Question about X2Gen MG19MY 19" LCD Monitor
X2GEN MW19U MONITOR (THE SAME PROBLEM -SCREEN BLANK & CLICKING)
THE POWER SUPPLY SEEMS THE MOST COMMON CULPERT - WOULD WE NOT HAVE THE SAME PROBLEM BY REPLACEING THE POWER SUPPL.Y FROM THE COMPANY WHICH IS LONG GONE--IS THERE SOME OTHER WAY TO MATCH UP A POWER SUPPLY THAT IS SUPECT???
  • cdimit1 Jan 31, 2009
    yellow light blinks but monitor will not start
  • huotnuts Feb 15, 2009
    the power box seems to just die and the screen goes blank can we get a new power box
    Problem Solver:
  • 10 Answers
Go on Ebay and find another power supply rated 12V @ 4A
Posted on Apr 09, 2009
BEING A COMPUTER EXPERT (IT TOOK ME 6 MONTHS) TO REALIZE "DEFAULT" MEANT GOOD NOT LIKE BACK IN THE DAY!
STARTING FROM THERE, I NEVER EVEN THOUGHT OF WHAT MADE A MONITOR LET ME GAMES ON POGO & CHECK THE GIRLS OUT. I LOOKED UP "X2GEN" AND HAD NO PROBLEM FINDING OUT THEY DON'T LIVE THERE ANYMORE.
THEN I LUCKED ON YOUR SITE AND THOUGHT MAYBE (THE FUSE) SO MY LITTLE SCREW DRIVER REMOVED SCREWS AND LIKE MAGIC, X2GEN WAS UNPLUGGED AND THE COMPONENTS WERE SEPARATED FROM EACH OTHER.
NOT REALLY HARD TO BELIEVE I STILL HAVE NO IDEA IF THERE IS A FUSE IN THE THING..
BACK TO YOU GUYS AND FINISHED READING YOUR THOUGHTFUL SOLUTIONS.
I DO KNOW WHAT THE POWER SUPPLY IS ---"back to known stuff" --AND THOUGHT WHY SEARCH FOR A NEW ONE FROM THE POOR FOLKS THAT WENT BELLY UP MAKING THEM IN THE FIRST PLACE??? "NOW THAT'S DEFAULT"
THERE IS A FISH TANK POWER UNIT THAT HAS THE SAME NUMBERS - IF THAT DON'T WORK--DUMPSTER & WILL GET A MONITOR FROM SOMEONE THAT STILL HAS A JOB--GOT TO KEEP'EM WORKING.
I WAS VERY HAPPY TO FIND YOUR SITE AND ALL THE FOLKS THAT TOOK THE TIME TO WRITE HELP--THANK-YOU FOR REAL rg
Posted on Jan 28, 2009
I purchast x2gen manitor madel mw19u 4 years ago and it stopt working help!
4 years monitor will more likley to have bad caps by now, which is very common problem as you can see in my albums, that will be the first thing to look for.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 12, 2011 | X2Gen MG19MY 19" LCD Monitor
X2gen mw19u monitor is off but the ''no signal'' light keeps flashing on and off. When I power up the computer, it continues to flash on and off. You can see that the computer is powering on and going...
Hi Steven,
You are getting "No Signal", indicates that CPU is working fine. Check with another monitor or desktop, if it is working gateway monitor is in risk. I recommend you to check with Gateway technician.
Jun 14, 2010 | Computers & Internet
Black screen
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 15, 2010 | X2Gen MG19MY 19" LCD Monitor
X2GEN MONITOR LIGHT ON AND CLICKING
Hi...there,
Well, it is seems your monitor backlight inverter got burnt... need to replaced a new one or repaired it.
Dec 01, 2008 | X2Gen MG19MY 19" LCD Monitor
X2gen mw19u 19'' widescreen monitor going black
Try your monitor cable connections on both your pc and into your monitor.
Make sure they are TIGHT and level.
Also, it could be your video display card is faulty or your video display drivers are corrupt.
Try setting your desktop to a lower resolution, like 800x600 and see it that helps.
Nov 19, 2008 | X2Gen MG19MY 19" LCD Monitor
X2GEN MW19U Does Not Power On
You will need a multimeter to check, there is a proteection component that may look like a transistor( but only 2 leads on it) or what might look like a small blue capacitor. also the diodes at the power circut need to be checked. also be sure that solder conections are secure in the power circut
Oct 06, 2008 | X2Gen MG19MY 19" LCD Monitor
Black screen
Hey...Benji,
It's seems your backlight inverter are burnt out...Get a new one..or repaired old one by yourself.
Here how it done...need to replaced a new capacitors. Good lucks!
Aug 19, 2008 | X2Gen MG19MY 19" LCD Monitor
X2gen MG19E monitor
The only way to adjust the tilt on these monitors is to loosen the screws that attach the stand to the monitor. We had to completely remove the stand from the monitor to get to these stand screws.
Feb 12, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
318 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
