Question about GE 26939GE2 Cordless Phone
My Phone Won't Recieve A Signal?
Okay well the problem with this phone is that every time i hit the talk button on the handset it beeps two times and goes dead. I've charged the batter for at least 12 hours and it still did it. So we got a new battery and replaced it. We charged that one for at least 12 hours again and it does the same thing! It's like the handset lost contact with the base. We can still make calls with speaker phone on the base. We can tell the battery works because some functions work on the handset. The charge light blinks when we charged it. So we are stumped and were wondering if you could help us!
I Have exactly the same problem. maybe someone found a workaround for this issue? Thank you
Posted on Aug 04, 2007
SOURCE:
My handset is display only searching, I cannot make or recieve calls & it is just flashing 88
when I press talk I get connectin9..handset out of range..searcgin9
when I press end I get Searching
Jan 30, 2013 | Uniden DECT 6.0 Cordless Phone
I have the phonemate 2970 answering machine/phone and satellite extension phone. When I turn the sat phone on I get a series of beeps and the HOLD light flashes for about 6 times then shuts down. I...
1. Remove the AC adapter plug from the back of the base unit (not from the wall); leave tel cord connected.
2. While holding down the "set code" button under the cassette lid, plug the ac adapter back into the base. The screen will then display some numbers (110) etc.
3. Hold down the HANDSET keys 1 and 2 simultaneously and then press the speaker button on top within 20 seconds.
4. Press any 3 digits on the handset i.e. 1-2-3.
5. After hearing a BEEP from the handset and base, press 2 on the handset. The base should then say "twenty-five", and the handsets will beep, confirming the new security code is enabled. Press talk or speaker on handset to confirm communication.
6. The time/day stamp and remote access code will be cleared.
7. Best to do this with the answering mach turned off.
8. Restart this procedure if anything goes wrong (may hear a series of error beeps).
I saved my manual and in it I had a fax Casio sent me with these instructions (i had this prob a few times years ago). Good luck!
Jan 18, 2011 | Casio PhoneMate PMP3875BK
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Nov 12, 2010 | Uniden Lands Phones
No instruction manual
On the handset that is on the base is the one you need to use to set the time and date. It will also clear out the CL on answering machine.
On the handset without pushing talk hit the flash key. A message will appear on your phone and it says Answering machine. You can listen to all the options but to set time and date ---push the 8 button.
Set your time by using the phone keys such as it's 09:53 then look up in the right corner and use the + arrow key to set AM or PM. Then hit the # key. Then in the upper right corner it will say Mon---use the + arrow key to set the day. Then hit the # key. The message on your phone will say the day is and then the time is. Then hit flash. Then you can check your answering machine and see if that worked. This took me some time. I would not buy another phone like this again.
Mar 06, 2009 | GE 25952EE1 Cordless Phone
All handsets cannot be used at the same time
Some of the cordless phones do not allow more than one handset to be used at the same time. Is there a transfer button on the handsets? Can you call from one handset to the other? If not the phones probably have to be used one at a time.
To get off speaker phone just push the speaker phone button again.
Jan 28, 2008 | GE 25931 Trio Cordless Phone
Motorola 580 handset not working
My handset does not connect to the base station. It flashes momentarily, but does not find the base. The base station has a humming noise when the phone line is disconnected and the talk button is depressed. Hum is also present when the phone line is reconnected. The problem was resolved by replacing the 9VDC power supply. The hum disappeared and the handset immediately connected to the base.
Oct 31, 2007 | Motorola Mobility MA580 (612572111116)...
Cordless GE phone issue. 25825GE3-A
1. press the "talk" button FIRST
2. then press "program" button and follow instructions on screen
only one phone said "needs registration" but had to register all 4 phones but this worked for me
hope this helps
Sep 11, 2007 | Uniden Cordless Phone
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
New Expansion Handset refuses to register with the base
If im not misytaking the base has to be set up for another expansion too.
Apr 06, 2006 | Motorola Mobility MD7091 Cordless Phone
GE 26939GE2 Cordless Phone Logo
145 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
