Question about Dualit Coffee Makers & Espresso Machines
I need a handle for dualit 84009 espresso coffee maker. It is the handle that holds the black plastic 2 head piece in order to filter through 2 cups of coffee.
  • 123 Answers
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Your manual is listed on this page and you will be able to download it.
Good Luck.
Posted on Apr 10, 2008
  • 15 Answers
SOURCE: Dualit 889 espresso coffee maker problem
To pull a shot
1) Turn machine on (innermost right switch)
2) Red light goes on (power on)
3) Yellow light goes on (thermablock heater)
4) Wait for yellow light to go off
5) Detach handle (pull to left)
6) Clean handle, remove crema sieve, clean with soap & water
7) Put crema sieve in handle (you should have a choice of two)
8) Put espresso ground coffee in with brown handle
9) Tamp coffee down FIRMLY with handle
10) Place handle back into machine (push to right)
11) Ensure flip switch on leftmost side is at top position
12) Flip down rightmost switch to infuse coffee into handle
13) Wait 18 - 24 seconds
14) Flip up rightmost switch to turn off infusion
15) Put milk into container (about 200ml in a 600ml container)
16) Flip down rightmost switch to bottom position = steam
17) Keeping tip about 5mm from top of milk, foam to ~400ml
18) Place sugar in coffee, if desired
19) Pour milk in coffee
LATTE
YUM
Posted on Jun 22, 2008
SOURCE: Need Replacement pot for black Kit. Select. Dual Pot Coffee Maker CM-202
Select Brands
Kitchen Selectives
Select Brands
Customer Service Or Call 913-663-4500
To order replacement carafes for the CM-202 Dual Coffee Maker you have to call Customer Service at 913-663-4500 - This item cannot be ordered on line.
Posted on Jan 01, 2009
SOURCE: bosch porsche 9110 drip coffee maker
mine just broke this morning! i just ordered the same part from appliancepartspros.com - the part number is AP2807555. It is currently backordered until 4/25/09 - hopefully I will get that and the other part I ordered. Hope this helps.
Posted on Apr 15, 2009
  • 7 Answers
SOURCE: How much coffee?
Fill it as full as you can with fine ground coffee. I cut the resulting brew with an equal amount of boiling water. Called an "Americano" in Italy.
Posted on Jul 17, 2009
Why does steam wand on dualit espresso leak
The wand can leak if the rocker switch is not in the UP position.
In MIDDLE position it will try to deliver hot water.
In DOWN position it will try to deliver steam.
The thermoblock in this unit is actually a 3-way valve, of which two positions route water from the boiler directly to the wand. The 3rd position (UP) routes hot water (but not steam) from the boiler to the group head.
Try holding the switch in the UP position by hand when making coffee. If the machine still pushes water through the wand then you will have to replace the switch inside the machine that is activated by the rocker, or the valve it operates.
Please let me know how it goes.
graham dot r dot leach at gmail dot com
Oct 01, 2010 | Dualit Espresso 889 Espresso & Coffee...
Lost a piece of the black plastic steaming wand
Check with WholeLatteLove, yes I know the only have gaggia parts, its the same thing.
May 07, 2009 | Saeco VIA Venezia
Dualit 889 espresso maker leak
my machine did the same.... i just descaled it and gave all the parts a really good clean and it seemes to solve the problem
Dec 30, 2008 | Dualit Espresso 889 Espresso & Coffee...
Dualit 84024 - Coffee flows through central screw of flow head?
you can ask the service center at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700--Steve Karow
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Sep 13, 2008 | Dualit 84024 Espresso Machine
Brew head gasket
I Rang Dualit direct and they sent out the gasket free of charge
t + 44 (0) 1293 652 500
info@dualit.com
Jun 28, 2008 | Dualit Espresso 889 Espresso & Coffee...
To pull a shot
LATTE
YUM
May 06, 2008 | Dualit Espresso 889 Espresso & Coffee...
Dualit vapor lost
if you are loosing our steam you have a seal problem you have to open the machine and activate it look were the steam come out remove the piece clean and ghange seal good luck cheers
Jan 30, 2008 | Dualit 84022 Coffee Maker
Spare parts/dualit 84024 espresso
If you are in the UK, contact Dualit, who even though they have stopped making espresso makers, apparently stock a good range of parts - and also offer a repair service.
Dec 28, 2007 | Dualit 84024 Espresso Machine
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Dualit Coffee Makers & Espresso Machines Experts
Hjalmer Lamminen
Hjalmer Lamminen
ray gallant
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Dualit Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
