Question about Business Objects Crystal Reports 2008
Out o fmemery while set page setting in crystal report
While i tring to set page set up, error occers out of memory and page setup window shows with out any combo filling. e.g. printer list and page size list not showing and doen'nt accept any changes.
Sharp FO-4400 Manual
Setting 05: TRANSACTION REPORT PRINT SELECTION
This sets the condition for printing out a Transaction Report. Enter a number
from 1 to 5 as follows:
1 (ERROR/TIMER MEMORY): A report will be printed after an error, timer
operation, or memory operation.
2 (SEND ONLY) A report will be printed only after a transmission
3 (ALWAYS PRINTS) A report will be printed after each
transmission, reception, or error
4 (NEVER PRINTS) A report will never be printed.
5 (ERROR ONLY) A report will be printed only after an error occurs
Oct 20, 2011 | Sharp Office Equipment & Supplies
BROTHER MFC8840D IS THERE A WAY TO SHOW THAT I SENT A FAX TO A SPECIFIC PHONE NUMBER AT THE END OF MAY?
Possibly. The Fax Journal has the last 200 faxes (incoming or outgoing). Press Menu then select Fax (up and down arrows). Press Set, and use the navigation keys until Setup Reports or Report Settings appears. Then press Set and use the navigation keys to find the Act. Interval or Journal Period. Press Set again and a length of time for the Journal (anything but off). Press Set again. (If you use the 7 day count-down, you will get additional queries for day of week and time of day for the start of the count-down.) Press Stop/Exit and the Activity Report will print when 200 faxes are in memory, the memory is full or the desired time frame. (The setting of 50 faxes will print at every 50 faxes.) After printing the report, these entries will be deleted.
I hope this helps.
(if the report was already generated, you won't get the old entries. Similarly if the memory was cleared after an Out Of Memory error, you won't find this entry. If Fax Storage was on, you may be able to actual get the original Fax. Menu > Fax > Remote Fax Opt > Print Fax or Print Document. Then Start and when all stored Faxes print hit Stop/Esc.)
Aug 05, 2010 | Brother MFC-8840D All-In-One Laser Printer
The request could not be submitted for background processing
apo ke he nyo nih yob??kome doh make ko??
nate babi sggh mat/minoh saleh nihh..jubo ite..
Jan 11, 2010 | Crystal Decisions Crystal Reports 10.0...
My Sharp UX-355L Fax machine printed unwanted information
Sounds like you have the machine set up to print reports on all occasions, fax transmission, error, etc. You can change this by doing the following:
1 Press these keys:
The display will show:
FUNCTION
TRANSACTION LIST
2 Press a number from 1 to 5 to select
the condition for printing.
ALWAYS PRINT A report will be printed after each
transmission, reception, or error.
ERR/TIMER/MEM A report will be printed after an error,
timer operation, or memory operation.
SEND ONLY A report will be printed after each
transmission.
NEVER PRINT A report will never be printed.
ERROR ONLY A report will be printed only when an
error occurs.
To print from memory:
If the memory becomes full...
If the memory becomes full while the document is being scanned,
MEMORY IS FULL will appear in the display.
♦ Press the START/MEMORY key if you want to transmit the pages
which have been stored up to that point in memory. The remaining
pages will be ejected from the feeder. After transmission, the memory
will be cleared and you can transmit the remaining pages. You
will also need to transmit the page which was being scanned when
the memory filled up.
♦ Press the STOP key if you want to cancel the entire transmission.
Hope this helps. : )
Mar 30, 2009 | Sharp UX 355L Plain Paper Thermal transfer...
How do you turn off the in use/memory light?
This of course depends on why the light is on! If you had a fax come in and it is in memory, you will need to print the fax and clear the memory before the light will go out. The LCD Display should be telling you why that light is on.
1. There is a fax or print job in memory waiting to be printed.--> See steps below
2. There is a paper jam --> Open printer - Remove all paper - Close printer - press OK button
3. You are out of ink or the cartridges are low. - Change Cartridges
Solution: Printing reports and lists MX310
The table below shows the reports and lists that can be printed from your machine.
Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Mar 24, 2009 | Canon PIXMA MX310 All-In-One Printer
How can i get a fax from memory.
Printing reports and lists The table below shows the reports and lists that can be printed from your machine.
