=EV-A62_512&c=pw
http://3btech.net/sa8xagpatira.html
Listed find the low, medium and high ranges of video cards. I hope this helps.
Posted on Jul 03, 2009
anandg27
  • 1272 Answers
SOURCE: which kind of RAM my motherboard is compatible?
It supports maximum of 2 GB of DDR RAM
DDR here means DDR 1 and not DDR2 or DDR3
Rate it, if it helps.
Posted on Aug 04, 2009
rustysheriff
  • 344 Answers
SOURCE: which graphics card is suitable for asus P5RD1-VM?
Any PCI-E card will do.
Posted on Apr 05, 2010
How much video card memory does the p5pe-vm board supports? cause i have installed the geforce 6600 256 mb , and it only detects 128mb.. and when i run dxdiag , it says there ( approximate memory: 1
Eyaa! Use www.systemrequirementslab.com ant take one random game to check your computer performance, there it will show your computer performances.
Mar 14, 2012 | ASUS P5PE-VM Motherboard
Compatible memory at 2gb capacity and video card for asus p5pe-vm motherboard
Hi, you can download a manual here at asus:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR RAM memory
1 x AGP 8X slot.
Hope this will help you.
Aug 14, 2011 | ASUS P5PE-VM Motherboard
Ram supported by asus motherbord p5p800-vm<green>
Memory should be same as the one that is in the motherboard . Each motherboard support only one type of memory. Search on the internet for the type of motherboard for memory supported with it. If it says other than DDR2/ DDR3 then the motherboard wouldn't support the memory. Do some searching like motherboaed p5p800 and see few websites for specification for the motherboard, check the memory specifically for the details.
Sep 18, 2009 | ASUS P5P800-VM Motherboard
Jul 03, 2009 | ASUS P5PE-VM Motherboard
My ASUS P5SD2-VM Is Having A No Display Problem
If you are using the motherboards built in VGA graphic display, check your bios settings. Open your manual to page 2-22. Read the page.
Make sure you have the bios set to, Primary Graphics Adapter [PCI-E] set to, [IntVGA].
Set the internal VGA to, [Enable]. You will also need to set an amount of your system memory for the VGA to use. It is recommended if you are using Windows Vista that you increase your 1GB of system memory to, 2GB. Or instead you can buy a decent PCI-E video card that will use its own memory instead of your system memory. If you do this you'll need to change the bios settings to, Primary Graphics Adapter [PCI-E].
Also change, Share Memory Size to [Disabled].
If you need the manual for the Asus P5SD2-VM. Click on the link below;
http://support.asus.com/download/download.aspx?modelname=P5SD2-VM&SLanguage=en-us
Click the dropdown menu & click on your operating system. Than click Search. Asus list all drivers, manuals, FAQ's ect.
To view the manual you'll need Adobe Reader. You can download Adobe for free at this link;
http://www.adobe.com/products/reader/
Again, if you do not have any display & your using the built in VGA graphics card try resetting the bios. Doing this will reset the bios back to normal default settings. The bios will auto use the built in VGA. To clear the bios see page 1-22.
Mike
Apr 26, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Specify a suitable board for intel quad core 2.66
Obviously the p5q-vm is a better mobo as it has a faster FSB and supports up to 16G of RAm vs 4G on the p5ql-cm.  If you are looking for a gaming PC then certainly the p5q-vm is the better choice.  With that said, you may also want to consider another video card.  While the 9600GT is a fantastic card, it will soon be on the bottom of the dogpile when it comes to gaming.
Apr 24, 2009 | ASUS P5PE-VM Motherboard
Replacing Asus CUV4x Motherboard with Asus p5vd2-vm-se motherboard? I have my old computer that i want to replace with new set of motherboard. My old computer has the following specification: Asus CUV4x...
Hi eibral2345, sorry but there is no chance the motherboard, Asus P5VD2-VM-SE will run the Samsung memory. It’s the old style 3.3V PC133/100 SDRAM. The new Asus motherboard,
P5VD2-VM-SE uses Single-Channel DDR2 - 667MNz or 533MHz memory. Here is a link to the specs of the Asus CUV4X: http://www.pcstats.com/articleview.cfm?articleid=314&page=3
Here are the specs for the Asus P5VD2-VM-SE MB: http://www.asus.com/products.aspx?modelmenu=2&model=1787&l1=3&l2=11&l3=369&l4=0
Will the new Asus board fit in your case? It should!
The larger measurement is the height of the board.
The Height + Width of the new board is smaller than the older board.
Have more questions?
Good luck eibral2345!
Mike
Sep 26, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Graphics card problem
Hi rovin,
So you bought an XFX GeForce 256MB video card. You're board has 1 free AGP 8x video slot & 3 PCI (White opened slots).
You mention there is not slot for the new card. (What type of video card did you buy)? PCI-E, AGP or PCI?
The only slot you're board does not have is a PCI-Express.
Look in you're manual on page 1-7 for the location of the AGP video card slot.
94565e6.jpg If you bought the wrong card, exchange it for an AGP 8x or PCI.
The ASUS P5PE-VM uses a integrated Intel® 865G chipset with integrated Intel® Extreme Graphics 2 Technology, which uses you're system memory to function.
If you need a manual you can download it from Asus. Click on the link to open to the P5PE-VM download site.
http://support.asus.com/download/download.aspx?modelname=P5PE-VM&SLanguage=en-us
I hope you find this helpful.
Mike
May 11, 2008 | ASUS P5PE-VM Motherboard
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
