Question about Konica Minolta Bizhub C220 Color Copier
We have a bizhub c220 that keeps wrinkling a3 paper. The engineer blames moisture content of paper but the paper has been in the machine for over a week and the room is bone dry. Help.
We have used paper from 3 different suppliers but still the same problem. Paper is kept in sealed packs until installed in the machine.
  • Michael Feb 02, 2013
    If the paper is getting wrinkled, check the pressure roller.
    If it is wavey in the paper feed direction, check ALL of the gears around the fuser.
  • Konica Minolta Master
  • 1,297 Answers
Try A4 R position and A4 normal position.If is OK the problem is located in the vertical transport section.If the problem persist the A4 paper the causes is located in 2 section:before enter in the fusing unit or exit to fusing unit.Check the Lower pressure roller and the springs.
Posted on Jan 29, 2013
  • 74 Answers
SOURCE: Bizhub C10, error c0045
The Fusing Cooling Fan Motor (M3) Lock signal HIGH for a continuous 1 -sec. period while the Fusing Cooling Fan Motor is turning at full speed or decelerated speed. This may need to be replaced or checked by a service tech
Posted on Mar 31, 2010
Testimonial: "Quick reply and to subject oriented. Bravo Expert!"
jqsababa967
  • 145 Answers
SOURCE: There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
Posted on Apr 26, 2009
  • 1297 Answers
SOURCE: Konica bizhub di1610fp priter constantly gives a
Change the paper size,emter in the user modeor press the Utility key.I have the Minolta Di 1610 (copier/printer) and every function is OK.One toner cartridge is OK for 7500 copies,if you can the setting the user tools.
Posted on Sep 01, 2009
  • 79 Answers
SOURCE: At power on, my bizhub 222 immediately gives me a
If you have verified that there is no jammed paper, then I would suggest taking a can of compressed air and blowing the doc feeder out as best you can. Often times dust or paper scraps and debris can become lodged in the paper path, frequently blocking a sensor, thus creating a jam (despite the lack of paper.) As well, you might try running a thick piece of card stock through the feeder, as this will act to dislodge any stuck paper bits.
Let me know how it turns out.
David R.
Posted on Dec 11, 2010
  • 118 Answers
SOURCE: bizhub 500
ya i agree but.... there may also be a piece of paper behind the paper drawer too... check it out. to remove the paper drawer there is a stop with one screw that you have to remove in the frount of the cabinet on the right side
Posted on Nov 20, 2011
Why is bizhub 450 is warping the paper after copying?
Have tech come out and look at the fuser unit and check the temp setings
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 25, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub c220 defaulting to bypass tray
means from printer properties it can be set to any tray
if ur using defalut settings it is
set it to a4 paper and tray 1 or 2
Dec 18, 2012 | Konica Minolta Bizhub C220 Color...
Bizhub c220 tray 1 problem
pull out tray and check any paper is jammed is remaining at the back end of that tray
Nov 19, 2012 | Konica Minolta Bizhub C220 Color Copier
How to keep the envelope from wrinkling during printing
Are you using proper laser envelopes? The machine should also be set on envelope mode (When you put your envelopes on the bypass tray the machine should ask what kind of paper you have put in there - just select envelopes).
Oct 08, 2012 | Konica Minolta Bizhub C220 Color...
Trying to print A3 full colour on my bizhub c250.2out of 3 times paper crashes at the oven and get the massage: misfeed detected, i remove the jam paper. but i would like to know what can cause this...
Fusing unit life is over or it can be the paper size problem.if you are using manual by pass tray for A3 printing then make sure machine is detecting A3 in manual by pass tray.if its OK then problem is in fusing unit.
May 31, 2012 | Konica Minolta bizhub C250 All-In-One...
My brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Tam
Apr 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
My printer wrinkled the paper when it is out
Try using fresh paper from a new ****. If still wrinkles might be an issue with your fuser. The fuser is the part that heats the toner onto the paper and if the paper contains too much moisture content (from improper storage methods), this can cause wrinkling effect as well.
Try printing with different types of paper and from manual tray to isolate problem. If it occurs all the time, most likely bad paper or bad fuser.
Jan 16, 2010 | HP LaserJet 4200 Printer
Printer
High moisture content in paper,
or fuser (ie hot bit rear) needs replacement the orange fuser pressure rollers are wrinkled or worn.
Jan 09, 2008 | OKI C3200n Led Printer
Paper traveling too slowly through system
These do run slow 4 pages a minute, they were fast in their day.
Check driver settings on pc that paper type is set as normal paper.
Otherwise it is the paper having high moisture content or machine needs a new "baker" aka the fuser assembly rendering it unecomical for repair (lower orange roller will be creased or upper roller losing its coating)
Nov 20, 2007 | HP LaserJet 4 plus Printer
Konica Minolta Bizhub C220 Color Copier Logo
153 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
