Question about ASUS P5WD2 Motherboard
PC powers on and dies after 2 seconds. I hope it is the power supply because that is an easy fix. I hope it is not the motherboard (Asus P5WD2). This never happened to me before so I am not certain. I have not moved the machine. Connectors are seated well. Any ideas?
  • 56 Answers
I DO NOT THINK IT IS A POWER SUPPLY PROBLEM, TO RULE IT OUT JUST PUT ANOTHER PWR/SUPPLY ON IT AND SEE IF YOU GET THE SAMED RESALTS I THINK YOU ARE GOING TO GET THE SAME RESULTS AGAIN,
DIS CONNECT ALL WIRES GOING TO THE MOTHERBAORD EXCEPT THE POWER ONE.
I THINK IT IS THE POWER SWITCH IT SELF
IF NOT CONTACT ME AGAIN AND I WILL HELP U
CANDYMANGANDY
Posted on Jan 27, 2009
No display ASUS P4P800-VM Motherboard
Check the memory and the power supply fan is spinning if not that means you have a problem with your motherboard. If the power supply is spinning monitor if you hear a beep if there is a beep that means you have a problem in your motherboard. Check also the CPU fan if spinning, if spinning in a second then stop you have a problem with your processor
Oct 10, 2011 | ASUS P4P800-VM Motherboard
I have a asus p5wd2-e motherboard and am trying to start for first time. board powers up hard drive and dvd rom power on as do the fans and internal lights. but video does not appear at all??? video card...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Apr 19, 2011 | ASUS P5WD2 Motherboard
Sir i am using asus motherboard(ASUS M2N68-AM SE2) in my pc, when i switch on my pc the processor fan and smps fan is rotating for few seconds(4 to 6 Seconds) and it stopped rotating. 1. the monitor shows...
remove all the ram from motherboard and switch on the system and see it is working or not like just on and fan are rotating and the smps fan is also working and your system is giving beep sound for ram.try with other smps also some time problem with power supply also. Remove the connector of power switch and restart switch and directly try to on from shorting the connector with the help of pen or screw driver point. Some time faulty switch also give problem. Just try all these possibilities.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Jan 03, 2011 | ASUS M2N68-AM SE2 Motherboard
Driver audio
You can download the drivers from ASUS WEB site. Select your model motherboard, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system.
Click on this link: -
http://usa.asus.com/index.aspx
Mar 25, 2010 | ASUS P5WD2 Motherboard
First time building power hookups on mobo
the general guidline is that if your power supply has the extra cables and your mobo can support them, then plug them in... those extra 4 wires in your long power strip will normally be used for grounding, so that's a must. check your mobo manual to see the exact specs. ... as for raid, wiki it man.
Jul 17, 2009 | ASUS P5WD2 Premium Motherboard
I hook everything up and turn it on but i get nothing
if you just built a new pc, and hooked up your power button and reset button and mixed up the possitive and negitive wires you may have fried your motherboard. If you hold the power button for five seconds and your pc does not power down, it's fried.
Apr 11, 2009 | ASUS P5WD2-E PREMIUM GREEN INTEL 975X...
PCIe card detection
I need to get mother board drivers of Asus p5wd2. Plz help out and tell me the site to download the same.
Oct 30, 2008 | ASUS P5WD2 Premium Motherboard
PC doesn't turn on
You can find a lot more help- info about that in the forum of asus....!
Sep 28, 2008 | ASUS M2N-MX Motherboard
Computer powers on but then turns off after a few seconds
I know this is a late response but someone might have this similar issue which is generally caused by a faulty power switch on the case of the computer. The switch is stuck in the pressed or active position so when you power the computer the switch still being depressed or faulty turns the computer right back off again and you're stuck in this loop. The best way to identify if this is the issue is to remove the power shunt from the jumper then use a screw driver to jump the power connections that would turn the computer on... if it stays on the switch or entire case needs to be replaced whichever is easier
Aug 08, 2008 | ASUS P5W DH Deluxe Motherboard
P5WD2-E Premium
Intel Socket 775 Pentium® 4/Celeron Processors
Compatible with Intel® 05B/05A/06 processors
Intel® Hyper-Threading Technology ready
Support Intel next generation 65nm CPU
This link will show which processors are compatible( look for the 65 nm Manufacture tech.) Filter on
  1. Package type LGA 775
  2. Bus Speed 1066
  3. PCG 06
Looks likeno quad just Duo
Mar 22, 2008 | ASUS P5WD2 Premium Motherboard
ASUS P5WD2 Motherboard Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
