Question about Humminbird Boating
How do I set up my Humminbird 858cx to use 83HKz, i get no data in the 83HKz screen.I do get data in the 200 HKz screen
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 227 Answers
Is your transducers 83hkz and 200hkz or just 200 hkz???
Posted on Dec 25, 2013
Why does my screen loose depth return as soon as I am in 150 mts of water?.How come in shallower water I get a very good image but past 150 mts the screen is just scrambled and there's no bottom retur
Be sure you have your unit set in "max mode" and run it on 200khz frequency see if this makes any difference. Also be sure your unit is wired directly to your battery not through a switch or fuse panel as this can rob your unit of voltage, impacting the strength of your sonar signal.
Oct 05, 2014 | Humminbird Boating
Humminbird
My 787c2 screen just shows lines across it does anyone know were to get a new screen for it hummingbird says they don't stock them anymore try Humminbird Fishfinder Depth Finder Humminbird GPS Chartplotters...
Jun 14, 2013 | Humminbird Boating
I just bought a used boat with a Humminbird 160 fish finder on it but, the only thing that shows up on the screen is the temperature, NO DEPTH and NO FISH, is there a setting i need to set as i am clueless...
Check to make sure the transducer is hooked up correctly, and check the actual transducer for signs of damage. Transducers are fragile, and a good whack can break the crystal inside. For more troubleshooting, here is a helpful link with the Owners Manual for your Humminbird.
http://store.humminbird.com/media/document/PiranhaMAX_150-160-170-180-190c.pdf
Aug 29, 2011 | Boating
My Humminbird 788 ci screen clutters up and gives crazy depth readings when the trolling motor (mk terrpva80# w/ ipilot and built in td w/mkr-us2-8 cable) is set on mid to high speed settings. It does...
One thing you might try is restoring the defaults in your unit. One other thing is go into the menu under the sonar tab and adjust your Noise Filter. You may have some type of interference going on. You can call our customer service department and they will trouble shoot it for you. Our number is 800-633-1468.
Joby from Humminbird.
Jan 01, 2011 | Humminbird 787c2 Combo GPS Receiver
Screen shows bottom fine but doesnt show any fish i have changed every setting but nothing works
Fish on the bottom show as a blur, similar to weed, and pelagics show the same, but because of there position they are easy to recognise. Large singe fish like schnapper and sharks tend to show as an upside down V. You will have to use it often and you will eventually, by experience be able to tell whether you are looking at fish or weed.
Feb 07, 2010 | Humminbird Xt 6 20 Transom Mount Dual Beam...
Humminbird 525 fishfinder, battery is fine, unit runs ok in simulator mode, it powers up ok in normal mode, displays for 2 seconds, then the screen goes white, you can just see the reading, but only just,...
Hi!
Sorry to say it sounds like you will need to replace the screen assembly which is about a $70 repair or so.
This is best left to a qualified Humminbird technician who has access to parts and support.
here are the numbers:
Where to ship your items:
(if you live in the U.S.)
Humminbird
Attn: Service Dept.
678 Humminbird Lane
Eufaula, AL 36027 Who to call:
Toll-free: 1-800-633-1468
Monday - Friday
8:00am - 4:30pm CST
Authorized Service Centers - Canada Bay Distributors
119 Progress Ct.
P O Box 70
North Bay, Ontario, Canada P1B 8G8
Tel: (705) 476-6010
Email: info@bwmarineproducts.com
Mike's Reel Repair
#108-31060 Peardonville Rd
Abbotsford, BC V2T 6K5
Tel: (604)855-1119
Email: mikesreelrepair@gmail.com
www.mikesreelrepair.com
PTG Electronics Ltd.
3092 Portage Ave
Winnipeg, MB R3K 0Y2
Tel: (204)831-0862
Fax: (204-888-6207
Email: Ptg_ltd@mts.net
Sep 05, 2009 | Humminbird Fishfinder 525 406260 1
My Humminbird Matrix 67 shows 11.3 volts on the
Hi!
Go into the menu (press menu twice) and look for the alarms tab. There is a setting you can change for a low battery warning, make sure it is set to off or as low as you can get it. Also it may be time for a software upgrade (available at a service center)
Best of luck!
Mike
Jul 08, 2009 | Humminbird MATRIX 97 GPS Receiver
Humminbird Matrix 12 sonar/gps problems
Make sure the 'North Up' is set to 'True' in the settings.
Best of luck
Mike
May 03, 2009 | Hummingbird Humminbird 1155C GPS Receiver
Navionics gold card & humminbird 78c2
Hi!
You NEED to have a gps lock in order for the card to show it's true potential.
Also check in the menu for a setting that says "Map detail" and change it to all available. It could be the setting is on a lesser choice (like the internal mapping and not the new sd card)
Hope this helps!
Mike
Aug 06, 2008 | Navionics: Gold+ Chart Cartridge
Navionics gold sd card
Make sure that you go into MAP data and select this chart as the map info. You might just be using the internal base map right now.
Mitch
Aug 05, 2008 | Navionics Gold United States East...
Boating Logo
56 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
