Error code SC 542 ricoh aficio mp 3350b
SC 870 Address book data error
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
jonniewalker
  • 1029 Answers
SOURCE: copier ricoh aficio 450 error code SC 542-00 ?
  • SC542: Fusing temperature warming-up error
  • check the fusing unit -
    The fusing temperature does not reach the fusing standby temperature within
    125 seconds after the main power switch is turned on.
    - Possible causes -·
    Fusing thermistor defective or out of position
    · Fusing lamp open
    · Fusing thermofuse open
    · BICU defective
    · Power supply board defective
    · Poor fusing unit connection
    troubleshooting
  • to reset the error enter the sp mode c 107 ca then use the sp np 5-801 then pres ok
Posted on Mar 18, 2009
SOURCE: I have a ricoh aficio 2035 that reads error sc 542
Fuser warm up error. Repair problem (fuse, lamp, thermistor etc.) then reset code in service mode.
Posted on Jun 26, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Ricoh Aficio MP 4000 sc 870 error after power cord
SC870 = Address Book Data Error. This is most likely a hard drive failure especially considering the power loss. This is about a $175 repair in case you want to call around locally and get estimates to replace the drive. There is an outside chance you can get someone to walk you thru the Service Mode and do the following to reload the address book:
1. Enter the SP mode
2. 5846-50 (Initialize All Address Book)
3. Turn the machine off then on again.
Good Luck
Posted on Oct 20, 2009
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
What will I do to Ricoh Aficio MP 3350B with an error code of SC220?
Ricoh Copier Error Code SC 220 is Laser Sync Detect problem. Check your manual and there is a fix for this in the menu.
Sep 30, 2014 | Ricoh Aficio MP3350
Error code sc542
Fusing Temperature Warming-up Error
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermofuse open
• BCU defective
• AC drive board defective
• Poor fusing unit connection
Jan 20, 2014 | Ricoh Aficio MP 161 Black and White Copier
Ricoh Aficio 2022 Unit indicates to call for
You could reset all the counters but you should call a proffessional with a good mantenance KIT, your copier probably needs it...
Have fun!
Jan 04, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio MP 4000 sc 870 error after power cord was pulled with machine off but main power on.
Good Luck
Oct 20, 2009 | Ricoh Office Equipment & Supplies
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Jul 12, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
183 people viewed this question
jasbo
jasbo
