Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My washer will not Stop filling up with water
When the washer starts it fills up and does not stop. I can get it to drain still but it will not do so during the cycle
  • 446 Answers
The pressure switch which activate the water capacity may probably be defective nor the hose the triggers the pressure switch is clogged up with dirt and does not send the right signal to the pressure switch.
im afraid you need a tech to open up and do this for you..
cheers
Posted on Jan 27, 2009
SOURCE: Water will not stop filling the washer
I just fixed this problem on my GE washer that overflowed earlier into my hallway and living room. The fix required removing the tube from its connection at the outer tub and cleaning out some residue that was preventing air from moving to the sensor at the top of the machine at the control panel. No tools were needed other than a large steak knife to undo the clips to remove the front panel of the machine and a small flat head screw driver that I used to clean out the plastic pressure hose.
The good news is that even if this had not worked and the sensor/switch needed to be replaced, the part is available for replacement at the local hardware superstore and a few online outlets for around thirty dollars. Replacement of the switch looks to be relatively simple by disconnecting the existing wiring housing and replacing with a new part.
There are several detailed diagrams available online by doing a search for your product/ model number.
Be sure to check the hose before replacing the pressure sensor/switch- this will save time and money.
Posted on Jun 23, 2009
  • 209 Answers
SOURCE: Washer water overflow.
i am a recently retired engineer of 20 years and this sounds like a blockage to start with, when you remove the lid you will find a round disc like object (pressure switch) with a thin pipe coming from it going down to the bottom end of the machine, this pipe as either come off or is blocked somewhere. drain the machine totally, clear out the pipes, make sure there are no damaged parts to the pipes, then make sure all are fitted properly, start the machine off again and watch for water level shutting off near the bottom of the door, start with the above, if this doesn't cover the fault there may be an issue with the timer or electrical fault elsewhere/? hope this helps, if so rate me please, thank you
Posted on Sep 13, 2007
  • 1073 Answers
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Posted on Apr 20, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Kenmore 80 series washer doesn't stop filling up with water
You are right, the switch for the water seems to have gone bad and should be replace. It is located next to the timer with a adjusting screw on it.
Posted on Feb 11, 2009
aasc
  • 1606 Answers
SOURCE: kenmore series 90 washer keeps filling with water
If overfills onto the floor , then the waterlevel switch hose came off the switch behind the control panel . You have to remove the 2 side screws and tilt panel to see the hose and switch . If the water keeps filling , but doesn't go on the floor , then you have a syphon problem at your drain . As it fills , water is being sucked out by your drain due to no air able to get in around the drainhose and drainpipe . Pull drain hose out of drain and only insert about 4-5 inches into drain . If hose is tightly in drain , a parts house or home depot should have a syphon break in stock .
Posted on Jul 22, 2009
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Washer won't stop filling
Does the water stop filling if machine is unplugged? If yes, bad water valve inside washer.
If water stops when unplugged, may be a faulty pressure switch or airdome hose came loose from switch - located in control panel - water level switch.
If water keeps filling and never overflows onto floor - likely that water is siphoning out drain hose. Raise drain hose higher or allow an air break at the drain hose exit.
Jan 21, 2011 | KitchenAid KAWS750L Top Load Washer
Maytag top loadind washer. Won't stop filling up.
Make sure your drain hose to the drain pipe is higher than the water in the tub if not it will keep running and going out the drain.
Also try taking the hose off the level switch and blow in it to be sure it's not stoped up. If is it won't let the level sw cut off. air should go through it. Good luck
When you unpluged the power and it ddn't keep runing the water valve should be ok.
Mar 25, 2010 | Maytag PAV2300 Top Load Washer
Washer continues to fill and does not stop. is there a level or pressure switch that is problem or something else? Kenmore 80 series
if there is no water leaking from the unit.then stop the washer pull your drain hose up so it is at least as high as the top of the washer make sure not to to take it all the way out of the wall.you should here water draining out of the hose once the water has stopped restart you washer and it should stop filling.if it does not the yes you have a fill valve sensor problem.the drain hose usually always holds some water and during the filling process if the drain hose if very low it will cause the water to start gravity eeding out of the washer that is why raising the hose helps out.i hope this helps your problem.i would like to now how it worked out for you good luck.
Jan 22, 2010 | Kenmore 15864/15862 Top Load Washer
The washer starts to fill normally, then agitates very briefly, stops, and begins to fill again. When watching the water fill, the water level does not rise at all, and if you push the button in to stop...
It sounds like your drain hose is two low. If your drain hose is inserted into a drain pipe try extending the drain pipe to the same hight as the washing machine.
Dec 27, 2009 | Washing Machines
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Water will not stop filling washer
cut power to washer ..does it stop filling? suspect water level control or small hose to it is off ..keeps running in? shut off water to washer and change fill valve where hoses attach..just won't fill to top and start? raise level of drain hose up and be sure it is not too tight in drain pipe to prevent siphoning
Jul 15, 2008 | Whirlpool Washing Machines
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
130 people viewed this question
Dan Webster
Dan Webster
Sal De
