Question about SimpleTech 320GB SimpleDrive External by Fabrik 320 GB USB 2.0 Hard Drive
I have 320GB hard dsik capacity. But yesterday i have given by laptop to format and install OS(Windows 7). But now i am able to see only 296GB. Please let me know what will happen to remaining space.
  • SimpleTech Master
  • 27,725 Answers
There are many reasons.......
Maybe you have available unpartitioned space left in the hard disk. To check this:
1. Right click on the "Computer" icon on the desktop and select "manage"
2. After the Computer Management window appears, select Disk Management. It should show you if you have any unpartitioned drive space.
3. You can up or format your unpartitioned spaces from hereon. may be your harddisk is corrupted and has space 296GB only
or sometimes all drives contains some space for system file in that space is hidden
Posted on Jan 23, 2013
2 Suggested Answers
ikechinedu
  • 184 Answers
SOURCE: My SimpleTech 320GB external hard drive is no longer recognized
trying using it on another system and and see if it happens like that. if it does, you may want to get a driver for the hard drive. it is likely the driver is corrupted. try it on another port also.
Posted on Jun 09, 2009
Hi guys, how important is the hard drive caddy? my father bought a presario v5000 from a garage sale. i found out that the hard drive caddy was missing and the hard drive in it was broken as well. will a...
OK look any drive, that's is the format, ie: STA or IDE? and that will fit will work, that 320GB will be OK. Simply install the HDD in the bay, and then use a windows installation disk, or similar to format it, just format it as ONE big partition, that should be fine, IF you find that it will not "See" the HDD, then partition it into smaller partitions. However you should be OK. You need to FIRST test to see if the actual PC is OK, try a HDD before you buy a new one, make sure that it is actually working.
Oct 11, 2011 | Computers & Internet
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
I have a laptop IBM thinkpad type 2373 I was trying to install a new OS, and I deleted all the partitions and format the hard drive, but the installation failed. And now I have been trying to start the...
Hi
You need to make the proper format, in order not to see this message.
Tell us please which OS you intend to install, what tool you used to format?
If your hard drive is 250 GB or less, you can format it using OnTrack Disk Manager,
For any hard disk capacity, you can use Windows CD to format.
Please tell us your results
Good Luck
May 14, 2011 | IBM ThinkPad T43 Notebook
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
I have a Toshiba A45-S121 laptop. I upgraded my hard drive from a 40GB hard drive to a 320GB Western Digital. Loaded Windows XP and formated drive in FPTS format. The computer rebooted to the hard drive...
Best possible solution put back your 40GB and try to get an external casing for your 320GB to see if it works.And try windows on NTFS instead of FPTS, so reformat your 320GB and install the Windows XP again.
I hope this solution is helpful.
Sep 26, 2010 | Toshiba Satellite A45-S121 Notebook
If the Hard drive is 320gb then why does it show up on my computer as 298gb?
This is called file system over head. When you "format" a drive in Windows for example, the operating system uses a certain portion of the space for allocating the file system, Master File Table, and partition information. So, the 298 you see, is the formatted capacity. The larger the drive, the more "reserved space" is used. If you find this helpful, please leave positive feedback.
TechRx, Inc.
http://techrxgb.com
Aug 26, 2010 | Seagate FreeAgent Pro Desktop - 320GB -...
How to reformat my MSI notebook?
You need to have an valid Operating System installer CD/DVD. This could be a Windows or Linux installer or whatever Operating System that you prefer.
  1. Turn your laptop on.
  2. Open the CD drive and load the CD Installer.
  3. Reset your laptop to manually reboot it. If you loaded the CD fast, this step is no longer required.
  4. The setup program will then load. Follow the onscreen procedure.
  5. At the point of selecting the hard disk drive, choose "Delete Partitions" to completely remove all data.
  6. After deleting partitions, create new partitions for your hard disk. You can choose to divide your hard disk capacity into 2 or more partitions depending on your requirements.
  7. Format the root partition now (Drive C) to continue the installation.
Mar 03, 2010 | Computers & Internet
Format my computer
You can format the computer with the restore discs that came with the computer or with windows installation cd. you can format the hard drive / computer in the setup, it will format the hard drive as you go forward, it will ask if you want to format fast or slow etc.
let me know if you need anything else.
Ekse
May 05, 2009 | Acer Extensa 4620 Notebook
SimpleTech 320GB SimpleDrive External by Fabrik 320 GB USB 2.0 Hard Drive Logo
144 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
