Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool side by side, 7 years old. not making ice
The trough that runs from the back of the freezer into the mechanizm that makes and dumps the ice seems to be frozen solid. the handle is in the down position and has been raised and lowered to try to fix the problem. This occurred about 3 days ago. I turned the temperature down on the freezer this morning to the lowest setting in hopes that the trough may thaw. The water dispenser still works correctly and the filter light is green and was replaced not too long ago. Any help that you may provide would be appreciated.
  • 410 Answers
Try using a hair dryer to thaw out the trough and remove the ice. please note the ice will run all the way up into the tube where it comes thru the cabinet.
this may have occured from your recent filter change as a new filter introdues alot of air into the water system and will cause these tubes to freeze up. in the future right after you replace your filter be sure to run aout 1/2 to 1 gallon of water thru water dispenser to clear air out of system. thx peyton
Posted on Jan 28, 2009
We have a whirlpool gold conquest side by side refrigerator. Water dispenser works, ice does not. Stopped suddenly making any ice. How do we fix it? It's only 2 years old.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 21, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
I've got a Whirlpool side by side refrigerator that is about 7 years old. The freezer side works, the frige side works, and the ice maker is making ice. The front door ice and water dispensor isnt working...
That will take a few test to determine which is the most likely. Most times it is a loose connection in wiring harness as it goes from cabinet to door or the freezer light switch is defective. When you open door to freezer all of the fountain and ice maker power is disconnected for safety reasons. If the switch is defective when door is shut then these are acting as a lockout. But you just said ice maker works so we are back to a bad connection or the LV (Low Voltage)board itself. This will take someone with a multi meter and follow through with me and wiring from the tech. sheet. I will try to make a wiring diagram for you to follow here. Thanks, Sea Breeze
Jan 19, 2011 | Whirlpool GD2SHGX Refrigerator
I have a whirlpool side by side model # ED5VHGXMB10. It leaks water into the bottom of the freezer. I have re adjusted the water tube that dumps water into the ice maker thinking it was shooting over the...
Below that panel in the freezer (evaporator cover) is the drain trough. Most likely it is clogged.
Using a baster, with hot water and bleach mixed deluge till it flows down to the drain pan underneath.
Dec 31, 2010 | Whirlpool ED5VHGXM Side by Side...
We have a GE Side by Side Profile refrigerator and the freezer, at it's highest setting, can't keep ice cream frozen and the ice maker only puts out about 8-10 dumps in a 24 hour period. The model is...
Sounds like your coils are dirty which will cause inadequate cooling due to reduced heat exchange at the coils. Also check to make sure fan is running (next to compressor and should be running when compressor runs). The fact that your ice maker makes ice at all suggests that compressor runs, therefor no freon problems. Problem should be easily fixed with correct diagnosis. Hope this helps.
Dec 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Gold GD5SHAXLQ02- Serial number SP3131657 just stopped cooling. Neither the fridge and freezer seems to be cooling. This unitl is about 7 years old.
Hi!!
Check
temp. control knobs,
Small fan in freezer
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure the air duct going to the fridge is clear. Once this is done, restart unit.
If evaporator is not covered w/ice, then you may have a freon leak, Call a Service Center to get a repair estimate.
Don't forget to rate this post!! Good Luck
Aug 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer drain freezes up, leaks on to shelf in frig. It get so bad that there is ice built up on the floor of the freezer. Frig is only 4 years old.
you have a defrost problem it is either a defrost thermostat, defrost heater, defrost timer, u can manually defrost it by unpluggin it for a awhile and lettin it wamr up and clear the ice and that hole.... or posiibly remove that back panel in the freezer and takin a hairdryer to those coils and drain hole or trough,,,,,, this is only temporaliy though u gotta figure out which one of those parts is faulty hope this helps
Jan 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our ice maker is not working is there a switch to turn on to make it start producing ice. We bought it used and it is only a couple of years old. It is a Whirlpool gold. Side By Side
Open up freezer door look at ice maker. The wire is the on/off switch. If wire is up push down to make ice. The wire runs the length of the ice maker and does not take much force to move.
Good luck
Sep 29, 2009 | Whirlpool Refrigerators
Refrigerator is 7 years old. no ice is being made and refrigerator is now setting on the "coldest" setting, and barely keeping refrigerator cool and freezer items barely frozen. could dirty coils be...
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 13, 2009 | Roper RT18HDXKQ Top Freezer Refrigerator
Not getting cold
hi..
1)check your cutoff sensor, it is most likely a rod that will push up when the ice bin gets full, make sure its not stuck in the up position...
2) If the tube to the ice maker was not clogged with ice itself that is not your problem. The ice maker is thermally proctected and will not make ice unless the freezer is actually at zero degrees F. Not just frozen. The plastics in a freezer will be soft when warm even easily melt, but be hard when at operating temps. Just try setting your freezer colder to see if it kicks in. Give it at least 24 hrs. Don't do the human nature thing and open it every hour to see if it makes ice. You will just dump the cold air out. Listen for the ice to dump into the tray. I hope this helps..
thank u
rate me!!
Jul 15, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
97 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
