Emcolite 12 volts 20 volts
How to change the bulb
  • viv_don
    viv_don Jan 22, 2013
    Thank you for your interest but we have managed to prise off the glass cover and were then able to change the bulb.
  • Brian Sullivan
    Brian Sullivan Jan 22, 2013
    well done
  • 27,725 Answers
Need a bit more information as to which bulb you are referring to ?
Posted on Jan 22, 2013
I have a 2004 Mitsubishi Lancer. My passenger tail lights are out. I have changed the bulbs and they are still not working. I do have brake lights. Any suggestions
In the front engine control unit (ECU), the taillight relay may be defective. There should be 12 volts on pin 8. Next, check 7.5A DEDICATED FUSE 20 for 12 volts. Check the lamp sockets for voltage.
Jan 29, 2015 | 2004 Mitsubishi Lancer
How do i change a 6 volt system to a 12 volt system on a 1948 dodge pickup
Voltage conversion necessitates the replacement of all 6 volt light bulbs and motors with 12 volt light bulbs and motors (including the starter), plus the addition of a ballast resistor to the ignition primary so that the ignition primary can continue to operate on 6 volts. You will need to refit a 12 volt starter solenoid, alternator, and regulator to the vehicle as well. Needless to point out that you will also need to replace the radio. You can use the original wiring if it is in good condition, and all switches should operate adequately as long as their insulators are still intact. The 12 volt system uses less current than the 6 volt system, so there should be no problem with wire gauge.
IMPORTANT: If the original system is POSITIVE GROUND instead of NEGATIVE GROUND, you will need to verify the polarity of all motors you replace, plus reverse the polarity of the ignition coil primary.
May 12, 2014 | Cars & Trucks
How many 5 watt outside lights can you power with a 20 amp breaker?
Volts x amps= watts.
20 amp breaker x 125 volts = 2500 watts.
However, electrician use the 80% rule, so multiply 2500 x 80% = 2000 watts.
So if you have 20 amp breaker, and 12 gauge wire, and 20 amp switch, and distance is less than 150 feet, then watt load is 2000 watts or 400 5-watt bulbs.
Keep in mind that most switches are 15 amp, and not 20 amp.
Recalculate for 15 amp switch = 1875 watts x 80% = 1500 watts or 300 5-watt bulbs.
Jun 22, 2012 | Home
I have a old tow motor w/ a wisconsin air cooled engine . I'm looking to change the 6 volt system to 12 volt system. looking for a basic 12 volt wiring diagram for GM alt. and wisconsin parts?
to change the points to electronic you will need to get the manufacturer of the distributor and contact them for a compatible electronic kit to replace the points or replacement distributor
to fit an alternator , get one with an internal voltage regulator ( talk with an auto electrician for the best unit --it is not necessary to go big amperage units so one about 35-60 amps will suffice and cheaper as well)
wiring will be the same as will fuses (neither volt sensitive)
gauges will have to be changed to 12 volt units
bulbs changed from 6 volt to 12 bulbs and switches will be the same as they are no volt sensitive
basically the same circuit can be used and the only place to be careful is the alternator wire to the battery and the charge light or volt gauge ( auto electrician can advise here )
starter motor will have to be changed to 12 volts and you will again have to get the replacement unit from an auto electrician as the bendix pitch , movement and mounting neck will be critical
wisconsin did not make electrical components but used off the shelf companies such as delco remy, lucas , bosch, ac etc for the accessories to the engine
it is an interesting project so collect as much information from auto electricians and web sites to help you
Jun 06, 2017 | Cars & Trucks
Headlight on rx 300 lexus won't work even after changeing the bulb
have a tester handy.unplug the light and then turn on the headlights.with tester on 12 volts test plug to see if you have 12 volts. if not the plug is properly corroded or shorted .
Nov 24, 2011 | 1999 Lexus RX 300
How many 100 watt light bulbs can I hook to a 20 amp breaker (120 volts)
A 20 Amp breaker will support 2400 Watts with a 120 Volt line.
120 Volts times 20 Amps (Amperes) = 2400 Watts.
Answer? 24 100Watt light bulbs.
HOWEVER, you should always allow 1 cushion of 100 Watts.
That would be 23 100Watt light bulbs.
(Wait until you add electric motors to the equation. Things start getting a little more complicated)
(I always use 20 amp breakers for lighting. 15 amp breakers for lighting is phased out.
Secondly a 20 amp breaker requires using 12-2 or 12-3 wiring. (12/2, 12/3)
SO does the receptacles.
Therefore 12 gauge wiring is used throughout the house, until you come to the heavier loads )
[ 12/2 = 2 insulated conductors, and one bare copper ground wire.
12/3 = 3 insulated conductors, and one bare copper ground wire.
Remember, with 12/2 the Black wire is ALWAYS the Hot wire. White is Common (Neutral). Bare copper is Ground wire.
12/3 has 3 conducting wires.
One Black, one Red, and one White for the Common. (Neutral) Bare copper is Ground.
Used for 3-way switches ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 30, 2011 | Hammering
I need a replacement bulb for t3606 12 volt, 20 watt, 1.7amp
I'm glad to provide the instructions get the replacement Spreader Light. Please click hear to order for the Spreader Light.
Please let me know if you require any additional help.
Jul 12, 2011 | Guest 410 Marine Compact Spreader Light...
I changed a bulb in my range hood and when i turned it on tow other went out immediately ??
Did you replace the bulb with the correct type? Check your manual -- mine are 12 volt, 20 watt bulbs. If you put one in there that's not rated properly it will probably blow the fuse(s) in your hood.
Jan 21, 2011 | GE ZV750SY Kitchen Hood
I just installed a 1000 W 3-way toggle dimmer for a load of 12 75 W recessed lights, each holding 65W bulbs. When I turn the lights on, the metal plate around the dimmer gets very hot. Is this normal?
The watt rating is absolutely critical to the operation of the device.
The high heat is a direct result of too much amperage flowing through the dimmer.
Reduce your wattage immediately or stop using the dimmer.
You have a fire hazard.
According to the math, you have 20 - 65 Watt bulbs
Change 12 of the bulbs to 40 watt and you will drop to the 1000W max.
12 x 40 = 480W
8 x 65 = 520W
Total = 1000
However I am worried about this circuit.
A typical 15 amp switch (not a dimmer, but the switch) is maxxed-out at 1440 Watts.
So if you had 20 100 watt bulbs for 2000 Watts, it would heat up the 15 amp switch
It seems very odd that an electrician would put 20 lights on one circuit without having a 20 amp switch and 12 gauge wire.
Look at the markings on the switch you replaced and look for amps or watts.
And then look at the color of the wire cable inside your box ... 12 gauge wire is yellow and the lighter-weight 14 gauge wire is white.
If you have a white wire going to all those lights, then you are going to burn down the house unless the total wattage is reduced.
Volts X Amps = Watts.
I think your circuit needs a review to make sure it has the correct wire.
http://waterheatertimer.org/Color-codewire2.html
This being said, Lutron makes 1800 Watt dimmers.
You can web search: 1800Watt single pole dimmer
If you have yellow-colored 12 gauge wire, it can carry up to 1920 Watts
If you want more help, add a comment and I will answer
Nov 04, 2010 | Lutron 1000-Watt Incandescent Dimmer...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
