I changed the almost every setting in aging menu of Aiwa A2119 TV. Channels were reduced to 99 from original 209 channels and picture quality has become very very poor and dark. Please communicate to me the factory aging menu settings of the TV. Thanking you people in advance.
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
  • 52 Answers
SOURCE: won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Posted on Mar 07, 2008
SOURCE: AIWA TV-A2119 PROBLEM: SOUND MENU NOT COMING
THE PROBLEM IS YOUR TV MODE HAS BEEN RECONFIGURED TO KE1 MODEL. SO YOU WILL NOT GET THE AUDIO MENU. THE SOLUTION IS, JUST BUY AN ANOTHER REMOTE RC-ZVT03 MODEL AND USE IT AS A TEST JIG REMOTE. OPEN THE COVER, YOU WILL SEE THE CONTROLLER IC BW7461-3T ( 16 PIN). ACTUALLY TO ENTER IN TO THE SERVICE MODE, WE HAVE TO PRESS THE "TEST" KEY. BUT THAT KEY IS NOT AVAILABLE IN THE REMOTE. SO SIMULATE THE 'TEST' KEY, JUST SHORT THE PIN NO 4 AND PIN NO 12 THROUGH A WIRE TO ENTER IN TO THE "SERVICE MODE". ONCE YOU PRESSED THE PIN 4&12, THE TV WILL ENTER IN TO THE "AGEING MODE". THEN PRESS "AV MODE" SWITCH IN THE ANOTHER REMOTE ( YOUR CASE ZVT13). A MENU WILL APPEAR TO SELECT THE MODE. PRESS NUMERIC KEY "3" (INDA-1) TO SELECT THE "AIWA TV-A2119KE" MODEL AND AGAIN PRESS "AV MODE" TO EXIT. AGAIN PRESS THE TEST KEY TO EXIT. RESTART YOUR TV. NOW YOUR PROBLEM SOVED. SINCE I ALSO FACED THE SAME PROBLEM, I GOT THIS SOLUTION (jp_ati).
Enjoy.
Dr. M. Jayaprakasan, Chennai
Posted on Oct 12, 2008
SOURCE: Aiwa A2119 Tv setting codes
I have Aiwa A2119 model and I am facing sound problem, as all other things are working perfect but sound is automatically gone I don’t know why. Can you help to solve it?
your help will be greatly appreciated.
With regards,
Ash
Posted on Oct 30, 2008
  • 188 Answers
SOURCE: philips 21rf vardan tv
Check option code's.
Posted on Jul 29, 2009
Tv error codes
This problem has been answerd a few while ago.
May 17, 2013 | Aiwa Televison & Video
Brand new TV with Light leakage on the screen
I happen to have the same tv brand, size, and problem. The only difference is model. I bought mine black friday 2012 and its got screen problems. Im looking for a solution also to why it has the problem it has. It was working great for the time being until i noticed cloudy white spots around the perimeter edges. I found out its do to a few possibilities. One is the one thats wrong with mine that i believe is dead pixels. My tv doesn\'t look damaged in the screen butt when the image darkens while watching tv u can see it. Its like a bleeding discoloration. Me personally im taking mine back to either get my money back or new tv. From ur breaf description sounds like u have the same issue except yours came that way.if u look at my follows on here u will see pictures of my tv and the issue to my screen. I bought mine from best buy. So i got a thirty day store return warranty plus i purchased a 2 year warranty. So im going back and going to see what they are going to say. I advise u to probably do the same especially if u got warranty.
As far as changing ur setting for HD picture quality with ur dish is to go through your menu options on the dish.i use comcast so mine is different butt im sure in a way the maybe might b in somewhat similar. With comcast theres a format button on the front of my box that i can press to change different format quality. If that dont give u what your looking for then see if you turn off your box while tv is on and then press menu on box and see if a user menu pops up if so then u should be able to change quality. You then can program it to be 1080 if ur using hdmi or components. One thing with comcast box is that i can make every channel 1080 bt the regular channels that dont broadcast that quality makes the picture smaller. So then u have to have HD channels to get 19080 quality. Butt u can get a good quality setting still with regular broadcast channels by overriding to 480p or to the best quality its puts out to that channel. Most broadcast channels set out a 480i or a a better HD 480p. Other than that you have to have HD channels and then ur box should automatically format to 1080u quality on the HD dish channels so you dont have to keep changing. Then when change ur channel back to standard broadcast channel it will automatically format to back to 480peither and so one as you change channels. Well hope it all helps and you got what you were looking for.
Dec 04, 2012 | Westinghouse " 46"" Class - LED - 1080p -...
My aiwa tv a 219 remote locked how to open it.
Aiwa television comes with the option of blocking certain channels from viewing, allowing you to control which channels people using the television can view. However, if you forget the code that you entered to block the channels, you might find yourself unable to watch those channels. Fortunately, there are a couple of buttons on the television and the remote that you can press to reset the PIN and customer ID numbers, which unblocks the channels.
Turn the television on.
Press the "Volume Down" button on the front of the TV and press the "7" button on the remote at the same time.
Enter in a new PIN code and new customer ID.
Oct 30, 2012 | Aiwa Televison & Video
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control.
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
6EDEH
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
100 000 0
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Sep 14, 2009 | Aiwa TV-S2011 20"
With regards,
Ash
Aug 14, 2008 | Aiwa F2000 20" TV
Enjoy.
Mar 22, 2008 | Aiwa F2000 20" TV
Aiwa Tv sound menu is not coming
Aiwa A2119 21"TV
picture okay but no sound. service mode not function in remote control for rectification.How to get sound. My E mail ID is vattipl@yahoo.com
Dec 20, 2007 | Aiwa F2000 20" TV
AIWA VX-T1420 Setting Channels
No it should not light up. If you can not go into menu and add channels manually or auto program. Then you will have to get a remote to work. You could order original remotecontrols.com.
Sep 23, 2007 | GE 13TVR60 Combo
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
