Question about Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB600 will not switch on
I have changed the batteries (a few times), cleaned the contacts and the thing still will not turn on. I have tried it on and off the camera, but nothing happens.
Any suggestions or recommendations for where it can be repaired in London?
  • 6 more comments
  • yegster Feb 13, 2009
    Completely dead. Won't switch on
  • Anonymous Feb 15, 2009
    so frustrating!! i am having the exact problem and can not figure it out?
  • Anonymous Feb 17, 2009
    Exactly the same problem, all of a sudden it's dead.
  • rsky Feb 27, 2009
    Hmmm, that's exactly what happened to my SB 600. I had just purchased new batteries a month or two ago and it was working fine. Yesterday I pulled it out cause I needed a self portrait and it wouldn't even turn on. Placed 4 new batteries in it and no luck.
    Makes it hard to even think of buying another if this happens so normally!
  • Anonymous Mar 14, 2009
    Same exact problem
  • Anonymous Mar 15, 2009
    Well, in search of answers, here I came and me too.  It had good batteries in about a month ago, may have been left on, but I have put fresh in and nada.  Checked twice to make sure polarity of batteries correct.
  • cloud9photos Apr 06, 2009
    Unit will not power on at all, checked battery compartment, and it appears to be clean and free of corrosion.
  • Anonymous Apr 12, 2009
    This flash has problems... goes dead after no use for awhile... quickly opening and closing the door wakes it up somtimes...poorly made flash.
I'm sure this won't work for everyone but I used a long thin flathead screwdriver to scrape some corrosion off of the contacts that would be touching the positive side of the battery and then it fired up fine.  I'll use some swaps dipped in alcohol to give them a better cleaning later but after the scraping (gentle) it fired right up.
Posted on Mar 16, 2009
  • 1 more comment
  • pelube Sep 18, 2010
    Worked like a charm for me too. The corrosion can be very subtle to he eye, but obvious when scraping gently.
  • tcfire
    tcfire Dec 30, 2012
    WOW!! Mine crapped out a yer ago and I was ready to replace it...did the screw driver trick and it's like new!!! Thanks!!!
  • Michael Leiber
    Michael Leiber Nov 25, 2013
    excellent , same here. Invisible but after a little screwdriver treatment turned on again
Corroaded contacts on my nikon sb600
If its not that bad , use a pencil with eraser better yet an ink eraser and rub the contacts
Nov 15, 2013 | Nikon Speedlight SB-600 TTL Flash
Sb 600 not able to get out of standby
If you cannot release Standby from within the menu options, here is one thing I did: removed all batteries then pumped the on/off button numerous times. Upon replacing the batteries the issue is solved. If that does not work then it may need to go to Nikon. The SB600 seems to have more issues than the SB800 and up.
Oct 08, 2013 | Nikon Speedlight SB-600 TTL Flash
Sb600 keeps flashing
The the signal to the camera to shoot flash off the camera
change your settings
Jul 11, 2013 | Nikon Speedlight SB-600 TTL Flash
Canon DSLR will not turn on
Hi there,There are a few things we can try/check here!
1.Turn the camera OFF. Remove the battery and clean the contacts (shiney metal strips) on the battery.2. Remove the lens and clean the lens contacts.3. If you have a body cap, put it on the camera (no lens, just to keep dust out right now).4. Reinstall the fully charged battery and turn on the camera.
It should start up. If so, turn it back off and reinstall the lens.
Also, be sure to check all the doors/hinges on the body. These are found on the battery and the memory card. They have electrical contacts on them that need be to be fully closed.
If possible, try a different battery (a friends, or take it to your friendly neighbourhood camera shop).
Hope it turns back on!
May 07, 2012 | Canon EOS Digital Rebel XTI Digital Camera
Canon Eos D40 Keep Error 99
You will need to clean the contacts, cleaning all the contacts will stop the error code for coming up. Next thing to try out is a full reset. Remove the main battery and the date/time battery. Close the battery door and turn "on" the camera and then depress the shutter button and turn off the camera and replace the batteries.
Jan 10, 2011 | Cameras
My speed light does not switch on even with new batteries. PLEASE HELP!!!
circuit board is burned... you will have to replace it. same thing happen to my sb600... and looks like a quality issue with nikon speedlights.
Mar 20, 2010 | Nikon Speedlight SB-600 TTL Flash
Will not turn on
Make sure there is no battery corrosion on the battery contacts. If there is rub it off with a pencil eraser (nothing abrasive or it willget worse) until bright and shiney. If this does not fix the problem it should be sent off for service.
Jan 01, 2010 | Nikon Speedlight SB-600 TTL Flash
Camera has failed to operate giving a "change batteries" message
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 29, 2009 | Canon PowerShot S3 IS Digital Camera
Nikon Speedlight SB-600 TTL Flash Logo
1,343 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
