Zanussi jetsystem ZJD-12191 TURBODRY washer dryer drum will not turn
WILL FILL WITH WATER AND GO THROUGH THE PROGRAM BUT KEEPS TRIPING MAINS FUSE. DRUM DOSE NOT ATEMPT TO TURN. NO SMELL OF BURNING OR ANY NOISES
  • Washing Mach... Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jan 22, 2013
  • 1462 Answers
SOURCE: Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Posted on Apr 01, 2007
SOURCE: Zanussi jetsystem Turbodry 1200
Hi, Ive moved into a new flat, and I have a zanussi jet stream 1400 turbo dry front loader. Of course, no instructions were left on how to use it. I cant seem to get anything but soaking wet clothes, no spin cycle, and certainly no turbo dry.
Can you tell me where I could download a users manual?
Posted on Feb 10, 2008
SOURCE: Zanussi jetsystem 1200 wahser dryer problem
with my machine halfway the wash cycle E20 comes up all the time. how can i solve this? email to rients@rients.com
Thanks!
Posted on Jun 05, 2008
kjmac
  • 97 Answers
SOURCE: Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
barkencoa
  • 3463 Answers
SOURCE: zanussi jetsystem 1400 not drainng properly.........
There should be a filter located at bottom front right of washer behind a metal cover.
Press on cover to open, and remove filter by unscrewing anti -clockwise.
Also check outlet pipe is not blocked, more so if it goes into a sink waste connection, if it still leaves water in drum, then there is probably a partial blockage else where, which will require further investigation.
Please leave a fixya rating if my solution solves your problem.
Thankyou.
Posted on Feb 06, 2009
Zanussi jetsystem turbodry 1600 wjs1665 w is not heating the water
More than likely the heater element has failed.
This is located at the rear of the washer drum.
It means removing the rear half of the cabinet to access it.
Mar 29, 2010 | Zanussi ZWF1430W Front Load Washer
Power button seems to be broken
the trigger has been damage you have to replace it .if you want i can fix it im a technician
Jul 18, 2009 | Washing Machines
Zanussi jetsystem turbodry 1200 door wont open
its the doorcatch,turn power off, remove lid and put hand in machine where doorlock is situated feel about and try open catch, repair or replace?
Jun 24, 2009 | Zanussi ZWF1420W Front Load Washer
WASHING INSTRUCTIONS ZANUSSI ZJD 1285
CLICK HERE
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 16, 2009 | Washing Machines
Zanussi ZJD 125 on a timer switch
No prob, the washer never draws the full 3kw at any one time.
Plz rate this solution.
thanks.
Dec 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanusssi jetsystem turbodry 1200
clean out filter, door bottom right, unscrew filter and clean it
Aug 02, 2008 | Zanussi IZ161S Front Load Washer
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi turbodry w 1042 w
probably short to earth on the dryer elements. to check. take top off, disconnect dryer elements then run on dry program. if the trip stays in, then you have identified the fault
May 16, 2007 | Zanussi FJS1225W Front Load Washer
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
