Question about Whirlpool LER5636P Electric Dryer
Dryer will not start
I have a Whirlpool Ler5636eq3. It started squealing the other night. Last night after load of wash finished I put a new load in and pushed the start button. It will not start or turn. It just makes a motor noise and a burning smell. The Blets are secure. Any ideas?
  • savannahsmil Feb 05, 2009
    how do i know belts are secure?
    I found a tight one on back, and a soewhat loose one around bottom. how do i fix them
  • bhrhodes Mar 10, 2009
    My dryer problem is similar to Jessie_lee_8's. When I press the start button, there is a loud buzzing noise and it sounds like the motor will not engage. Prior to this happening, the dryer was making sort of an intermitant squealing/squeaking noise and only did this for a day or two before progressing to the stage it's in now. Haven't noticed a burning smell, however.
  • 65 Answers
IT SOUNDS AS THOUGH YOUR MOTOR HAS LOCKED UP AND FAILED. THE BURNING SMELL IS THE VARNISH FROM THE WINDINGS OF THE MOTOR. REPLACE THE MOTOR. THEY CAN BE HAD FOR AROUND EIGHTY DOLLARS
Posted on Jan 27, 2009
I have a whirlpool dryer model #LER5636EQ3 which the power cord was missing upon aquiring it, the wall socket in my laundry room is a 50amp, so I need to know if a 50amp power cord would be a proper...
The recommended power cord is a 30 amp 3- or 4- wire cable. A 50 A cord could cause a problem by allowing a surge to the dryer motor and damage the dryer or start a fire. There are 30A to 50A adapters (see RV and boat supply vendors). The installation instructions for the LER5636EQ3 are available here: https://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%203397618.pdf . See page 5 of the PDF.
Note: the 50A outlet has a 50A circuit breaker protecting it. If you swap the outlet to a 30A outlet, you will also need to replace the breaker with a 30A one.
I hope this helps.
Feb 01, 2013 | Whirlpool Dryers
Whirlpool Dryer Model LER5636EQ3. Runs for several minutes then stop.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 23, 2011 | Avanti D110 Electric Portable Dryer
Dryer will not turn on,timer is counting down. I do not have a fuse problem, can you give me possible reason. We just finished a load of wash last night. ...
heatman101
Apr 30, 2011 | Whirlpool Dryers
Loud squealing sound when the basket first spins up this is a Kenmore stacked set, washer on the bottom, and dryer on top
Your problem could be a bad bearing...The drum rides in a bearing at the rear middle of unit..Its basically a plastic insert...When the dryer is first started the bearing will squeal until the plastic warms up..Normally you will hear the squeal at the back middle of dryer...Your problem may also be the belt tensioner...Again a plastic wheel with a metal bearing inside...Normally this squeal will be from start to finish..
Apr 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer ran fine. Next load it would not start. It is a 220V, 5 cycle-3 temperature unit. Model # LER5636EQ3 TYPE: 178-00
Check your door switch to make sure its ok. Whirlpool has a fuse on the back of the machine inside. Fuse will be white in color. If that is open, check for a clogged vent or ck your hi-limit thermostat. If everything else is ok you have a bad timer.
Sep 10, 2009 | Dryers
During washing the kenmore 70 series washer squeals
Re-check the motor coupler.
If it was not seated flush on both post it will bind and squeal.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Whirlpool ler5636eq3
check and see if belt is broke you have to lift the top and then remove the front with two screws on each side on the inside pull out and up. after you lift the top you will see the tub and a belt should be on it if so lift up on the belt it should be snug if it comes off in your hand bingo there is your culprit remove front and install new belt
Dec 27, 2007 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
265 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
