Question about Toshiba 32AF43 32" TV
Tv will not stay on just tv
Tv continually changes from tv to video 1 then video two then video three
ive removed batteries from remote and have made sure no buttons are stuckits a toshiba model# 32a43 serial 94735212 chasis# tac0301and main circuit board# pd1050a
  • 139 Answers
Look at the IR emmiter "eye" on your remote thru your Cell phone camera. You can tell if the remote is constantly emitting a signal.
Posted on Mar 06, 2009
When I put the batteries in the remote it would turn the tv on,I followed the directions for putting the code in and after doing that it won't even turn the tv on.
I've not had much luck with "provided" codes, probably because there are just so doggoned many TV models out there. Most remotes have instructions on how to let the remote itself find the code. I found the manual online
(http://tv.manualsonline.com/manuals/mfg/ge_appliances/24991.html). Adapted from the manual:
1. Make sure you have batteries correctly inserted in the remote.
2. Turn ON the TV manually.
3. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
4. Press and quickly release the desired mode button [TV, in this case]. The red indicator blinks off once.
5. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press.
Code Search starts from the currently stored three digit
number under that mode. Sometimes the first code that "works" with your device may only allow limited functionality (e.g. the MENU button might not work).
There may be a code that performs more functions.
Continue the code search process until the best code is
found.
Press the DOWN button to backtrack through the library
until the device changes channel. Pressing
CHANNEL UP changes direction to forward
again.
6. Press and release ENTER to install the code.
Oct 09, 2015 | GE Universal Remote Control 3 Device Model...
I need codes for my rca universal but i cant find them
you only use codes 1 at a time , not in combination .
Sep 14, 2017 | RCA Televison & Video
My Hp pavilion tx1320us notebook pc that ive had for a few years now had fallen asleep and the battery died before i could plug the charger in. When i go to turn it on it turns on and almost instantly...
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 21, 2010 | HP Pavilion TX1000Z Notebook PC
Ive got nitino ul100. ive got 2 green lights on but screen does not come on it stays black
etc....
Sep 19, 2010 | Computers & Internet
I have a Sony KP-53S35 53 inch Rear Projection TV connected to a Directv Receiver. The TV does turn on, but the screen goes blank and VIDEO 1 is displayed. It will stay on, but will continue to do this. ...
Press any channel button on tv remote to switch its input source as TV to watch tv channels.
As you said, screen shows Video-1 display that means tv is set on input-1 that need to be changed, press channel button on remote or tv front to shift it on tv channels mode.
Let me know if you have additional question.
Thanks.
May 03, 2010 | Sony KP-53S35 53" Rear Projection...
Tv continually changes from video 1 to video 2 to video 3 etc... sometimes get black screen as well + menu items. Based on a suggestion, I removed the batteries from the remote but that does not help. This...
It sounds like a switch problem inside the TV if you have already tried removing the remote batts. Try replacing the switches behind the push buttons on the front of the TV. Also, if glass cleaner or some other foreign substance has run down the front of the screen and into the set, this can cause switches to short out and cause this problem. The part number for the switches is 23145227. Thanks for using fixya.
Jan 20, 2010 | Toshiba 32AF43 32" TV
Toshiba TV Remote Control not working
Hi
can you give to me your exact problem?
Thanks!
Sep 22, 2008 | Toshiba 30HF85 30" TV
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
Front panel controls are unresponsive
Check volume up switch in front panel locked continuously. If it is not take away the remote control from the TV or remove the battery in the remote. Because maybe the remote continuously sending volume up commands. Rarely this type problem occurs through remote control also. Even problem is not sorted there is problem in EEPROM ic (memory ic). This can be sorted out by the technical persons only. I hope this useful to you.
Aug 31, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I have been seeing a lot of Toshiba remote "eyes" (the infra-red receiver inside the TV) fail recently. If several known good remotes cannot control the TV then the IR receiver will have to be replaced. If you have no experience soldering and unsoldering PC boards then have a qualified tech handle it for you.
Jun 27, 2006 | Toshiba 32A30 32" TV
Toshiba 32AF43 32" TV Logo
108 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
