Question about GE ZV750SY Kitchen Hood
Light globe burned out in fiori range hood - GE ZV750SY Kitchen Hood
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Range Hood Parts... no where to be found
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Torin E13 Rangehood. Blown light globe needs replaceing
Gee I think I could figure that out by looking at it .
Jan 17, 2016 | Kitchen Ranges
Reverse lights out on 02 chevy mc
Check the fuses. Not always the globes that burn out. Fuses are either A) in the bonnet (Hood) or B) Under the dash (including the side panel of dash boards).
Jan 04, 2014 | Vehicle Parts & Accessories
Westinghouse range hood wrf900cs light blew, light globes replaced but lights still not working
I had the same problem. An audible pop and the lights stopped. Fans still works, light bulb filaments appear intact.
My problem was that a short piece of the copper on the printed circuit board, inside the switch housing, had vaporized as if it were a fuse. I soldered a bridge of copper wire across the small 5mm gap and all was working again.
Access the switch compartment by removing the filters, undo a couple of retaining screws to remove switch unit.
Make sure the electricity to the unit is Off/unplugged before proceeding!!!
Switch unit cover has 4 screws holding it on. Once inside the unit, trace the wire (mine was grey colour) from the light switch to the small printed circuit board. The copper printed circuit link to the connector had gone...no sign of burning, just gooone!
Solder a bridge of copper wire across the gap and reassemble switch unit to test.
....send beer donations to me in qld...cheers!!!
Jun 29, 2012 | Kitchen Ranges
Burned out light on bertazzoni hood
Here is how I fix this problem in case someon is still looking for an answer: 1. Turn power to hood off at electric panel 2. Remove light diffusers - these are the round glasses under hood covering the light bulbs. Turn the light diffuser counter clock wise to remove 3. Remove the burned out light bulbs 4. Install the new light bulbs
Jan 05, 2012 | Bertazzoni K48HERX 48" Kitchen Hood
Can you send me step-by-step directions on how to replace a burned out oven light on a Kenmore 30" Electric free standing range, Model#911.92712021, Serial # 2V2 16648Q?
Open the oven door. Grab the light globe and turn it counter-clockwise until it comes off. Next, grab the light bulb, turn it counter-clockwise until it comes out.
Reverse procedures to re-install
Nov 10, 2010 | Ovens
How to replace light globe in Chateau Grange rangehood
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
Nov 17, 2009 | Kitchen Ranges
I am looking for replacement globes for the range hood of our lofra oven. They look like usual down lights, 230V40W, screw in but have a white collar approx 2 cm long between globe and screw part... any...
Ok, the bulbs that you describe are fairly standard energy efficient ones I think, have a look at the link and see if it looks right, the only complication is the size of the screw fitting, it will be either an E14 or E27 the E14 is the smaller.
http://www.lightbulbs-direct.com/bulbfinder/?w=6-11&v=220-250&c=Screw&f=Any&cat=25
I hope this helps, and good luck!
Nov 17, 2009 | Lofra MBX76MFI Dual Fuel (Electric and...
Feb 10, 2009 | GE ZV750SY Kitchen Hood
GE ZV750SY Kitchen Hood Logo
53 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
