Question about Haier Washing Machines
My haier thermocool top loader washing machine is not draining water in the wash tube Just observed that ,what is the solution
I want solution to the problem
gittos73
  • 244 Answers
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Posted on Sep 12, 2007
futureloginn
  • 734 Answers
SOURCE: Daewoo Top loader washing machine water wont drain...
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
  • 6 Answers
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Posted on Dec 20, 2008
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
Posted on Aug 10, 2010
Haier Thermocool washine machine 8.0kg does not drain water after washing. Why?
Drain pump is blocked with debris or the drive belt is not turning the pump. Have an appliance engineer take a look.
Mar 30, 2015 | Haier Washing Machines
you need to locate where your pump outlet is on the machine,, it must have something stuck inside it
Oct 18, 2012 | Haier XQBM22-C Top Load Washer
My bravos top loader will not fill up with water. The water drains as fast as it is trying to fill up. As a result, the wash cycle never completes.
You must make sure the drain hose is above teh water level and not in the water in the "P" trap of the house drain. There must be air to prevent siphoning. The drain hose should not go more than about 12" down in the drain tube.
Kelly
Mar 27, 2011 | Maytag Bravos MTW6600T Top Load Washer
My washing machine spins and rinses but does not fill with water and wash, what could the problem be. It is a top loader
Does it pump the water in?, I made a small mistake of just running my drain hose to the floor drain in a basement suite once. with out the hose being up above the rim of washer,the water just runs right on out. made a mount with 2 inch pvc and ran a tube to the drain and it worked then.
Mar 04, 2011 | Kenmore Washing Machines
Hi, I bought a Haier 8.8-lb. 1.6 cu. ft. Capacity Portable Top-Load Clothes Washer from drugstore.com two week ago. When water goes into the machine, I found the water came out from drain tube at the same...
Have you got the drain pile positioned higher than the top of the machine. If the outlet of the pipe is lower than the water level, the water will just run out. If this is not the problem then don't even try adjust or open the unit. Take it back to the dealer or you will void your warranty and it is not worth it. Let the dealer worry about it.
Feb 21, 2011 | Haier HLP23E Top Load Washer
Laundry tub has a bad smell/stinch like mildew. Has gotten into towels and other laundry. How do you get into the machine to see if there is lint buildup or what is causing this? Have used numerous odor...
Water left in bottom of washing machine should not be more than a tablespoon or so. Have you tried washing a full cycle with EMPTY washer, 1 gallon of clear distilled vinegar and 1 pound box of baking soda...the plain one on the grocery shelf. You got some drain tube that seems to be harboring this smell, which feeds back to your clean clothes. Empty the washer immediately upon washing being done. Always leave your lids or doors open. You may have to change out the tubing/drains from INFLOW and OUTFLOW. This is all under the assumption you have a front loader. I don't believe this would exist with regular top loader as gravity pulls all to the drains.
Oct 17, 2017 | Kenmore Washing Machines
Top loader washing machine does not fill up
very simple, your drain hose is below 4 ft, your drain hose should go in the hole between the hot and cold water, if you dont see a hole then it is covered, you need to knock out the hole...
Nov 10, 2009 | Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Draining extra water
Cut off the zip tie that holds the drain tube. Bring the drain tube as close to the ground as possible and siphon out the water - yes, that means sucking on that hose. Have a bowl handy to collect the water, or do it somewhere you don't mind getting wet. Just keep the end of the hose lower than the basin of water and you should have no problems.
Oct 10, 2008 | Haier HLP21E Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
