Question about Canon iR 2016i Black and White Copier
Out of toner cheng - Canon iR 2016i Black and White Copier
    Problem Solver:
  • 18 Answers
Clean the toner of dp unit baising
Posted on Mar 14, 2013
Sharp AR-M 420U How to chenge language and copy coming is very light scanner also clean
You have to in to admin settings for language.
Settings Key > Administrator settings > Enter 5 digit pin > Operation Settings > Display Language Settings.
Check the toner cartridges and Drum Unit. Most people forget about the Drum it probably needs to be replaced but check toner first.
Mar 19, 2017 | Sharp Office Equipment & Supplies
How do i fix error f2 70 new blk cartridge installed
you need to chenge the toner sensor for the macining
Jan 20, 2015 | Sharp MX-3501N All-In-One Printer
Do I need to input code after chenge new toner?
http://files.sharpusa.com/Downloads/ForBusiness/DocumentSystems/MFPsPrinters/Manuals/cop_man_ar235_75.pdf Go to page 82 for instructions, no code is needed to be inputted after changing toner.
May 13, 2014 | Sharp AR-275 Copier
Sharp ar m550n error codesError code F2How can i fix it ?Help me plz , Thank
press and hold start key to show you sub code and send for me but i think you toner cartrige shode chenge
Dec 18, 2013 | Office Equipment & Supplies
My iR2018N canon xerox machine problem is display show out of toner chenge toner.
If you have already tried a new toner cartridge, try another one. Ensure you are using an approved toner cartridge for your model machine. Your toner supplier should have all the required information to provide you with the correct toner. If multiple toners have been attempted and it still fails to properly acknowledge them, call for service.
Oct 24, 2013 | Canon iR2018N
This printer is not even 6 months old and I cannot get a WORD Document to print.
from control panel \ printers and faxes, view can you see in that folder your printer, if yes, right click on your printer and second line - set as a default printer, then can print.
If you see it and your printer is a default printer, change usb port and put another usb port,
If you can print, but printer is printing bat, you need chenge cartridge or toner.
Jun 13, 2011 | HP Office Equipment & Supplies
How tha cheng samsung ml 1610 pickup rollor
maybe you mean How to change paper pickup roller?
If YES - follow this simple steps:
  1. Open front cover
  2. Remove toner cartridge
  3. Look for two plastic pins (left and right side of the roller) on top.
  4. You have to use flat screwdriver to unlock this pins but be careful to avoid any damage on it.
  5. The trick is to unpin left and right pins at the same time.
  6. To turn back this roller you have to put first bottom pins then press the roller up until you hear a sound as click.
Warning:
Be careful with tire direction, if you turn it with wrong direction printer does not pick up the paper!!!
Good luck!!!
Mar 21, 2011 | Samsung ML 1610 Laser Printer
Copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
KONICA MINOLTA C300 GIVES JOB WAS NOT RUN CORRECTLY ERROR
Change your dns and smtp in the copier. Go to your browser and type the IP of your copier in the address bar. You'll find these settings in the Network section, the administrator password is '12345678'or '00000000'
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Aug 06, 2009 | Konica Minolta bizhub C250 All-In-One...
Chenge the langue
Under blue "set" icon menu, second from bottom is "language".
Feb 14, 2008 | Fuji FinePix F401 Digital Camera
Canon iR 2016i Black and White Copier Logo
65 people viewed this question
old marine
old marine
