Question about Sony Televison & Video
What is the parts number used in sony kv-21bmr1 ic regulator?
    Top Expert:
  • Sony Master
  • 74,251 Answers
There are three IC regulators. Out of which ones number do you want? Circuit section? Position?
Posted on Jan 22, 2013
  • 236 Answers
SOURCE: STRS6707 problem
In the past, my experience with Sonys is that you need to use Sony parts to successfully repair them. Also you might have a cold solder joint which creates an arc when you turn it on. This arc will cause a "spike" which could possibly take out the regulator. Stargazer
Posted on Jan 21, 2007
  • 119 Answers
SOURCE: part help
the vertical o/p generic number stamped on the fron of the ic is "TDA8172" the sony part number is "8-759-980-58". good luck
Posted on Mar 13, 2007
jerryg50
  • 1667 Answers
SOURCE: regulator ic of sony tv kv-g21c1
I am not familiar with the particular model of Sony TV that you have. I can answer genericaly:
There are a number of voltage regulators typicaly used on TV sets. These are usualy IC devices, or a complete descrete circuit. The purpose of these are to regulate voltages that are used to operate various circuits. Most sets can typicaly have anywhere from about five to maybe even a dozen or more throughout the set, depending on the sophistication of the model.
The regulators, like any part in the set can fail with age and use. Sometimes they are damaged from other components failing, or when a regulator fails, it can damage the circuit areas that it is suppying. When the set is being service, the tech must check for other failed parts.
Jerry G.
Posted on Sep 01, 2008
  • 108 Answers
SOURCE: SONY KV-2965, vertival IC damaged
Not a good sony model number. How old is the set
Posted on Jan 07, 2009
  • 4234 Answers
SOURCE: sony color TV model kv-c29 11d blown power supply ic and transist
There should be circuit designations printed on the PC board. Without those, there are too many possibilities to give you anything useful. Can you provide those please?
Thanks,
Dan
Posted on Jan 21, 2009
My sony kv-21BMR1 problem no sound
How many KV21BMR TVs; you have?
Aug 10, 2016 | Sony Televison & Video
KV-21bmr1. Why no color?
If tuner has fault, there will be no color.
If color system is set wrong, there will be no color.
If the chroma-IC is faulty, there will be no color.
If the set has not been properly tuned, there will be no color.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 18, 2015 | Sony Televison & Video
My television will not turn on. The light blinks 6 times over and over again and there is no picture or audio.
that chassis for sony is the DA4 chassis and they had a big problem with regulator failures in the main power supply. primary and secondary power regulators the location numbers are IC8002 and IC6501 i believe the part number from sony is MCZ3001DB you must get the part number that ends is (DB) or you will not reliably repair the tv. the sony part number is 6-705-810-01 they are going to cost around $20 each because they are the good parts. they are going to be about 20 pin ICs and you will just need to desolder old ones and resolder new. they will be on the board on the left looking from the back about middle of the board on the left hand side. good luck!!!
Jan 26, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Part No EHT of Sony KV 2167MT
1-439-530-21 part no. for flyback transformer
Sep 13, 2009 | Sony Televison & Video
Regulator ic of sony tv kv-g21c1
Jerry G.
Sep 01, 2008 | Televison & Video
Sony Vega Service Codes
The 7 blinks indicate an over voltage condition. The high voltage section has exceeded 33,000V. This is generally caused by a bad regulator. I don't have a listing for your model, but there should be a multi-pinned IC attachd to a heatsink marked STRxxx located close to where the AC cord comes into the set. Post the actual marking here and I'll get you the part number and cost. That is the regulator that may be the problem.
Dan
Jul 15, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Part help
Mar 13, 2007 | Sony KV-27S65 27" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
