Question about Canon PIXMA MX310 All-In-One Printer
Mx310 stuck in factory mode 1
I have used compatible ink, and have tried the solutions suggested of switching on holding reset button, pressing, removing cartridges...you know the long list! However my printer goes to "factory mode 1" and won't let me do anything else. Any suggestions before I throw it out the window?
mtspace
  • 103 Answers
SOURCE: reset Ink levels for canon mx310
I've heard that with canon there is a way around the ink-level chip monitoring on the cartridge by doing the following:
  1. Power off printer
  2. Hold RESUME button then press and hold POWER, the beeper will sound once.
  3. Hold POWER and release RESUME
  4. Press RESUME twice
  5. Release POWER button
  6. When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
  7. Press POWER to set data
Posted on Jan 05, 2008
  • 6 Answers
To Reset the Canon Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Any problems contact me on charmed_halliwell@hotmail.co.uk
Posted on Feb 23, 2008
worldvet
  • 859 Answers
SOURCE: MX310 error code U163
Can you tell me, have you replaced the empty tank with a full one? And, have you manually reset the ink level function by pressing Stop/Reset for a full 6 seconds (one second longer than described in your manual?)
If you have, and you still see the ink cartridge light flashing, does it flash every second or every three seconds?
The contacts for the ink cartridge are easy to contaminate by accident. Sometimes wiping the contacts off with alcohol will clean them enough for the ink level to be recognized.
Now, and yes, this is a common problem. Press and Hold the Stop/Reset button for 6 full seconds again after cleaning the contacts and then release it? Use the one Mississippi method of counting.
The Scan cover must be closed completely and locked in place. And the ink cartridge must be firmly locked in place as well.
Please advise me of your results. There may be a more complex problem involved and it is important to have the necessary data in order to get you back to working again. Okay?
How long has it been since you purchased this printer?
Regards,
Worldvet
Posted on Oct 17, 2008
  • 191 Answers
SOURCE: Reset Canon printer chip
you can override ink check status and manually reset it in drivers options
Posted on Sep 22, 2009
pineworks
  • 4041 Answers
SOURCE: Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Posted on Jan 25, 2010
Why is alarm light flashing? 5800
The ink absorber is full,The waste ink error is based upon time instead of actual volume in the tank. You can reset the counter by the instructions below.
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the STOP/RESET button, then press and hold the POWER button.
(3) Release the STOP/RESET button, Next press and release the STOP/RESET button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the STOP/RESET button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!)
After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Dec 18, 2015 | Canon PIXMA MX310 All-In-One Printer
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
Where would i find the ink absorber on my mx310
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
B52Computers
Jan 10, 2011 | Canon PIXMA MX310 All-In-One Printer
How do I re set the cartridges after a refill on my Canon PIXMA MX320?
Hi there
Here How to Disabling Low Ink Level Notification for Canon IP and MP, the method to reset
Ink level notification:
1. Push “resume” for 5 seconds for canon For MPXXX you must enter to service
Mode.
2. Push Power switch then remove power cord.
3. Insert plug power cord while pressing “power switch” at the same time.
4. Push Start/reset by step 2 continue Wait display shown “0′
5. Push + change display from “0′ to “1′
6. Push colour button 2 times
7. Push Power switch again, Printer will print 1 page
8. Open cover
9. Unplug power cord
10. Take out ink cartridge #40 and #41
11. Insert plug again
12. Push power switch
13. Open cover (scan cover)
14. Insert ink cartridge #40 and #41 again
Enter to service mode for canon MPXXX
With the printer powered off but connected to a power source, press the Power
Button while pressing and holding the Stop/ Reset button.
When the Power is lit, press the Stop/Reset button two times while pressing and
Holding the Power button.
Order), the printer will move into a service mode. (Waiting for menu selection)
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 30, 2010 | Canon PIXMA MX310 All-In-One Printer
Resetter
http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
The reset method work for canon printers that using PG-40 and CL-41 cartridge. After doing thisreset method canon printer will not display low ink notification anymore and will not show error code “E4′ or “E5′. This method takes from indoreset yahoo group and prepared by Choy.
Here How to Disabling Low Ink Level Notification for Canon IP and MP, the method to reset ink level notification:
  1. Push “resume” for 5 seconds for canon IPXXXX. For canon MPXXX you must enter to service mode.
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
http://downloadprinterresetter.blogspot.com/
OK, go to website above, and download a "Resetting" tool, this makes resetting easier to do.
Apr 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Pixma mx328 check ink u051
The error usually came out after you refill ink on the black cartridge...there is no way you can make the printer work without resetting the ink cartridge..
Try to reset the printer using this procedure.. it will help.
1. turn off the printer..
2. press/hold the stop/reset button..and press/hold power button too..
3 while holding power button, release the stop/reset button..
4. then press the stop/reset button twice..
5. release power button..and wait until the power button lights a steady/still green and says "idle"...
6. open the cover...take out both catridges.. then turn off the printer.
7.put back the cover then turn on...
8. now put the catridges back.. and wait for some time to return to display menu... then try to print...
The printer may still prompt a "black ink volume unknown and color ink volume unknown" but don't worry that won't affect the operation of the printer. And you will able to use your printer, fax and scanner.
Do this every time you refill the ink of the cartridges.
If you find this solution helpful please vote on this on the YES below..thanks..
Dec 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx300 not printing
Hi
It is ink low error U051
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Or try this
Here the Solution to reset the ink level for Canon Pixma MX300 follow this steps to reset the ink level in your canon MX300.
  1. Switch off the Canon MX300 and disconnect the power cable.
  2. While press and hold the power button, Connect the power cable to electric socket.
  3. While pressing the power button, press the “Cancel/Stop” button (red button).
  4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says “idle”.
  5. Press “>” (next button) once “Shipping Mode 3′ then Press the “OK” button. Press “OK” again for “without cleaning”.
  6. A test page will print.
  7. Open the cover, like you are about to change the cartridges.
  8. Disconnect the power cable again without switch off the printer.
  9. Take out the both cartridges.
  10. Close the cover.
  11. Connect the power cable and turn on the printer.
  12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Nov 02, 2009 | Canon MX300 Office All-In-One Printer
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 wase ink full. Any ideas how to reset
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 13, 2009 | Office Equipment & Supplies
Reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
10. The page counter is now reset! Enjoy.
Jul 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MX310 All-In-One Printer Logo
304 people viewed this question
old marine
old marine