LIST
REPORT
RX (Reception)
REPORT
Crystal reports version 8.5
I'm not an expert in Crystal Reports, however you might find my info and experiences to be of some use with your question. I've been working with VB6.0 for some time. One day I decided to checkout Visual Studio 2008, (which came with crystal reports) I decided I didn't like it and removed it from my computer. It was after the removal of crystal reports that my computer went to hell. Every program I tried to install since it's removal was not being allowed, also every program I tried to uninstall was not being allowed. After some research I found out that Crystal Reports was the culprit. It has a management package that was designed to protect it's rights management. Simply stated.....it was governing parts of my registry by setting certain parts of my registry key permissions to, "read only". I ended up having to use the administrative tool in Windows XP and reloading default permissions through an existing INF file thus resetting every registry key back to it's default read/write state. I would not recommend you do this. Doing so may harm your existing install of Crystal Reports. What I would do though if I was in your situation, would be to change just the one key that pertains to your .tmp file location in regedit. My guess is it would be located HKLM under software. You can change any key permissions by simply right clicking any key and go to, "permissions" However, if i'm guessing right, Crystal Reports has a backup mech. that would not allow you to change the key permissions even in regedit. In wich case you'll have to use a utility like ::.HERE.:: and create a custom bat file for just that one key. You can try contacting Crystal Reports directly but i'm quite sure they'll just tell you to kindly, "get bent" lol. This method of protection serves no purpose other then to protect their software from being pirated. So i'm 99% sure they won't help you in the matter that you need. Changing permissions to registry keys back to default would negate their program protective measures. From the problem you described i'm 90% sure that is exactly what is going on due to what I already know about the protection measures of Crystal Reports. Any file that is being generated with Crystal Reports, temp or otherwise is now governed by Crystal Reports through your registry, through a registry like firewall, also run by Crystal Reports. This is why you're getting Access Denied when you try to right click the file and delete it locally. You have two options.
1.) Become submissive and a slave to their tech support and wait for them to come up with a solution that will allow them to maintain control over your registry, with a patch of some sort provided by either Microsft Visual Studio or through Crystal Reports directly that will resolve your particular issue.
2.) Setup a dummy computer install all the crystal reports programs on it. Get it all setup, then do a full registry reset (from that link i posted above) and see if you can still use crystal reports after the full registry reset and if that truely resolves all the access conflicts. If so then apply it your main work machine and once again become the master of your registry.
Hope that helps,
9x
Aug 26, 2008 | Computers & Internet
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
SSRS Tool Tip
SSRS or "sequel server reporting services" check out this link on Microsoft
http://www.microsoft.com/sql/technologies/reporting/whitepapers.mspx
Here is another couple of helpful links, including use of crystal for tool tip expressions
http://www.devx.com/codemag/Article/36397/0/page/4
http://www.experts-exchange.com/Microsoft/Development/Q_22909247.html
Jan 21, 2008 | Computers & Internet
Fax in memory light stays on
I've had this 830 for about 5 months now and am very impressed with its speed, but the glitches, Holy Smoke.
The one you're describing is one I've had before. The only solution I've found is to unplug the machine, wait about one minute and plug it back in. All is then OK. The problem with that system is that if there are any more docs in memory, you've lost them.
I'm having a similar problem with receiving faxes. The first sheet prints, and then the display indicates that there is a 'fax output error check page size and press OK'. The memory light shows that there are more pages of the fax (I presume) that need to be printed, but they won't be because of this error. Of course one checks the size and presses OK but it simply prints out the same page followed by the same error message. This could go on for eons if one would allow it. I then have to unplug the printer, wait and plug it back in, and again all is well, but I've lost the documents in memory.
There are so many little quirks with this machine I am almost tempted to go back to my miserable HP, but I've chosen to keep working with the MP830 with the hopes that after years of learning its idiosyncracies, there will eventually be a class action suit against Canon which I will be part of, to cover the cost of psych services and physical therapy (bas shoulder from throwing the machine out the window.
Wes
Oct 13, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Business Objects Crystal Reports 2008 Logo
55 people viewed this question
Top Business Objects Computers & Internet Experts
David Payne
David Payne
Are you a Business Objects Computer and Internet Expert? Answer questions, earn points and help others
